CY74FCT138T 8 选 1 解码器
数据:
The \x92FCT138T devices are 1-of-8 decoders. These devices accept three binary weighted inputs (A0, A1, A2) and, when enabled, provide eight mutually exclusive active-low outputs (O\0\x96O\7). The \x92FCT138T devices feature three enable inputs: two active low (E\1, E\2) and one active high (E3 ).
All outputs are high unless E\1 and E\2 are low and E3 is high. This multiple-enable function allows easy parallel expansion of the device to a 1-of-32 (five lines to 32 lines) decoder with just four \x92FCT138T devices and one inverter.
These devices are fully specified for partial-power-down applications using Ioff. The Ioff circuitry disables the outputs, preventing damaging current backflow through the device when it is powered down.
特性
  • 功能,引脚分配和驱动器与FCT和F逻辑兼容
  • 减少V OH (通常= 3.3 V)等效FCT功能的版本
  • 显着改善噪声特性的边沿速率控制电路
  • I off 支持部分掉电模式操作
  • 匹配上升和下降时间
  • 与TTL输入和输出逻辑电平完全兼容
  • 具有启用功能的双1至8解码器
  • ESD保护超过JESD 22
    • 2000-V人体模型(A114-A)
    • 200-V机型(A115-A)
    • 1000 V充电器件型号(C101)
  • CY54FCT138T
    • 32 mA输出灌电流
    • 12 mA输出电源当前
  • CY74FCT138T
    • 64-mA输出灌电流
    • 32-mA输出电流
参数 与其它产品相比 编码器和解码器
Function
Technology Family
VCC (Min) (V)
VCC (Max) (V)
Channels (#)
Voltage (Nom) (V)
F @ Nom Voltage (Max) (Mhz)
ICC @ Nom Voltage (Max) (mA)
tpd @ Nom Voltage (Max) (ns)
Configuration
Type
IOL (Max) (mA)
IOH (Max) (mA)
Rating
Operating Temperature Range (C)
Package Group
Package Size: mm2:W x L (PKG)
Bits (#)
Digital input leakage (Max) (uA)
ESD Charged Device Model (kV)
ESD HBM (kV)
CY74FCT138AT CY74FCT138CT CY74FCT138T CY54FCT138T
    Decoder
Demultiplexer
Decoder/Demultiplexer
FCT     FCT     FCT     FCT
4.75     4.75     4.75     4.75
5.25     5.25     5.25     5.25
1     1     1     1
5     5     5     5
70     70     70     70
0.2     0.2     0.2     0.2
5.8     5     6     6
3:8     3:8     3:8     3:8
    Standard     Standard
64     64     64     64/-32
-32     -32     -32
Catalog     Catalog     Catalog     Military
-40 to 85     -40 to 85     -40 to 85     -55 to 125
SOIC
SSOP
SOIC
SSOP
SSOP     CDIP
LCCC
16SOIC: 106 mm2: 10.3 x 10.3(SOIC)
16SSOP: 29 mm2: 6 x 4.9(SSOP)
16SSOP: 29 mm2: 6 x 4.9(SSOP)     See datasheet (CDIP)
20LCCC: 79 mm2: 8.89 x 8.89(LCCC)
8     8     8     8
5     5     5     5
0.75     0.75     0.75     0.75
2     2     2     2
技术文档
数据手册(1)
元器件购买 CY74FCT138T 相关库存
相关阅读
