SN74CBT1G125具有单个高速线路开关。当输出使能(OE \)输入为高电平时,开关被禁用。
两个端口之间的开关连接| Configuration |
| Number of Channels (#) |
| Power Supply Type |
| Vss (Min) (V) |
| Vss (Max) (V) |
| Vdd (Min) (V) |
| Vdd (Max) (V) |
| Ron (Typ) (Ohms) |
| Bandwidth (MHz) |
| Rating |
| Operating Temperature Range (C) |
| Package Size: mm2:W x L (PKG) |
| Package Group |
| Supply Range (Max) |
| Ron (Max) (Ohms) |
| Input/Output Continuous Current (Max) (mA) |
| Supply Current (Max) (uA) |
| Features |
| OFF-state leakage current (Max) (µA) |
| ON-state leakage current (Max) (µA) |
| Input/Output OFF-state Capacitance (Typ) (pF) |
| VIL (Max) (V) |
| VIH (Min) (V) |
| SN74CBT1G125 | SN74CB3T1G125 | SN74CBTLV1G125 | SN74CBTLV1G125-Q1 |
| 1:1 SPST | 1:1 SPST | 1:1 SPST | |
| 1 | 1 | 1 | |
| Single | Single | Single | |
| N/A | N/A | N/A | |
| N/A | N/A | N/A | |
| 4 | 2.3 | 2.3 | |
| 5.5 | 3.6 | 3.6 | |
| 5 | 5 | 5 | |
| 200 | 200 | ||
| Catalog | Catalog | Catalog | Automotive |
| -40 to 85 | -40 to 85 | -40 to 85 | -40 to 125 |
| 5SC70: 4 mm2: 2.1 x 2(SC70) 5SOT-23: 8 mm2: 2.8 x 2.9(SOT-23) | 5SC70: 4 mm2: 2.1 x 2(SC70) 5SOT-23: 8 mm2: 2.8 x 2.9(SOT-23) | 5SC70: 4 mm2: 2.1 x 2(SC70) 5SOT-23: 8 mm2: 2.8 x 2.9(SOT-23) | 5SOT-23: 8 mm2: 2.8 x 2.9(SOT-23) |
| SC70 SOT-23 | SC70 SOT-23 | SC70 SOT-23 | SOT-23 |
| 5.5 | 3.6 | 3.6 | |
| 20 | 25 | 25 | |
| 128 | 128 | ||
| 10 | 10 | ||
| Voltage translation Ioff 5V tolerant I/O bidirectional low capacitance and on-resistance | Powered off protection | low tpd unbuffered low Ron Ioff 3-state Powered off protection | |
| 1 | 1 | ||
| 1 | 1 | ||
| 4 | 7 | 7 | |
| 0.8 | 0.8 | 0.8 | |
| 2 | 2 | 2 | |
