ADUM6221A adi
数据:
isoPower integrated, isolated DC-to-DC converter100 mA output supplyMeets CISPR 32/EN55032 Class B emission limits up to 5 Mbpsat full load on a 2-layer PCBDual DC to 100 Mbps signal isolation channels28-lead, fine pitch, SOIC with 8.3 mm minimum creepageHigh temperature operation: 125°C maximumHigh common-mode transient immunity: 100 kV/µs Safety and regulatory approvalsUL 1577 (pending)VISO = 5000 V rms for 1 minuteIEC/EN/CSA 62368-1 (pending)IEC/CSA 60601-1 (pending)IEC/CSA 61010-1 (pending)CQC GB 4943.1 (pending)DIN EN IEC 60747-17 (VDE 0884-17) (pending) VIORM = 596 V peak The ADuM6221A is a dual-channel digital isolators with an isoPower®, integrated, isolated DC-to-DC converter. Based on the AnalogDevices, Inc., iCoupler® technology, the DC-to-DC converter providesregulated, isolated power that meets CISPR 32/EN 55032Class B limits at full load on a 2-layer printed circuit board (PCB)with ferrites. Popular voltage combinations and the associatedoutput current levels are listed in Table 1.The ADuM6221A eliminates the need for a separate, isolatedDC-to-DC converter in 500 mW, isolated designs. The iCoupler chipscale transformer technology is used for isolated logic signals andfor the magnetic components of the DC-to-DC converter. The resultis a small form factor and total isolation solution.The ADuM6221A isolators provide two independent isolation channels(for more details, see the Pin Configurations and FunctionDescriptions section).Applications RS-232 transceivers Power supply start-up bias and gate drives Isolated sensor interfaces Automotive on-board charger (OBC) and DC-to-DC Industrial programmable logic controllers (PLCs)
