ADG788评估板:技术解析与应用指南
在电子设计领域,开关器件的性能和应用灵活性至关重要。ADG788作为一款采用紧凑型4mm×4mm、20引脚LFCSP封装的三重单刀双掷(SPDT)开关,凭借其出色的性能在数据和音视频切换等应用中表现出色。本文将围绕ADG788评估板展开,详细介绍其特性、硬件组成、操作方法以及注意事项。
文件下载:EVAL-ADG788EBZ.pdf
一、ADG788评估板特性
电源供应灵活
- 单电源供电范围为1.8V至5.5V,双电源供电为±2.5V,能满足不同应用场景的电源需求。
用户可通过Link J23轻松选择单电源或双电源操作模式,具体配置如下: Position Operation Mode A Single-supply operation B Dual-supply operation (default configuration)
控制输入兼容性强
具备TTL/CMOS兼容的控制输入,提供多种开关控制选项,包括板载链接和外部控制信号,方便用户根据实际需求进行灵活控制。
符合环保标准
该评估板符合RoHS标准,体现了其在环保方面的考虑。
二、评估板硬件组成
硬件套件内容
ADG788评估板套件包含一块完全装配好的印刷电路板(PCB)以及一张CD,CD中包含ADG788产品数据手册和评估板数据手册。
硬件功能
用户可将需要切换的信号连接到ADG788开关,并通过板载链接或向适当的连接器施加正确的控制信号来控制其操作。同时,可利用板上提供的测试点监测ADG788引脚处的信号。
三、电源供应与开关控制
电源供应
要使ADG788评估板正常工作,用户需提供一个连接到Power Block P1的外部电源。通过Link J23可选择单电源或双电源操作模式,为不同的应用场景提供了电源配置的灵活性。
开关控制
| ADG788的操作由四个输入引脚(IN1、IN2、IN3和IN4)控制。Link J8、Link J9、Link J12和Link J13用于控制施加到这些引脚的逻辑电平,用户可以通过向Connector J5和Connector J11施加外部信号来驱动这些引脚(信号具有50Ω板载接地端接电阻)。不同链接位置对应的ADG788开关状态如下: | Link | Position | ADG788 Switch Status |
| J8 | Removed | S2A to D2 = off, S2B to D2 = on S2A to D2 = on, S2B to D2 = off |
| A | |||
| B (default configuration) | Controlled via signal applied to Connector J5_TOP High: S2A to D2 = on, S2B to D2 = off Low: S2A to D2 = off, S2B to D2 = on |
| J9 | Removed | S3A to D3 = off, S3B to D3 = on | |
| A | S3A to D3 = on, S3B to D3 = off | ||
| B (default configuration) | Controlled via signal applied to Connector J5_BOTTOM High: S3A to D3 = on, S3B to D3 = off Low: S3A to D3 = off, S3B to D3 = on |
| J12 | Removed | S1A to D1 = off, S1B to D1 = on | |
| A (default configuration) | Controlled via signal applied to Connector J11_BOTTOM High: S1A to D1 = on, S1B to D1 = off Low: S1A to D1 = off, S1B to D1 = on |
| B | S1A to D1 = on, S1B to D1 = off | ||
| J13 | Removed | S4A to D4 = off, S4B to D4 = on | |
| A (default configuration) | Controlled via signal applied to Connector J11_TOP High: S4A to D4 = on, S4B to D4 = off Low: S4A to D4 = off, S4B to D4 = on |
| B | S4A to D4 = on, S4B to D4 = off |
四、连接与测试点
| 评估板上的连接器和测试点为用户提供了方便的信号监测和连接方式。具体的连接器位置、测试点以及与ADG788引脚的连接关系如下表所示: | Connector | Position | Test Point | Connection to ADG788 Pin |
| J1 | Top Bottom | T19 T1 | S1A D1 | |
| J2 | Top Bottom | T2 T3 | S1B S2B | |
| J3 | Top Bottom | T4 T5 | D2 S2A | |
| J4 | V DD GND V SS | T9 T10 T8 | V DD GND V SS | |
| J5 1 | Top Bottom | T6 T7 | IN2 IN3 | |
| J6 | Top Bottom | T11 T12 | S3A D3 | |
| J7 | Top Bottom | T13 T14 | S3B S4B | |
| J10 | Top Bottom | T15 T16 | D4 S4A | |
| J11 1 | Top Bottom | T17 T18 | IN4 IN1 |
需要注意的是,Connector J5和J11仅在Link J8和Link J9设置在Position B,且J12和J13在Position A时才与ADG788引脚相连。
五、评估板原理图与版图
评估板提供了详细的原理图和版图,包括评估板原理图、元件面PCB绘图(第1层)、焊接面PCB绘图(第2层)以及元件面丝印PCB绘图等,为用户进行电路分析和设计提供了重要参考。
六、订购信息
物料清单
| Qty | Reference Designator | Description | Supplier/Number |
| 2 | C1, C2 | 0.1 μF SMD ceramic capacitor | FEC 301-9482 |
| 2 | C3, C4 | 10 μF (0805 package) 10 V X5R SMD ceramic capacitor | FEC 498-737 |
| 8 | J1, J2, J3, J5, J6, J7, J10, J11 | Dual phono connector | FEC 128-0670 |
| 1 | J4 | 3-pin power block | FEC 963-2980 |
| 5 | J8, J9, J12, J13, J23 | 3-pin SIL header and shorting link | FEC 486-1220 and FEC 148-029 |
| 4 | R1, R2, R5, R6 | 10 kΩ SMD resistor | FEC 933-0399 |
| 4 | R3, R4, R7, R8 | 50 Ω SMD resistor | FEC 933-1336 |
| 19 | T1 to T19 | Test point | FEC 873-1128 |
| 1 | U1 | ADG788BCPZ | Analog Devices, Inc. |
订购指南
| Model | Package Description |
| EVAL-ADG788EBZ 1 | ADG788 Evaluation Board |
其中,Z表示符合RoHS标准的部件。
七、ESD注意事项
ADG788是静电放电(ESD)敏感器件,带电的设备和电路板可能在无察觉的情况下放电。尽管该产品具有专利或专有保护电路,但高能量ESD仍可能对器件造成损坏。因此,在使用过程中应采取适当的ESD预防措施,以避免性能下降或功能丧失。
综上所述,ADG788评估板为电子工程师提供了一个方便、灵活的平台,用于评估ADG788开关的性能。通过对评估板的深入了解和正确使用,工程师可以更好地将ADG788应用于实际项目中。大家在使用过程中有没有遇到过类似开关器件的ESD问题呢?欢迎在评论区分享你的经验和见解。
开关器件
1文章
220浏览量
17772
ADG788评估板:技术解析与应用指南
