RLE 电源参考指南:适配你的产品
在电子设备的设计与应用中,电源的选择至关重要,它直接影响着设备的性能和稳定性。RLE 的电源经过了严格测试,确保与旗下产品完美适配。下面为大家详细介绍 RLE 产品对应的电源信息。
文件下载:PSWA-DC-24.pdf
产品与电源适配表
| Product | Input Voltage | Connection Type | Power Supply Options |
| BMS - 1WIRE | 24VDC | Terminal block | PSWA - DC - 24 - ST |
| BMS - LD3Z | 24VDC | Terminal block | PSWA - DC - 24 - ST |
| BMS - WiNG | 24VDC | Terminal block | PSWA - DC - 24 - ST |
| F200 | 5VDC | USB | Power supply included with product - no additional purchase necessary |
| FDS - PC | 24VAC/VDC | Barrel connector & terminal block | PSWA - DC - 24 (included with product), PSWA - DC - 24 - ST, WA - AC - 24 - ST |
| FMS - 24 (1U) | 24VDC | Barrel connector & terminal block | PSWA - DC - 24 (included with product), PSWA - DC - 24 - ST |
| FMS - 24 (2U) | 24VDC | Barrel connector & terminal block | PSDT (included with product) |
| FMS - 48 | 36 - 72VDC | Hardwired | End user provides hardwired power |
| GD200 | 24VAC/VDC | Terminal block | PSWA - DC - 24 - ST, WA - AC - 24 - ST |
| LD1000 | 24VAC/VDC | Terminal block | PSWA - DC - 24 - ST, WA - AC - 24 - ST |
| LD1500 | 24VAC/VDC | Barrel connector & terminal block | PSWA - DC - 24, PSWA - DC - 24 - ST, WA - AC - 24 - ST |
| LD2100 | 24VAC/VDC | Barrel connector & terminal block | PSWA - DC - 24, PSWA - DC - 24 - ST, WA - AC - 24 - ST |
| LD310 | 5VDC | Terminal block | WA - DC - 5 - ST, PSWA - DC - 5 - ST, PSWA - DC - 5 - ST - KIT |
| LD5200 | 100 - 240 VAC | Hardwired | End user provides hardwired power |
| LDRA6 | 24VAC/VDC | Barrel connector & terminal block | PSWA - DC - 24, PSWA - DC - 24 - ST, WA - AC - 24 - ST |
| MD3 | 12VDC | Terminal block | WA - DC - 12 (customer needs to strip barrel connector off) |
| RA1X2 | 24VAC/VDC | Terminal block | PSWA - DC - 24 - ST, WA - AC - 24 - ST |
| RR10X20 | 24VAC/VDC | Terminal block | PSWA - DC - 24 - ST, WA - AC - 24 - ST |
| RR10X20 - 48 | 48VAC/VDC | Hardwired | End user provides hardwired power |
| RR20X40 | 100/120/240VAC | Hardwired | End user provides hardwired power |
| SD - RO1 | 24VAC/VDC | Hardwired | PSWA - DC - 24 - ST, WA - AC - 24 - ST |
| SeaHawk 10K | 12 - 24VAC/VDC | Terminal block | PSWA - DC - 24 - ST, WA - AC - 24 - ST |
| SMK | 24VDC | Terminal block | PSWA - DC - 24 - ST |
| WiNG - MGR | 24VAC/VDC | Barrel connector & terminal block | PSWA - DC - 24 (included with product), PSWA - DC - 24 - ST, WA - AC - 24 - ST |
| WiNG - MGR - 868 | 24VAC/VDC | Barrel connector & terminal block | PSWA - DC - 24 - KIT (included with product) |
| WiNG - RXT | 5VDC | Barrel connector | PSWA - DC - 5 (included with product) |
| WiNG - RXT - 868 | 5VDC | Barrel connector | PSWA - DC - 5 - ST (included with product) |
从这个表格中,我们可以清晰地看到不同产品所需的输入电压、连接类型以及对应的电源选项。大家在设计电路时,一定要根据产品的具体要求来选择合适的电源,否则可能会影响设备的正常运行。比如,如果给需要 24V 电源的产品接入 5V 电源,设备很可能无法启动。
电源详细信息
| Power Supply | Voltage Conversion | Isolated | Connection Type | Wall Plug Type | Region | Compatible Products |
| WA - AC - 24 - ST | 120VAC to 24VAC, 500mA | Yes | Stripped and tinned | Type A fixed | Domestic | FDS - PC, GD200, LD1000, LD1500, LD2100, LDRA6, RA1x2, RR10x20, SD - RO1, SeaHawk 10K, WiNG - MGR |
| WA - DC - 5 - ST | 100 - 240V to 5VDC, 1.0A | No | Stripped and tinned | Type A fixed | Domestic | LD310 |
| WA - DC - 12 | 120VAC to 12VDC, 2.0A | No | Barrel connector (customer must strip) | - | - | MD3 |
| PSWA - DC - 5 | 100 - 240VAC to 5VDC, 1.6A | Yes | Barrel connector | Interchangeable - includes Type A blade | Domestic | WiNG - RXT |
| PSWA - DC - 5 - Kit | 100 - 240VAC to 5VDC, 1.6A | Yes | Barrel connector | Interchangeable - includes Type A, C, G, and I blades | International | WiNG - RXT - 868 |
| PSWA - DC - 5 - ST | 100 - 240VAC to 5VDC, 1.6A | Yes | Stripped and tinned | Interchangeable - includes Type A blades | Domestic | LD310 in domestic locations |
| PSWA - DC - 5 - ST - Kit | 100 - 240VAC to 5VDC, 1.6A | Yes | Stripped and tinned | Interchangeable - includes Type A, C, G, and I blades | International | LD310 in international locations |
| PSWA - DC - 24 | 100 - 240VAC to 24VDC, 1.0A | Yes | Barrel connector | Interchangeable - includes Type A blade | Domestic | FDS - PC, FMS - 24 (1U), LD1500, LD2100, LDRA6, WiNG - MGR |
| International | FDS - PC, FMS - 24 (1U), LD1500, LD2100, LDRA6, WiNG - MGR - 868 | |||||
| PSWA - DC - 24 - Kit | 100 - 240VAC to 24VDC, 1.0A | Yes | Barrel connector | Interchangeable - includes Type A, C, G, and I blades | - | - |
| PSWA - DC - 24 - ST | 100 - 240VAC to 24VDC, 1.0A | Yes | Stripped and tinned | Interchangeable - includes Type A blade | Domestic | FDS - PC, FMS - 24(1U), GD200, LD1000, LD1500, LD2100, LDRA6, RA1x2, RR10x20, SD - RO1, SeaHawk 10K, WiNG - MGR |
| PSDT | 85 - 264VAC, 3.0A | Yes | Barrel connector on 24VDC side, C13 power cord not included | - | Domestic and International | FMS - 24(2U) |
这里详细列出了每个电源的电压转换情况、是否隔离、连接类型、插头类型、适用地区以及兼容产品。对于一些需要在不同地区使用的产品,我们要特别注意选择带有合适插头类型的电源。比如在国际项目中,PSWA - DC - 5 - Kit 就提供了多种插头类型,能满足不同地区的使用需求。
总结
在设计电子设备时,电源的选择是一个关键环节。RLE 为我们提供了丰富的电源选项,并且经过了严格测试,确保与产品的兼容性。大家在实际应用中,一定要仔细对照产品与电源的适配表,根据设备的输入电压、连接类型以及使用地区等因素,选择最合适的电源。你在电源选择过程中遇到过哪些问题呢?欢迎在评论区分享。
举报投诉
电源选择
8浏览量
6836
热点推荐
大功率电源定制避坑指南|厂家甄选核心技巧
设计 :过压、过流、短路、高温多重保护缺一不可,恶劣工况需强化防尘、宽温设计;
输入适配 :根据现场电网,确认是否需要宽电压、380V 三相自适应等定制化配置。
三、查验资质与质控体系,锁定合规产品
靠谱
发表于 04-29 13:54
UCC28704EVM - 724 10 - W USB适配器评估模块的使用指南
UCC28704EVM - 724 10 - W USB适配器评估模块的使用指南 一、引言 在电子设备飞速发展的今天,USB适配器作为常见的电源转换设备,其性能和安全性至关重要
电源适配器KC认证费用一般多少钱?
电源适配器出口韩国市场时,通常需要办理 KC认证。KC认证是韩国针对电子电气产品实施的强制性安全认证制度,由 韩国国家技术标准院 负责监管。很多企业在办理认证前,最关心的问题就是费用。下面为大家详细介绍
电源适配器EMC测试整改:2026年实操指南
电源适配器作为各类电子设备(家电、数码、工业设备等)的核心供电部件,EMC(电磁兼容)测试是其出口合规、市场准入的关键环节。无论是CE、FCC、ISED等认证,EMC测试不达标均会直接导致认证失败、货物扣留、产品下架
毫欧科普:详解合金电阻在电源适配器上的应用
合金电阻
毫欧电子作为合金电阻行业龙头企业,其自主研发的合金电阻系列产品(含封体合金电阻、裸露合金电阻等),通过严苛的材质选型与工艺优化,适配电源适配器的高功率、小型化、长寿命设计需求,已广泛应用
发表于 01-26 15:09
UPS电源的核心应用场景及适配逻辑
UPS电源(不间断电源)的核心价值的是保障负载连续、稳定供电,规避市电中断、电压波动、电磁干扰等风险,其应用场景已覆盖民用、商用、工业、关键基础设施等全领域。不同场景对供电质量、可靠性、延时需求
电源适配器开关机时间测试方法
电源适配器的开关机时间直接影响电子设备的启动响应速度、待机功耗及使用寿命,是评估适配器性能的关键指标之一。通过标准化测试,可准确获取适配器从触发开关机指令到输出状态稳定 / 关闭的时长
XDP™ XDP700 - 002:MOSFET 适配器板设置指南
XDP™ XDP700 - 002:MOSFET 适配器板设置指南 作为电子工程师,在进行硬件设计开发时,对各类评估板和适配器板的了解与使用至关重要。今天就来详细介绍一下 Infineon
CUI 电源适配器能够符合法规要求
作者: Pete Bartolik 在设计笔记本电脑和台式电脑时,设计人员大都倾向于在确定核心功能、性能和用户体验确定之后再选择电源适配器。但考虑到不断变化的监管影响,可以应将适配器选型放在整个
收银机的电源适配器坏了,可以用其他产品的替代使用吗?
在日常的商业运营中,收银机作为门店管理的核心设备,其稳定性和可靠性至关重要。然而,当原装收银机电源适配器坏了的话,我们是否可以用其他产品的电源适配
晶源微 CSC5812CL 应用指南:特性解析与场景适配
晶源微CSC5812CL是一款2.5A同步降压DC/DC变换电路,凭借宽电压适配、高集成度及稳定性能,在汽车电子、充电设备等领域具备明确的应用价值。本指南将从芯片核心特性出发,结合其性能优势,解析
RLE 电源参考指南:适配你的产品
