里斯本大学:基于石墨烯的摩擦电多传感器,用于智能纺织品自供电多模态运动传感
传感器专家网 来源:材料分析与应用 作者:材料分析与应用 2025-10-17 18:08 次阅读
加入交流群
微信小助手二维码
扫码添加小助手
加入工程师交流群
在康复治疗、运动训练和健康监测领域,对实时运动追踪的需求日益增长,这凸显了对兼具高精度、低功耗和舒适佩戴特性的可穿戴传感器的迫切需求。摩擦纳米发电机TENGs)通过将生物力学活动直接转化为电信号,为解决这一需求提供了可行方案,但其应用受限于变形时的机械不稳定性及对有线数据采集的依赖。本文,里斯本大学Helena Alves《 ACS Appl. Electron. Mater》期刊发表名为“Graphene-Based Triboelectric Multi-Sensors for Self-Powered Multimodal Motion Sensing in Smart Textiles”的论文,研究提出一种基于耐用纺织架构的全集成无线摩擦纳米发电传感系统。
该系统采用六枚聚二甲基硅氧烷基传感器,通过石墨烯纳米片(GNP)导电胶增强性能,并经微型蓝牙低功耗(BLE)模块实现多通道实时传输。在测试配方中,20%(质量分数)GNP复合材料在反复加载条件下展现出最佳导电性(约15 Ω/□)与稳定信号输出。集成系统在台式测试中展现出高达37伏的电压输出,并在宽温度范围(10–50 °C)内保持稳定性。通过结合可扩展材料、稳健的传感器设计和低功耗无线通信,本研究为自供电、高保真生物力学监测建立了实用平台。该方案为临床康复和日常健康应用领域开发新一代可穿戴系统开辟了新路径。
2图文导读
图1. (a) Morphology of films with different adhesive-to-graphene ratios, showing increased cracking in formulations with higher GNP content. (b) Sheet resistance of films as a function of GNP concentration, presenting a decreasing trend with increasing GNP content. (c) Step-by-step fabrication process of the triboelectric sensor, detailing material preparation and assembly of the positive and negative layers.
图2. (a) Schematic and real images of the triboelectric device, illustrating the positive (textile) and negative (PDMS) layers, as well as the vertical separation working mode, highlighting charge generation and current flow. (b) Output voltage at 3 Hz under forces ranging from 5 to 40 N, demonstrating an amplitude increase with applied force. (c) Output voltage as a function of active area and connection configuration, showing higher output for larger areas and connections along the longest side (black) compared to the shortest side (red). (d) Output voltage variation with temperature, showing a decrease from 90 to 70 V. (e) Output voltage response to relative humidity (RH), remaining stable up to 45% RH before significantly decreasing at higher levels. (f) Reversible effect of RH on output voltage over multiple humidity levels.
图3. (a) Diagram of the sensor-integrated shirt, showing triboelectric sensor placement (green, orange, blue), conductive paths, and communication module location. (b) Interior view of the shirt highlighting conductive connections and sensor deposition sites. (c) Exterior view of the sleeve with the negative sensor components marked in orange. (d) Circuit diagram of the communication module, showing the signal conditioning stage (blue) with impedance matching and noise reduction, and the wireless module (green) with Bluetooth Low Energy capabilities.
图4. Illustration of biomechanical motion and associated signal responses from three sensor channels, elbow (green), armpit (orange), and wrist/hip (blue), for different body movements: (a) elbow elevation with a flexed arm, (b) arm elevation (jumping jack motion), (c) arm flexion away from the torso, and (d) arm flexion against the torso.
3小结
综上所述,本研究成功开发出一种可穿戴式多传感器摩擦电系统,能够实现多关节的实时运动追踪。通过将基于聚二甲基硅氧烷(PDMS)的摩擦电层与石墨烯增强型导电粘合剂集成,该系统在电性能、柔韧性和耐久性之间实现了稳健平衡。优化的Gr20配方在保持柔韧性的同时实现了低面电阻(约15 Ω/□),台式测试证实其在40 N施加负载下可输出高达37 V的电压。该系统通过定制信号调理电路,实现了六个传感通道的稳定无线传输。尽管纺织集成配置中观察到信号衰减现象(特定布局下衰减达60%),系统性分析揭示了根本原因,并提出电极几何优化与封装技术等实用缓解策略。值得注意的是,该装置不仅作为高保真运动传感器运作,更展现出能量采集能力——在10 N负载下实现约7μW功率输出,为自维持运行开辟了路径。这些突破性进展共同彰显了石墨烯基摩擦电系统在可穿戴医疗、康复治疗及人机交互领域的应用潜力。其可扩展设计为未来智能纺织品提供了多功能平台,为实现自主、节能的生物力学监测开辟了新路径。
文献:
https://doi.org/10.1021/acsaelm.5c01519
来源:材料分析与应用
  • 传感器
  • 石墨烯
  • 运动传感
加入交流群
微信小助手二维码
扫码添加小助手
加入工程师交流群
    热点推荐
    四川大学、香港城市大学:研发一体化自供电可穿戴传感系统,用于模式健康监测
      模态传感器、能量收集和存储模块的集成促进了智能可穿戴电子产品的进步。然而,现有的模块化构建策略集成度较低,导致设备笨重,可能会影响信号采集的稳定性和可靠性。在这里,四川
    的头像 发表于 04-23 19:24 19次阅读
    四川<b class='flag-5'>大学</b>、香港城市<b class='flag-5'>大学</b>:研发一体化<b class='flag-5'>自供电</b>可穿戴<b class='flag-5'>传感</b>系统,<b class='flag-5'>用于</b><b class='flag-5'>多</b>模式健康监测
    重庆大学运动即供能!研发自供能无线传感器
    创新成果。该研究成功开发出一种新型自供能无线传感器,能够将人体手臂运动直接、同步地转化为控制机械臂的无线指令,整个过程中无需电池供电。这为构建下一代低功耗、高自主性的可穿戴人机交互系统
    的头像 发表于 04-03 15:48 1784次阅读
    重庆<b class='flag-5'>大学</b>:<b class='flag-5'>运动</b>即供能!研发<b class='flag-5'>自供</b>能无线<b class='flag-5'>传感器</b>
    ADPD4100/ADPD4101模态传感器前端:功能特点与应用解析
    ADPD4100/ADPD4101模态传感器前端:功能特点与应用解析 一、引言 在电子设计领域,传感器前端的性能对整个系统的表现起着至关重要的作用。ADPD4100/ADPD4101
    的头像 发表于 03-27 14:50 168次阅读
    ADPD4000/ADPD4001:模态传感器前端的卓越之选
    ADPD4000/ADPD4001:模态传感器前端的卓越之选 在当今电子设备日益智能化、多功能化的时代,
    的头像 发表于 03-27 14:45 181次阅读
    ADPD4200 模态传感器前端:功能、应用与设计要点
    ADPD4200 模态传感器前端:功能、应用与设计要点 在当今的电子设计领域,模态传感器前端
    的头像 发表于 03-27 09:35 196次阅读
    ADPD7008 模态传感器前端:特性、应用与设计指南
    ADPD7008 模态传感器前端:特性、应用与设计指南 在当今的电子设备设计中,对于高精度、多功能传感器前端的需求日益增长。ADPD7008 作为一款高度集成的模拟前端(AFE),为
    的头像 发表于 03-25 18:40 600次阅读
    深圳大学:研发用于实时步态分析的摩擦纺织传感器
      摩擦纳米发电机(TENG)因结构简单、小型、轻量化等优势成为可穿戴传感器件的理想选择。基于织物结构的TENG进一步赋予可穿戴器件柔软、舒适特性,为生理信号无创监测提供了新思路。以芯壳结构纱线为
    的头像 发表于 02-10 18:44 192次阅读
    深圳<b class='flag-5'>大学</b>:研发<b class='flag-5'>用于</b>实时步态分析的<b class='flag-5'>摩擦</b><b class='flag-5'>电</b><b class='flag-5'>纺织</b><b class='flag-5'>传感器</b>
    智能运动传感器领域应用的理想之选
    智能运动传感器领域应用的理想之选 在当今科技飞速发展的时代,传感器技术在众多领域发挥着至关重要的作用。今天,我们就来深入了解一下Smar
    的头像 发表于 12-26 09:35 583次阅读
    用于氧化石墨模态表征与激光还原图案化的共聚焦显微技术
    与工艺调控。下文,光子湾科技将详解基于共聚焦显微镜(CLSM)的原位模态表征与激光还原集成方法。#Photonixbay.氧化石墨(GO)薄片的
    的头像 发表于 12-16 18:03 516次阅读
    <b class='flag-5'>用于</b>氧化<b class='flag-5'>石墨</b><b class='flag-5'>烯</b>的<b class='flag-5'>多</b><b class='flag-5'>模态</b>表征与激光还原图案化的共聚焦显微技术
    深圳技术大学:超薄石墨应变传感器阵列,用于毫米级分辨率的高灵敏度多功能传感
    石墨柔性传感器阵列的应用受两大限制制约:现有制备方法难以实现高空间分辨率,且缺乏面向实际应用的系统级集成方案。为应对这些挑战,本文,深圳技术大学贾原 副教授、天津师范
    的头像 发表于 10-11 18:38 5959次阅读
    深圳技术<b class='flag-5'>大学</b>:超薄<b class='flag-5'>石墨</b><b class='flag-5'>烯</b>应变<b class='flag-5'>传感器</b>阵列,<b class='flag-5'>用于</b>毫米级分辨率的高灵敏度多功能<b class='flag-5'>传感</b>
    FiberCircuits 技术白皮书:将电路织入未来智能纺织品
    ,尺寸极小,例如  1.4 毫米宽的 ARM 微控制  和  0.9 毫米宽的传感器 ,从而实现了防水、耐用的交互式纺织品。 ”     引言:下一代可穿戴技术的演进 当前的可穿戴技术市场虽已形成规模,但其产品形态的内在局限性
    的头像 发表于 10-10 11:17 3526次阅读
    FiberCircuits 技术白皮书:将电路织入未来<b class='flag-5'>智能</b><b class='flag-5'>纺织品</b>
    变压振动温度传感器模态监测技术解析与应用展望
    功能,构建起变压健康状态的"立体感知网络",为电力系统的安全稳定运行提供关键技术保障。【模态检测技术原理】传感器采用三参数协同检测方案:声纹监测模块通过麦克风
    的头像 发表于 09-01 13:49 842次阅读
    变压<b class='flag-5'>器</b>振动温度<b class='flag-5'>传感器</b>的<b class='flag-5'>多</b><b class='flag-5'>模态</b>监测技术解析与应用展望
    可穿戴系列之全息无感化健康管理传感器
    监测,彻底消除人为干预需求,实现医疗监测与日常生活的无缝整合。图1人体模态生物信号传感分布图HUIYING可穿戴传感器总结分析穿戴传感器
    的头像 发表于 08-18 20:21 7422次阅读
    可穿戴系列之全息无感化健康管理<b class='flag-5'>传感器</b>
    兰州大学:研究阻抗解耦实现高精度自供传感
    近日,兰州大学材料与能源学院研究团队提出阻抗解耦策略用于提高自供传感系统中的传感精度,实现高精度
    的头像 发表于 07-23 11:26 1401次阅读
    兰州<b class='flag-5'>大学</b>:研究阻抗解耦实现高精度<b class='flag-5'>自供</b>能<b class='flag-5'>多</b>模<b class='flag-5'>传感</b>
    XMOS为普及AI应用推出基于软件定义SoC的模态AI传感器融合接口
    模态传感信号AI处理为智算中心和边缘智能开启感知智能的新篇章
    的头像 发表于 05-12 17:51 634次阅读
    XMOS为普及AI应用推出基于软件定义SoC的<b class='flag-5'>多</b><b class='flag-5'>模态</b>AI<b class='flag-5'>传感器</b>融合接口
