VMWare Linux系统磁盘扩容
当我们在VMware Linux虚拟机安装软件的时候,发现磁盘不够了,可以考虑给磁盘扩容,而不是重建虚拟机。
1. 修改磁盘容量
点击编辑虚拟设置
选择磁盘=》扩展
点击“扩展”
点击确定
2. 添加分区
重新启动系统后,执行以下操作
磁盘分区
[root@oracle ~]# fdisk /dev/sda Welcome to fdisk (util-linux 2.23.2). Changes will remain in memory only, until you decide to write them. Be careful before using the write command. Command (m for help): m Command action a toggle a bootable flag b edit bsd disklabel c toggle the dos compatibility flag d delete a partition g create a new empty GPT partition table G create an IRIX (SGI) partition table l list known partition types m print this menu n add a new partition o create a new empty DOS partition table p print the partition table q quit without saving changes s create a new empty Sun disklabel t change a partition's system id u change display/entry units v verify the partition table w write table to disk and exit x extra functionality (experts only) Command (m for help): n Partition type: p primary (3 primary, 0 extended, 1 free) e extended Select (default e): p Selected partition 4 First sector (41943040-83886079, default 41943040): Using default value 41943040 Last sector, +sectors or +size{K,M,G} (41943040-83886079, default 83886079): Using default value 83886079 Partition 4 of type Linux and of size 20 GiB is set Command (m for help): w The partition table has been altered! Calling ioctl() to re-read partition table. WARNING: Re-reading the partition table failed with error 16: Device or resource busy. The kernel still uses the old table. The new table will be used at the next reboot or after you run partprobe(8) or kpartx(8) Syncing disks.
查看新的磁盘分区类型
[root@oracle ~]# fdisk -l Disk /dev/sda: 42.9 GB, 42949672960 bytes, 83886080 sectors Units = sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 512 bytes I/O size (minimum/optimal): 512 bytes / 512 bytes Disk label type: dos Disk identifier: 0x000a9a6f Device Boot Start End Blocks Id System /dev/sda1 2048 6143 2048 83 Linux /dev/sda2 * 6144 2103295 1048576 83 Linux /dev/sda3 2103296 41943039 19919872 8e Linux LVM /dev/sda4 41943040 83886079 20971520 83 Linux Disk /dev/mapper/centos-root: 19.3 GB, 19323158528 bytes, 37740544 sectors Units = sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 512 bytes I/O size (minimum/optimal): 512 bytes / 512 bytes Disk /dev/mapper/centos-swap: 1073 MB, 1073741824 bytes, 2097152 sectors Units = sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 512 bytes I/O size (minimum/optimal): 512 bytes / 512 bytes
修改磁盘分区类型
通过fdisk -l 查看到/dev/sdb3的分区Id为8e,所以,/dev/vdb4的id也修改与其一致。
[root@oracle ~]# fdisk /dev/sda Welcome to fdisk (util-linux 2.23.2). Changes will remain in memory only, until you decide to write them. Be careful before using the write command. Command (m for help): t Partition number (1-4, default 4): Hex code (type L to list all codes): L 0 Empty 24 NEC DOS 81 Minix / old Lin bf Solaris 1 FAT12 27 Hidden NTFS Win 82 Linux swap / So c1 DRDOS/sec (FAT- 2 XENIX root 39 Plan 9 83 Linux c4 DRDOS/sec (FAT- 3 XENIX usr 3c PartitionMagic 84 OS/2 hidden C: c6 DRDOS/sec (FAT- 4 FAT16 <32M 40 Venix 80286 85 Linux extended c7 Syrinx 5 Extended 41 PPC PReP Boot 86 NTFS volume set da Non-FS data 6 FAT16 42 SFS 87 NTFS volume set db CP/M / CTOS / . 7 HPFS/NTFS/exFAT 4d QNX4.x 88 Linux plaintext de Dell Utility 8 AIX 4e QNX4.x 2nd part 8e Linux LVM df BootIt 9 AIX bootable 4f QNX4.x 3rd part 93 Amoeba e1 DOS access a OS/2 Boot Manag 50 OnTrack DM 94 Amoeba BBT e3 DOS R/O b W95 FAT32 51 OnTrack DM6 Aux 9f BSD/OS e4 SpeedStor c W95 FAT32 (LBA) 52 CP/M a0 IBM Thinkpad hi eb BeOS fs e W95 FAT16 (LBA) 53 OnTrack DM6 Aux a5 FreeBSD ee GPT f W95 Ext'd (LBA) 54 OnTrackDM6 a6 OpenBSD ef EFI (FAT-12/16/ 10 OPUS 55 EZ-Drive a7 NeXTSTEP f0 Linux/PA-RISC b 11 Hidden FAT12 56 Golden Bow a8 Darwin UFS f1 SpeedStor 12 Compaq diagnost 5c Priam Edisk a9 NetBSD f4 SpeedStor 14 Hidden FAT16 <3 61 SpeedStor ab Darwin boot f2 DOS secondary 16 Hidden FAT16 63 GNU HURD or Sys af HFS / HFS+ fb VMware VMFS 17 Hidden HPFS/NTF 64 Novell Netware b7 BSDI fs fc VMware VMKCORE 18 AST SmartSleep 65 Novell Netware b8 BSDI swap fd Linux raid auto 1b Hidden W95 FAT3 70 DiskSecure Mult bb Boot Wizard hid fe LANstep 1c Hidden W95 FAT3 75 PC/IX be Solaris boot ff BBT 1e Hidden W95 FAT1 80 Old Minix Hex code (type L to list all codes): 8e Changed type of partition 'Linux' to 'Linux LVM' Command (m for help): w The partition table has been altered! Calling ioctl() to re-read partition table. WARNING: Re-reading the partition table failed with error 16: Device or resource busy. The kernel still uses the old table. The new table will be used at the next reboot or after you run partprobe(8) or kpartx(8) Syncing disks.
查看修改后分区类型
[root@oracle ~]# fdisk -l Disk /dev/sda: 42.9 GB, 42949672960 bytes, 83886080 sectors Units = sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 512 bytes I/O size (minimum/optimal): 512 bytes / 512 bytes Disk label type: dos Disk identifier: 0x000a9a6f Device Boot Start End Blocks Id System /dev/sda1 2048 6143 2048 83 Linux /dev/sda2 * 6144 2103295 1048576 83 Linux /dev/sda3 2103296 41943039 19919872 8e Linux LVM /dev/sda4 41943040 83886079 20971520 8e Linux LVM Disk /dev/mapper/centos-root: 19.3 GB, 19323158528 bytes, 37740544 sectors Units = sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 512 bytes I/O size (minimum/optimal): 512 bytes / 512 bytes Disk /dev/mapper/centos-swap: 1073 MB, 1073741824 bytes, 2097152 sectors Units = sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 512 bytes I/O size (minimum/optimal): 512 bytes / 512 bytes
磁盘扩容
重启系统后,开始扩充分区
查看磁盘分区卷组
[root@oracle ~]# lvs LV VG Attr LSize Pool Origin Data% Meta% Move Log Cpy%Sync Convert root centos -wi-ao---- <18.00g swap centos -wi-ao---- 1.00g [root@oracle ~]# vgdisplay --- Volume group --- VG Name centos System ID Format lvm2 Metadata Areas 1 Metadata Sequence No 3 VG Access read/write VG Status resizable MAX LV 0 Cur LV 2 Open LV 2 Max PV 0 Cur PV 1 Act PV 1 VG Size <19.00 GiB PE Size 4.00 MiB Total PE 4863 Alloc PE / Size 4863 / <19.00 GiB Free PE / Size 0 / 0 VG UUID gp2KXC-VUTG-0C01-aAed-31UC-HkVO-qi3gus [root@oracle ~]#
扩展逻辑卷
创建物理卷
[root@oracle ~]# pvcreate /dev/sda4 Physical volume "/dev/sda4" successfully created.
如果出现 “Device /dev/sda4 not found."
可以使用partprobe命令使系统获知新的分区表的情况
[root@oracle ~]# partprobe Warning: 无法以读写方式打开 /dev/sr0 (只读文件系统)。/dev/sr0 已按照只读方式打开。 [root@oracle ~]# pvcreate /dev/sda4 Physical volume "/dev/sda4" successfully created.
扩充卷组
[root@oracle ~]# vgextend centos /dev/sda4 Volume group "centos" successfully extended [root@oracle ~]# vgdisplay --- Volume group --- VG Name centos System ID Format lvm2 Metadata Areas 2 Metadata Sequence No 4 VG Access read/write VG Status resizable MAX LV 0 Cur LV 2 Open LV 2 Max PV 0 Cur PV 2 Act PV 2 VG Size 38.99 GiB PE Size 4.00 MiB Total PE 9982 Alloc PE / Size 4863 / <19.00 GiB Free PE / Size 5119 / <20.00 GiB VG UUID gp2KXC-VUTG-0C01-aAed-31UC-HkVO-qi3gus
扩充逻辑卷
[root@oracle ~]# lvextend -l +100%FREE /dev/centos/root /dev/sda4 Size of logical volume centos/root changed from <18.00 GiB (4607 extents) to <36.50 GiB (9343 extents). Logical volume centos/root successfully resized.
修改文件系统大小
查看文件系统类型
[root@oracle ~]# df -Th Filesystem Type Size Used Avail Use% Mounted on /dev/mapper/centos-root xfs 37G 14G 24G 37% / devtmpfs devtmpfs 898M 0 898M 0% /dev tmpfs tmpfs 910M 0 910M 0% /dev/shm tmpfs tmpfs 910M 9.6M 901M 2% /run tmpfs tmpfs 910M 0 910M 0% /sys/fs/cgroup /dev/sda2 xfs 1014M 148M 867M 15% /boot tmpfs tmpfs 182M 0 182M 0% /run/user/0
修改文件系统大小
[root@oracle ~]# xfs_growfs /dev/mapper/centos-root
meta-data=/dev/mapper/centos-root isize=512 agcount=4, agsize=1179392 blks
= sectsz=512 attr=2, projid32bit=1
= crc=1 finobt=0 spinodes=0
data = bsize=4096 blocks=4717568, imaxpct=25
= sunit=0 swidth=0 blks
naming =version 2 bsize=4096 ascii-ci=0 ftype=1
log =internal bsize=4096 blocks=2560, version=2
= sectsz=512 sunit=0 blks, lazy-count=1
realtime =none extsz=4096 blocks=0, rtextents=0
data blocks changed from 4717568 to 9567232
注:如果文件系统是ext4,使用resize2fs修改文件系统大小。
扩容完毕!
本文来自博客园,作者:何以卿卿
链接:https://www.cnblogs.com/shiqiang-lee/p/16885421.html
Linux系统
4文章
618浏览量
30242 -
磁盘
1文章
403浏览量
26625 -
VMware
1文章
301浏览量
23233
原文标题:Linux系统磁盘扩容
文章出处:【微信号:magedu-Linux,微信公众号:马哥Linux运维】欢迎添加关注!文章转载请注明出处。
安装VMWARE+LINUX开发平台
【OK210试用体验】之VMware下Ubuntu磁盘空间扩容
【OK210试用体验】之疑惑VMware下Ubuntu扩展磁盘容量后无法启动
【我们一起学Linux之准备篇】善用佳软Vmware安装Linux系统
【昉·星光 2 高性能RISC-V单板计算机体验】三:从 nvme 磁盘启动 VisionFive2 并对磁盘分区扩容
Linux中的可用磁盘空间如何检查?
你会用VMware虚拟机安装Linux系统?
查看linux系统磁盘io情况的办法是什么
如何释放VMware虚拟磁盘未使用空间呢?
VMWare Linux系统磁盘扩容
