自定义弹窗其实也是比较简单的,通过CustomDialogController类就可以显示自定义弹窗。
接下来我们通过代码来看一下
大家也都用过@Entry,@Component等弹窗的话,只要用@CustomDialog就可以
先来预览一下我实现的效果:
import
CustomDialogExample
from
'./customdialog'
Entry
Component
struct
Index
// 方式一:使用箭头函数
onAccept
console
info
'确定'
this
dialogController
close
dialogController
new
builder
CustomDialogExample
cancel
this
onCancel
confirm
this
onAccept
alignment
DialogAlignment
Center
cancel
console
log
"cancel"
// 点击蒙层的回调
autoCancel
true
// 允许点击蒙层关闭弹窗
customStyle
false
// 使用自定义样式
onCancel
console
info
'取消'
build
Column
Button
' 自定义弹窗'
onClick
//打开弹窗
this
dialogController
open
width
"100%"
height
"100%"
alignItems
HorizontalAlign
Center
justifyContent
FlexAlign
Center
* Copyright (c) 2021 JianGuo Device Co., Ltd.
* Licensed under the Apache License, Version 2.0 (the "License");
* you may not use this file except in compliance with the License.
* You may obtain a copy of the License at
* http://www.apache.org/licenses/LICENSE-2.0
* Unless required by applicable law or agreed to in writing, software
* distributed under the License is distributed on an "AS IS" BASIS,
* WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
* See the License for the specific language governing permissions and
* limitations under the License.
//通过CustomDialogController类显示自定义弹窗。
CustomDialog
struct
CustomDialogExample
controller
cancel
void
confirm
void
build
Flex
justifyContent
FlexAlign
Center
alignItems
ItemAlign
Center
alignContent
FlexAlign
Center
Button
'取消'
fontSize
36
onClick
//方式二:关闭弹窗
this
controller
close
this
cancel
0xffffff
fontColor
Color
Black
Button
'确定'
fontSize
36
onClick
// this.controller.close()
this
confirm
backgroundColor
0xffffff
fontColor
Color
Red
margin
bottom
10
width
"100%"
height
200
export
default
CustomDialogExample
上面就是一个简单的自定义弹窗
接下来看一下它的有关属性
CustomDialogController 定义了 open() 和 close() 方法,它们说明如下:
open:打开对话框,如果对话框已经打开,则再次打开无效。
close:关闭对话框,如果对话框已经关闭,则再次关闭无效。
value:创建控制器需要的配置参数,
- CustomDialogControllerOptions
说明如下:
builder:创建自定义弹窗的构造器。
cancel:点击蒙层的事件回调。
autoCancel:是否允许点击遮障层退出。
alignment:弹窗在竖直方向上的对齐方式。
offset:弹窗相对 alignment 所在位置的偏移量。
customStyle:弹窗容器样式是否自定义。
源码
declare interface CustomDialogControllerOptions {
* Custom builder function.
* @since 7
builder: any;
* Defines the cancel function.
* @since 7
cancel?: () => void;
* Defines if use auto cancel when click on the outside of the dialog.
* @since 7
autoCancel?: boolean;
* Defines the dialog alignment of the screen.
* @since 7
alignment?: DialogAlignment;
* Defines the dialog offset.
* @since 7
offset?: Offset;
* Defines if use costom style.
* @since 7
customStyle?: boolean;
* Grid count of dialog.
* @since 8
gridCount?: number;
DialogAlignment的位置
| 名称 | 描述 |
| Top | 垂直顶部对齐。 |
| Center | 垂直居中对齐。 |
| Bottom | 垂直底部对齐。 |
| Default | 默认对齐。 |
| TopStart8+ | 左上对齐。 |
| TopEnd8+ | 右上对齐。 |
| CenterStart8+ | 左中对齐。 |
| CenterEnd8+ | 右中对齐。 |
| BottomStart8+ | 左下对齐。 |
| BottomEnd8+ | 右下对齐。 |
参考文档
自定义弹窗
语法糖
Component
13浏览量
9178 -
OpenHarmony
33文章
3971浏览量
21341
HarmonyOS应用自定义键盘解决方案
OpenHarmony应用开发之自定义弹窗
自定义视图组件教程案例
自定义算子开发
ArkUI如何自定义弹窗(eTS)
