怎样将Arduino数据直接存储到MySQL
454398 来源:网络整理 作者:网络整理 2019-11-20 17:08 次阅读
加入交流群
微信小助手二维码
扫码添加小助手
加入工程师交流群
步骤1:设置Arduino
刻录以下内容
void setup()
Serial.begin(9600);
void loop()
int i=0,j=0;
i=analogRead(A0);
j=analogRead(A1);
Serial.print(i);
Serial.print(“,”);
Serial.println(i);
步骤2:设置启动MySQL
为MySQL安装Wamp服务器并将其配置为存储数据
运行wamp服务器
打开MySQL控制台
选择数据库
然后为您的数据创建表
create table data(sno int(4) primary key auto_increment,LDR int(4),TEMP int(4));
使用desc your_table_name显示表详细信息
desc data;
这就是数据库的全部内容,现在我们可以进行处理了……
第3步:设置处理IDE
下载并安装Processing IDE 2.2.1
将上述给定的ZIP压缩到MyDocuments/Processing/Libraries中
现在打开正在处理的IDE和检查库是否已正确安装(如上图所示)
然后将以下代码复制并进行处理,并自行命名
ARDUINO TO MYSQL THROUGH PROCESSING
Read Serial messages from Arduino then write it in MySQL.
Author : J.V.JohnsonSelva September 2016
import de.bezier.data.sql.*; //import the MySQL library
import processing.serial.*; //import the Serial library
MySQL msql; //Create MySQL Object
String[] a;
int end = 10; // the number 10 is ASCII for linefeed (end of serial.println), later we will look for this to break up individual messages
String serial; // declare a new string called ‘serial’ 。 A string is a sequence of characters (data type know as “char”)
Serial port; // The serial port, this is a new instance of the Serial class (an Object)
void setup() {
String user = “root”;
String pass = “”;
String database = “iot_database”;
msql = new MySQL( this, “localhost”, database, user, pass );
port = new Serial(this, Serial.list()[0], 9600); // initializing the object by assigning a port and baud rate (must match that of Arduino)
port.clear(); // function from serial library that throws out the first reading, in case we started reading in the middle of a string from Arduino
serial = port.readStringUntil(end); // function that reads the string from serial port until a println and then assigns string to our string variable (called ‘serial’)
serial = null; // initially, the string will be null (empty)
void draw()
while (port.available() 》 0)
//as long as there is data coming from serial port, read it and store it
if (serial != null)
//if the string is not empty, print the following
//Note: the split function used below is not necessary if sending only a single variable. However, it is useful for parsing (separating) messages when
//reading from multiple inputs in Arduino. Below is example code for an Arduino sketch
a = split(serial, ‘,’); //a new array (called ‘a’) that stores values into separate cells (separated by commas specified in your Arduino program
println(a[0]); //print LDR value
println(a[1]); //print LM35 value
function();
void function()
if ( msql.connect() )
msql.query( “insert into data(LDR,Temp)values(”+a[0]+“,”+a[1]+“)” );
else
// connection failed !
msql.close(); //Must close MySQL connection after Execution
第4步:执行程序。
通过单击“运行”按钮运行程序,请关闭弹出窗口。关闭窗口将停止执行,并在下面的查询中查看在MySQL中存储数据。..
select * from data;
查看数据插入器的数量可以使用下面的查询。
select count(*) from data;
责任编辑:wv
  • MySQL
  • Arduino
加入交流群
微信小助手二维码
扫码添加小助手
加入工程师交流群
    热点推荐
    从业务库实时分析库,NineData 构建 MySQLSelectDB 同步链路
    MySQL SelectDB,难点从来不是“把数据搬过去”,而是把这件事做成一条真正可靠的生产链路。 NineData 在这个场景里的价值,不只是提供了一条复制通道,而是把任务创建、实时复制
    的头像 发表于 03-31 12:54 542次阅读
    从业务库<b class='flag-5'>到</b>实时分析库,NineData 构建 <b class='flag-5'>MySQL</b><b class='flag-5'>到</b>SelectDB 同步链路
    NineData 新增支持 MySQL openGauss PostgreSQL 数据复制链路
    MySQL openGauss PostgreSQL 兼容版的迁移,真正难的从来不是“把数据搬过去”,而是如何在业务不停、数据持续变化、结果需要验证、问题需要及时发现的前提下,把整
    的头像 发表于 03-19 11:44 204次阅读
    NineData 新增支持 <b class='flag-5'>MySQL</b> <b class='flag-5'>到</b> openGauss PostgreSQL <b class='flag-5'>数据</b>复制链路
    恒讯科技解析:如何安装MySQL并创建数据
    库管理系统(RDBMS),使用结构化查询语言(SQL)高效地组织和管理数据。它是全球最受欢迎的开源数据库系统之一,广泛应用于网页开发、电子商务和商业应用。 常见用例  MySQL 是多种应用的可靠选择,包括: 网络应用:管理用户
    的头像 发表于 01-14 14:25 377次阅读
    工业数据中台支持接入MySQL数据库吗
    工业数据中台完全支持接入MySQL数据库 ,且通过数据同步、集成与治理等技术手段,能够充分发挥MySQL
    的头像 发表于 12-04 11:23 510次阅读
    工业<b class='flag-5'>数据</b>中台支持接入<b class='flag-5'>MySQL</b><b class='flag-5'>数据</b>库吗
    mysql数据恢复—mysql数据库表被truncate的数据恢复案例
    某云ECS网站服务器,linux操作系统,部署了mysql数据库。工作人员在执行数据库版本更新测试时,错误地本应在测试库执行的sql脚本在生产库上执行了,导致部分表被truncate
    的头像 发表于 09-11 09:28 1193次阅读
    <b class='flag-5'>mysql</b><b class='flag-5'>数据</b>恢复—<b class='flag-5'>mysql</b><b class='flag-5'>数据</b>库表被truncate的<b class='flag-5'>数据</b>恢复案例
    如何触摸校准存储 SPI 闪存?
    触摸校准存储 SPI 闪存
    发表于 09-04 07:06
    MySQL数据备份与恢复策略
    数据是企业的核心资产,MySQL作为主流的关系型数据库管理系统,其数据的安全性和可靠性至关重要。本文深入探讨
    的头像 发表于 07-14 11:11 891次阅读
    企业级MySQL数据库管理指南
    在当今数字化时代,MySQL作为全球最受欢迎的开源关系型数据库,承载着企业核心业务数据存储与处理。作为数据库管理员(DBA),掌握
    的头像 发表于 07-09 09:50 899次阅读
    远程访问内网MySQL数据库?这个方案更简单
    各位开发者朋友们,是否还在为无法随时随地访问内网MySQL数据库而烦恼?今天分享一个超实用的方法,通过容器部署 MySQL 结合 ZeroNews 内网穿透,让你在任何地方都能安全访问和管理
    的头像 发表于 07-04 18:06 1013次阅读
    远程访问内网<b class='flag-5'>MySQL</b><b class='flag-5'>数据</b>库?这个方案更简单
    忆联 Docker+MySQL 流控方案:打造安全高效存储底座,释放 AI 极致性能
    探讨基于Docker部署的MySQL数据库在AI应用中的关键作用。通过忆联PCIe5.0企业级SSD(UH812a)实测验证,展示了Namespace技术与QoS优化策略如何实现存储资源的精细化管理
    的头像 发表于 06-26 13:53 580次阅读
    忆联 Docker+<b class='flag-5'>MySQL</b> 流控方案:打造安全高效<b class='flag-5'>存储</b>底座,释放 AI 极致性能
    MySQL数据库采集网关是什么?有什么功能?
    MySQL数据库采集网关是一种用于连接、采集、处理并传输数据MySQL数据库的中间设备或软件系
    的头像 发表于 05-26 15:20 826次阅读
    PLC数据中台对接到MySQL数据库并对接到生产看板
    工厂数据库系统能够存储产品订单信息、生产设备能力、原材料库存等数据这些数据接入MES或ERP等系统,能够实现生产管理的可视化应用。基于这
    的头像 发表于 05-26 11:20 664次阅读
    PLC<b class='flag-5'>数据</b>中台对接到<b class='flag-5'>MySQL</b><b class='flag-5'>数据</b>库并对接到生产看板
    MySQL数据库是什么
    MySQL数据库是一种 开源的关系型数据库管理系统(RDBMS) ,由瑞典MySQL AB公司开发,后被Oracle公司收购。它通过结构化查询语言(SQL)进行
    的头像 发表于 05-23 09:18 1456次阅读
    利用dockerfile搭建mysql主从集群和redis集群
    ==MySQL主从同步(Replication)是一种实现数据冗余和高可用性的技术,通过数据库(Master)的变更操作同步一个或多个
    的头像 发表于 05-14 11:38 3672次阅读
    利用dockerfile搭建<b class='flag-5'>mysql</b>主从集群和redis集群
    数据采集MYSQL和SQLSERVER数据库可以实现哪些功能
    ,确保企业各项数据资产得到合理存储与管理,方便随时调取、搜索,有助于提升管理水平与工作效率。 1.实时监控与预警​ 通过生产设备数据采集
    的头像 发表于 05-07 15:32 688次阅读
