LF147QML 宽带四路JFET输入运算放大器
数据:
产品信息
描述 The LF147 is a low cost, high speed quad JFET input operational amplifier with an internally trimmed input offset voltage (BI-FET II technology). The device requires a low supply current and yet maintains a large gain bandwidth product and a fast slew rate. In addition, well matched high voltage JFET input devices provide very low input bias and offset currents. The LF147 is pin compatible with the standard LM148. This feature allows designers to immediately upgrade the overall performance of existing LF148 and LM124 designs.The LF147 may be used in applications such as high speed integrators, fast D/A converters, sample-and-hold circuits and many other circuits requiring low input offset voltage, low input bias current, high input impedance, high slew rate and wide bandwidth. The device has low noise and offset voltage drift.特性Internally Trimmed Offset Voltage: 5 mV Max Low Input Bias Current: 50 pA Typ. Low Input Noise Current: 0.01 pA/√Hz Typ. Wide Gain Bandwidth: 4 MHz Typ. High Slew Rate: 13 V/μs Typ. Low Supply Current: 7.2 mA Typ. High Input Impedance: 1012Ω Typ. Low Total Harmonic Distortion: AV= 10, RL = 10KΩ, VO = 20VP-P   BW = 20Hz – 20KHz ≤0.02% Typ.Low 1/f Noise Corner: 50 Hz Typ. Fast Settling Time to 0.01%: 2 μs Typ. All trademarks are the property of their respective owners.
电路图、引脚图和封装图
技术文档
数据手册(1)
元器件购买 LF147QML 相关库存
相关阅读
