INA199-Q1系列属于电压输出,电流感测放大器,可感测分流电阻在-0.3V至26V共模电压范围内的压降,与电源电压无关。共有3种固定增益可供选用:50V /V,100V /V和200V /V.该系列器件采用零漂移架构,偏移较低,因此在进行电流感测能能够分流电阻两端的最大压降保持在10mV满量程以下。
该系列器件可由电压为2.7V至26V的单电源供电,最大电源流耗为100μA。所有版本器件的额定工作温度范围为-40°C至125°C,并且采用6引脚的SC70封装。
< /p>
所有商标均为其各自所有者的财产。
| Common Mode Voltage (Max) (V) |
| Common Mode Voltage (Min) (V) |
| Input Offset (+/-) (Max) (uV) |
| Input Offset Drift (+/-) (Typ) (uV/C) |
| Gain (V/V) |
| Gain Error (%) |
| Gain Error Drift (Max) (ppm/°C) |
| CMRR (Min) (dB) |
| Bandwidth (kHz) |
| Supply Voltage (Max) (V) |
| Supply Voltage (Min) (V) |
| Iq (Max) (mA) |
| Number of Channels (#) |
| Features |
| Rating |
| Operating Temperature Range (C) |
| Package Group |
| Package Size: mm2:W x L (PKG) |
| INA199-Q1 | INA210-Q1 |
| 26 | 26 |
| -0.3 | -0.3 |
| 150 | 35 60 100 |
| 0.1 | 0.1 |
| 100 200 50 | 100 1000 200 50 500 75 |
| 1.5 | 1 |
| 10 | 10 |
| 100 | 105 |
| 80 30 14 | 80 40 30 14 7 4 |
| 26 | 26 |
| 2.7 | 2.7 |
| 0.115 | 0.115 |
| 1 | 1 |
| Bi-directional Low-side Capable | Bi-directional Low-side Capable |
| Automotive | Automotive |
| -40 to 125 | -40 to 125 |
| SC70 | SC70 |
| 6SC70: 4 mm2: 2.1 x 2(SC70) | 6SC70: 4 mm2: 2.1 x 2(SC70) |
