TLV3541,TLV3542和TLV3544分别为单通道,双通道和四通道低功耗(每通道电流为5.2mA),高速,单位增益稳定的轨道到轨输入/输出运算放大器,设计用于所需带宽较宽的视频及其他应用。
此类器件仅消耗6.5mA(最大值)电源电流,增益带宽为200MHz,转换率为150V /μs,f = 1MHz时的低噪声输入为7.5nV /√ Hz 。凭借这种高带宽,高转换率和低噪声特性组合,TLV354x系列器件适用于低压高速信号调节系统。
TLV354x系列运算放大器经过优化,适用于2.5V(±1.25V)至5.5V(±2.75V)范围内的单电源或双电源操作。共模输入范围超出电源供电范围。输出摆幅处于100mV电压轨范围内,支持的动态范围较宽。
TLV354x器件的额定工作温度范围为-40°C至+ 125°C.TLV354x系列器件可用作多种经济型宽带宽运算放<大p的插入式替换件。
所有商标均为其各自所有者的财产。
| Architecture |
| Number of Channels (#) |
| Total Supply Voltage (Min) (+5V=5, +/-5V=10) |
| Total Supply Voltage (Max) (+5V=5, +/-5V=10) |
| BW @ Acl (MHz) |
| Slew Rate (Typ) (V/us) |
| Vn at Flatband (Typ) (nV/rtHz) |
| Vn at 1kHz (Typ) (nV/rtHz) |
| Iq per channel (Typ) (mA) |
| Vos (Offset Voltage @ 25C) (Max) (mV) |
| Rail-to-Rail |
| Features |
| Rating |
| Operating Temperature Range (C) |
| Package Group |
| Package Size: mm2:W x L (PKG) |
| CMRR (Typ) (dB) |
| Input Bias Current (Max) (pA) |
| Offset Drift (Typ) (uV/C) |
| GBW (Typ) (MHz) |
| Output Current (Typ) (mA) |
| 2nd Harmonic (dBc) |
| 3rd Harmonic (dBc) |
| @ MHz |
| TLV3544 | TLV3541 | TLV3542 |
| CMOS | CMOS | CMOS |
| 4 | 1 | 2 |
| 2.5 | 2.5 | 2.5 |
| 5.5 | 5.5 | 5.5 |
| 200 | ||
| 150 | 150 | 150 |
| 7.5 | 7.5 | 7.5 |
| 7.5 | 7.5 | 7.5 |
| 5.2 | 5.2 | 5.2 |
| 10 | 10 | 10 |
| In Out | In Out | In Out |
| Cost Optimized EMI Hardened | Cost Optimized EMI Hardened | Cost Optimized EMI Hardened |
| Catalog | Catalog | Catalog |
| -40 to 125 | -40 to 125 | -40 to 125 |
| SOIC TSSOP | SOIC SOT-23 | SOIC VSSOP |
| 14SOIC: 52 mm2: 6 x 8.65(SOIC) 14TSSOP: 32 mm2: 6.4 x 5(TSSOP) | 8SOIC: 29 mm2: 6 x 4.9(SOIC) 5SOT-23: 8 mm2: 2.8 x 2.9(SOT-23) | 8SOIC: 29 mm2: 6 x 4.9(SOIC) 8VSSOP: 15 mm2: 4.9 x 3(VSSOP) |
| 80 | 80 | 80 |
| 3 | 3 | 3 |
| 4.5 | 4.5 | 4.5 |
| 200 | 200 | 200 |
| 100 | 100 | 100 |
| -75 | -75 | -75 |
| -83 | -83 | -83 |
| 1 | 1 | 1 |
