THS4541是一款低功耗,电压反馈,全差动放大器(FDA),输入共模范围低于负轨和轨道到轨输出。专为低功耗数据采集系统而设计,其中高密度对于高性能模数转换器(ADC)或数模转换器(DAC)接口设计至关重要。
THS4541功能连接直流耦合,以地为中心的源信号时所需的负轨输入。这种负轨输入具有轨到轨输出,允许单端,接地参考双极信号源与各种SAR,ΔΣ或流水线ADC之间的接口,只需一个+ 2.7V至+ 5.4V电源。
THS4541的工作温度范围为-40°C至125°C,采用16引脚VQFN和10引脚WQFN封装。
| Architecture |
| Number of Channels (#) |
| Total Supply Voltage (Min) (+5V=5, +/-5V=10) |
| Total Supply Voltage (Max) (+5V=5, +/-5V=10) |
| BW @ Acl (MHz) |
| Acl, min spec gain (V/V) |
| Slew Rate (Typ) (V/us) |
| Vn at Flatband (Typ) (nV/rtHz) |
| Vn at 1kHz (Typ) (nV/rtHz) |
| Iq per channel (Typ) (mA) |
| Vos (Offset Voltage @ 25C) (Max) (mV) |
| Rail-to-Rail |
| Features |
| Rating |
| Operating Temperature Range (C) |
| Package Group |
| Package Size: mm2:W x L (PKG) |
| CMRR (Typ) (dB) |
| Input Bias Current (Max) (pA) |
| Offset Drift (Typ) (uV/C) |
| GBW (Typ) (MHz) |
| Output Current (Typ) (mA) |
| 2nd Harmonic (dBc) |
| 3rd Harmonic (dBc) |
| @ MHz |
| THS4541 | THS4524 | THS4531A | THS4551 | THS4552 | THS4561 |
| Fully Differential Voltage FB | Fully Differential Voltage FB | Fully Differential Voltage FB | Bipolar Fully Differential Voltage FB | Bipolar Fully Differential Voltage FB | Fully Differential |
| 1 | 4 | 1 | 1 | 2 | 1 |
| 2.7 | 2.5 | 2.5 | 2.7 | 2.7 | 2.85 |
| 5.4 | 5.5 | 5.5 | 5.4 | 5.4 | 12.6 |
| 620 | 145 | 36 | 150 | 150 | 70 |
| 1 | 1 | 1 | 1 | 1 | 1 |
| 1500 | 490 | 220 | 220 | 220 | 130 |
| 2.2 | 4.6 | 10 | 3.3 | 3.3 | 5 |
| 33 | 5.2 | 10 | 3.3 | 3.3 | 5 |
| 10.1 | 1.14 | 0.25 | 1.35 | 1.37 | 0.82 |
| 0.45 | 2 | 0.4 | 0.175 | 0.265 | 0.2 |
| In to V- Out | In to V- Out | In to V- Out | In to V- Out | In to V- Out | In to V- Out |
| Small Size Shutdown | Shutdown | Small Size Shutdown | Small Size Shutdown | Shutdown | Shutdown |
| Catalog | Catalog | Catalog | Catalog | Catalog | Catalog |
| -40 to 125 | -40 to 85 | -40 to 125 | -40 to 125 | -40 to 125 | -40 to 125 |
| QFN VQFN | TSSOP | QFN SOIC VSSOP | QFN VQFN VSSOP | TSSOP WQFN | VQFN VSSOP |
| 10QFN: 4 mm2: 2 x 2(QFN) 16VQFN: 9 mm2: 3 x 3(VQFN) | 38TSSOP: 62 mm2: 6.4 x 9.7(TSSOP) | 10QFN: 4 mm2: 2 x 2(QFN) 8SOIC: 29 mm2: 6 x 4.9(SOIC) 8VSSOP: 15 mm2: 4.9 x 3(VSSOP) | 10QFN: 4 mm2: 2 x 2(QFN) 16VQFN: 9 mm2: 3 x 3(VQFN) 8VSSOP: 15 mm2: 4.9 x 3(VSSOP) | 16TSSOP: 32 mm2: 6.4 x 5(TSSOP) 24WQFN: 16 mm2: 4 x 4(WQFN) | 16VQFN: 9 mm2: 3 x 3(VQFN) 8VSSOP: 15 mm2: 4.9 x 3(VSSOP) |
| 100 | 102 | 116 | 110 | 110 | 110 |
| 13000000 | 900000 | 250000 | 1500000 | 1500000 | 200000 |
| 0.5 | 2 | 3 | 0.45 | 0.45 | 0.3 |
| 850 | 95 | 27 | 135 | 135 | 60 |
| 100 | 55 | 26 | 45 | 65 | 35 |
| 140 | 133 | 129 | 128 | 128 | 110 |
| 140 | 141 | 138 | 139 | 139 | 115 |
| 0.1 | 0.001 | 0.001 | 0.1 | 0.1 | |
