数据: OPAx354-Q1 250-MHz, Rail-to-Rail I/O, CMOS Operational Amplifiers 数据表
OPAx354-Q1系列高速电压反馈CMOS运算放大器的设计适用于需要宽带宽的视频和其他应用。这些器件的单位增益稳定,可以驱动大输出电流。差分增益为0.02%,差分相位为0.09°。每通道静态电流仅为4.9 mA。
OPAx354-Q1系列运算放大器(运算放大器)经过优化,可在低至2.5 V(±1.25 V)的单电源或双电源上工作,最高可达5.5 V(±2.75 V)。共模输入范围超出了电源。输出摆幅在轨道的100 mV范围内,支持宽动态范围。
单电源版本(OPA354A-Q1)采用小型SOT-23-5(DBV)封装。供应版本(OPA2354A-Q1)采用微型VSSOP-8(DGK)封装,具有完全独立的电路,可实现最低串扰和无交互。二极管电源版本(OPA4354-Q1)采用TSSOP-14(PW)封装。器件规范适用于-40°C至+ 125°C的汽车温度范围。
所有tra demarks是其各自所有者的财产。
| Architecture |
| Number of Channels (#) |
| Total Supply Voltage (Min) (+5V=5, +/-5V=10) |
| Total Supply Voltage (Max) (+5V=5, +/-5V=10) |
| BW @ Acl (MHz) |
| Acl, min spec gain (V/V) |
| Slew Rate (Typ) (V/us) |
| Vn at Flatband (Typ) (nV/rtHz) |
| Vn at 1kHz (Typ) (nV/rtHz) |
| Iq per channel (Typ) (mA) |
| Vos (Offset Voltage @ 25C) (Max) (mV) |
| Rail-to-Rail |
| Features |
| Rating |
| Operating Temperature Range (C) |
| Package Group |
| Package Size: mm2:W x L (PKG) |
| CMRR (Typ) (dB) |
| Input Bias Current (Max) (pA) |
| Offset Drift (Typ) (uV/C) |
| GBW (Typ) (MHz) |
| Output Current (Typ) (mA) |
| 2nd Harmonic (dBc) |
| 3rd Harmonic (dBc) |
| @ MHz |
| OPA2354A-Q1 | OPA354A-Q1 | OPA4354-Q1 |
| CMOS Voltage FB | CMOS Voltage FB | CMOS Voltage FB |
| 2 | 1 | 4 |
| 2.5 | 2.5 | 2.5 |
| 5.5 | 5.5 | 5.5 |
| 250 | 250 | 250 |
| 1 | 1 | 1 |
| 150 | 150 | 150 |
| 6.5 | 6.5 | 6.5 |
| 6.5 | 6.5 | 6.5 |
| 4.9 | 4.9 | 4.9 |
| 8 | 8 | 8 |
| In Out | In Out | In Out |
| N/A | N/A | |
| Automotive | Automotive | Automotive |
| -40 to 125 | -40 to 125 | -40 to 125 |
| VSSOP | SOT-23 | TSSOP |
| 8VSSOP: 15 mm2: 4.9 x 3(VSSOP) | 5SOT-23: 8 mm2: 2.8 x 2.9(SOT-23) | 14TSSOP: 32 mm2: 6.4 x 5(TSSOP) |
| 80 | 80 | 80 |
| 10000 | 50000 | 50 |
| 4 | 4 | 4 |
| 250 | 250 | 250 |
| 100 | 100 | 100 |
| 75 | 75 | 75 |
| 83 | 83 | 83 |
| 1 | 1 | 1 |
