SN74CBT16209A 18 位 FET 总线交换开关
数据:
SN54CBT16209和SN74CBT16209A器件提供18位高速TTL兼容总线切换或交换。开关的低导通状态电阻允许以最小的传播延迟进行连接。
器件作为18位总线开关或9位总线交换器运行,提供数据交换。四个信号端口通过数据选择(S0,S1,S2)端子。
特性
  • Members of the Texas Instruments Widebus™ Family
  • 5- Switch Connection Between Two Ports
  • TTL-Compatible Input Levels
Widebus is a trademark of Texas Instruments.
参数 与其它产品相比 模拟开关/多路复用器
Configuration
Number of Channels (#)
Power Supply Type
Vss (Min) (V)
Vss (Max) (V)
Vdd (Min) (V)
Vdd (Max) (V)
Ron (Typ) (Ohms)
Bandwidth (MHz)
Rating
Operating Temperature Range (C)
Package Size: mm2:W x L (PKG)
Package Group
Supply Range (Max)
Ron (Max) (Ohms)
Input/Output Continuous Current (Max) (mA)
Supply Current (Max) (uA)
OFF-state leakage current (Max) (µA)
ON-state leakage current (Max) (µA)
Input/Output OFF-state Capacitance (Typ) (pF)
VIL (Max) (V)
VIH (Min) (V)
SN74CBT16209A
crosspoint/exchange
18
Single
N/A
N/A
4
5.5
4
200
Catalog
-40 to 85
48SSOP: 164 mm2: 10.35 x 15.88(SSOP)
48TSSOP: 101 mm2: 8.1 x 12.5(TSSOP)
48TVSOP: 62 mm2: 6.4 x 9.7(TVSOP)
SSOP
TSSOP
TVSOP
5.5
3
1
1
7.5
0.8
2
技术文档
数据手册(1)
元器件购买 SN74CBT16209A 相关库存
