采用Harris高级CMOS逻辑技术的CD74AC251和CD74ACT251 8输入多路复用器。该多路复用器具有真(Y)和补(Y)输出以及输出使能(OE \)输入。 OE必须处于低逻辑电平才能启用此设备。当OE \输入为高电平时,两个输出都处于高阻态。启用后,数据选择输入的地址信息将确定哪个数据输入路由到Y和Y \输出。
传输线FAST ??是飞兆半导体的商标。
| Function |
| Technology Family |
| VCC (Min) (V) |
| VCC (Max) (V) |
| Channels (#) |
| Voltage (Nom) (V) |
| F @ Nom Voltage (Max) (Mhz) |
| ICC @ Nom Voltage (Max) (mA) |
| tpd @ Nom Voltage (Max) (ns) |
| Configuration |
| Type |
| IOL (Max) (mA) |
| IOH (Max) (mA) |
| Rating |
| Operating Temperature Range (C) |
| Package Group |
| Package Size: mm2:W x L (PKG) |
| Bits (#) |
| Digital input leakage (Max) (uA) |
| ESD Charged Device Model (kV) |
| ESD HBM (kV) |
| CD74AC251 |
| Encoder Multiplexer |
| AC |
| 1.5 |
| 5.5 |
| 1 |
| 1.5 3.3 5 |
| 100 |
| 0.08 |
| 153 17.2 12.3 |
| 8:1 |
| 3-State Output |
| 24 |
| -24 |
| Catalog |
| -55 to 125 |
| SOIC |
| 16SOIC: 59 mm2: 6 x 9.9(SOIC) |
| 8 |
| 5 |
| 0.75 |
| 2 |
