SCP-LT8609S-BEVALZ SCP-LT8609S-BEVALZ评估板
数据:
scp-lt8609s-bevalz SCP-LT8609S-BEVALZ LT8609S Signal Chain Evaluation Board | Synchronous Buck Converter Demonstration circuit SCP-LT8609S-BEVALZ is a 42V, 2A/3A peak micropower synchronous step-down regula-tor featuring the LT8609S. The demo board is configured for a 5V output from a 5.5V to 42V input.
Like all boards in the Signal Chain Power series, this board is designed to be easily plugged into other SCP boards to form a complete signal chain power system, enabling fast evaluation of low power signal chains. To evaluate this board, some universal SCP hardware is required, namely:
SCP-INPUT-EVALZ
SCP-OUTPUT-EVALZ
SCP-FILTER-EVALZ
SCP-THRUBRD-EVALZ
SCP-1X2BKOUT-EVALZ
SCP-1X5BKOUT-EVALZ
SCP-5X1-EVALZ
To properly evaluate SCP series demo boards, you will need the SCP Configurator companion software. SCP Configurator can help you choose the right board and topology for your design.
Note that the Demo Manual does not cover details important to the operation and configuration regarding the LT8609S. Please refer to the LT8609S datasheet for a complete description of the part. SCP-LT8609S-BEVALZ
技术文档
数据手册(0)
元器件购买
SCP-LT8609S-BEVALZ 相关库存
型号:JY-SCP-5-1+
封装:SMD-8P
品牌:JieYing
描述:替代SCP-5-1+ 通道数5 最小频率2MHz 最大频率200MHz 隔离29dB 插入损耗0.3dB 相位不平衡3 幅度不平衡0.3dB 最大输入功率1W 阻抗50
