NHD - 0216K1Z - FSW - FBW - L字符液晶显示模块技术解析
一、产品概述
NHD - 0216K1Z - FSW - FBW - L是Newhaven Display International, Inc.生产的一款字符液晶显示模块。它具有2行16字符的显示能力,内置ST7066U控制器,采用+5.0V电源供电,具备1/16 duty、1/5 bias的特性,并且符合RoHS标准。
文件下载:NHD-0216K1Z-FSW-FBW-L.pdf
二、模块特性
2.1 功能特点
- 显示能力:能够清晰显示2行16个字符,满足基本的信息展示需求。
- 内置控制器:ST7066U控制器集成度高,方便开发人员进行控制和驱动。
- 电源与参数:+5.0V电源供电,1/16 duty和1/5 bias的设置确保了稳定的显示效果。
- 环保标准:符合RoHS标准,符合环保要求。
2.2 引脚描述
| Pin No. | Symbol | External Connection | Function Description |
| 1 | VSS | Power Supply | Ground |
| 2 | VDD | Power Supply | Supply Voltage for logic (+5.0V) |
| 3 | V0 | Adj Power Supply | Supply Voltage for contrast (approx. 0.6V) |
| 4 | RS | MPU | Register Select signal. RS = 0: Command, RS = 1: Data |
| 5 | R/W | MPU | Read/Write select signal, R/W = 1: Read R/W: = 0: Write |
| 6 | E | MPU | Operation Enable signal. Falling edge triggered. |
| 7 - 10 | DB0 – DB3 | MPU | Four low order bi - directional three - state data bus lines. Not used during 4 - bit operation. |
| 11 - 14 | DB4 – DB7 | MPU | Four high order bi - directional three - state data bus lines. |
| 15 | LED+ | Power Supply | Backlight Anode (+5.0V via on - board resistor) |
| 16 | LED - | Power Supply | Backlight Cathode (Ground) |
推荐使用2.54mm间距的引脚作为LCD连接器。
三、电气与光学特性
3.1 电气特性
| Item | Symbol | Condition | Min. | Typ. | Max. | Unit |
| Operating Temperature Range | TOP | Absolute Max | - 20 | - | +70 | ⁰C |
| Storage Temperature Range | TST | Absolute Max | - 30 | - | +80 | ⁰C |
| Supply Voltage | VDD | - | 4.7 | 5.0 | 5.5 | V |
| Supply Current | IDD | VDD = 5.0V | 1.0 | 1.5 | 2.5 | mA |
| Supply for LCD (contrast) | VDD - V0 | TOP = 25°C | 4.2 | 4.4 | 4.6 | V |
| “H” Level input | VIH | - | 0.7 * VDD | - | VDD | V |
| “L” Level input | VIL | - | VSS | - | 0.6 | V |
| “H” Level output | VOH | - | 3.9 | - | VDD | V |
| “L” Level output | VOL | - | VSS | - | 0.4 | V |
| Backlight Supply Voltage | VLED | - | 4.8 | 5.0 | 5.2 | V |
| Backlight Supply Current | ILED | VLED = 5.0V | 10 | 15 | 20 | mA |
3.2 光学特性
| Item | Symbol | Condition | Min. | Typ. | Max. | Unit | |
| Optimal Viewing Angles | Top | ϕY+ | Cr ≥ 2 | - | 40 | - | ⁰ |
| Bottom | ϕY - | - | 60 | - | ⁰ | ||
| Left | θX - | - | 60 | - | ⁰ | ||
| Right | θX+ | - | 60 | - | ⁰ | ||
| Contrast Ratio | CR | - | 2 | 5 | - | - | |
| Response Time | Rise | TR | TOP = 25°C | - | 150 | 250 | ms |
| Fall | TF | - | 200 | 300 | ms |
四、控制器信息
| 模块内置ST7066U控制器,其详细规格可从http://www.newhavendisplay.com/app_notes/ST7066U.pdf下载。DDRAM地址分配如下: | 1 | 2 | 3 | 4 | 5 | 6 | 7 | 8 | 9 | 14 |
| 00 01 02 03 04 05 06 07 08 09 0A 0B 0C 0D 0E 0F | ||||||||||
| 40 41 42 43 44 45 46 47 48 49 4A 4B 4C 4D 4E 4F |
五、指令表
| Instruction | Instruction code | Description | 270 KHZ Execution time (fOSC = | ||||||||||
| RS | R/W DB7 DB6 DB5 DB4 DB3 DB2 DB1 DB0 | ||||||||||||
| Clear Display | 0 | 0 | 0 | 0 | 0 | 0 | 0 | 0 | 0 | 1 | Write “20H” to DDRAM and set DDRAM address to “00H” from AC | 1.52ms | |
| Return Home | 0 | 0 | 0 | 0 | 0 | 0 | 0 | 0 | 1 | - | Set DDRAM Address to “00H” from AC and return cursor to its original position if shifted. The contents of DDRAM are not changed. | 1.52ms | |
| Entry mode Set | 0 | 0 | 0 | 0 | 0 | 0 | 0 | 1 | I/D | SH | Sets cursor move direction and specifies display shift. These parameters are performed during data write and read. | 37µs | |
| Display ON/ OFF control | 0 | 0 | 0 | 0 | 0 | 0 | 1 | D | C | B | D = 1: Entire display on C = 1: Cursor on B = 1: Blinking cursor on | 37µs | |
| Cursor or Display shift | 0 | 0 | 0 | 0 | 0 | 1 | S/C | R/L | - | - | Sets cursor moving and display shift control bit, and the direction without changing DDRAM data. | 37µs | |
| Function set | 0 | 0 | 0 | 0 | 1 | DL | N | F | - | - | DL: Interface data is 8/4 bits N: Number of lines is 2/1 F: Font size is 5x11/5x8 | 37µs | |
| Set CGRAM Address | 0 | 0 | 0 | 1 | AC5 AC4 AC3 AC2 AC1 AC0 | Set CGRAM address in address counter | 37µs | ||||||
| Set DDRAM Address | 0 | 0 | 1 | AC6 AC5 AC4 AC3 AC2 AC1 AC0 | Set DDRAM address in address counter. | 37µs | |||||||
| Read busy Flag and Address | 0 | 1 | BF | AC6 AC5 AC4 AC3 AC2 AC1 AC0 | Whether during internal operation or not can be known by reading BF. The contents of address counter can also be read. | 0s | |||||||
| Write data To Address | 1 | 0 | D7 | D6 | D5 | D4 | D3 | D2 | D1 | D0 | Write data into internal RAM (DDRAM/CGRAM). | 37µs | |
| Read data From RAM | 1 | 1 | D7 | D6 | D5 | D4 | D3 | D2 | D1 | D0 | Read data from internal RAM (DDRAM/CGRAM). | 37µs |
六、时序特性
6.1 从MPU向ST7066U写数据
| Tc | Enable Cycle Time | Pin E | 1200 | ns | ||
| TPW | Enable Pulse Width | Pin E | 140 | ns | ||
| TR,TF | Enable Rise/Fall Time | Pin E | 25 | ns | ||
| TAS | Address Setup Time | Pins: RS,RW,E | 0 | 0 | ns | |
| TAH | Address Hold Time | Pins: RS,RW,E | 10 | - | ns | |
| TDSW | Data Setup Time | Pins: DB0 - DB7 | 40 | - | ns | |
| TH | Data Hold Time | Pins: DB0 - DB7 | 10 | ns |
6.2 从ST7066U向MPU读数据
| Tc | Enable Cycle Time | Pin E | 1200 | 0 | ns | |
| TAH | Address Hold Time | Pins: RS,RW,E | 10 | ns | ||
| TDDR | Data Setup Time | Pins: DB0 - DB7 | - | 100 | ns | |
七、初始化程序
7.1 8位初始化
void command(char i)
P1 = i; //put data on output Port
D_I = 0; //D/I=LOW : send instruction
R_W = 0; //R/W=LOW:Write
E = 1;
Delay(1);
Delay(1); //enable pulse width >= 300ns
E = 0; //Clock enable: falling edge
void write(char i)
E = 0;
P1 = i;
D_I = 1; //D/I=HIGH : send data
E = 1;
Delay(1);
E = 0; //Clock enable:falling edge
void init()
E = 0;
Delay(100);
Delay(100); //Wait >40 msec after power is applied
command(0x30); //command 0x30 = Wake up
command(0x30);
Delay(30);
Delay(30); //must wait 5ms, busy flag not available
command(0x30); //command 0x30 = Wake up #2
Delay(10);
Delay(10); //must wait 160us, busy flag not available
command(0x30); //command 0x30 = Wake up #3
Delay(10);
command(0x38);
command(0x38); //Function set: 8-bit/2-line
command(0x10);
command(0x0c);
command(0x06); //Set cursor //Display ON; Cursor ON //Entry mode set
7.2 4位初始化
Nybble();
R_W = 0;
i = i < < 4;
P1 = i;
Nybble(); //Send Upper 4 bits //Shift over by 4 bits //put data on output Port //Send Lower 4 bits
void write(char i)
D_I = 1; //D/I=HIGH: send data
R_W = 0;
Nybble();
i = i < < 4;
P1 = i;
Nybble(); //Clock Upper 4 bits //Shift over by 4 bits //put data on output Port //Clock Lower 4 bits
void Nybble()
E = 1;
Delay(1);
void init()
P1 = 0;
P3 = 0;
Delay(100);
P1 = 0x30;
Delay(30);
Nybble(); //command 0x30 = Wake up
Delay(10);
Nybble(); //command 0x30= Wake up #2
Delay(10);
Nybble(); //command 0x30 = Wake up #3
Delay(10);
Delay(10); //can check busy flag now instead of delay
P1 = 0x20;
Nybble(); //Function set: 4-bit interface
Nybble();
command(0x28);
command(0x28); //Function set: 4-bit/2-line
command(0x10);
command(0x0F); //Set cursor
command(0x0F); //Display ON; Blinking cursor
command(0x06); //Entry Mode set
八、质量信息与注意事项
8.1 质量测试
| Test Item | Content of Test | Test Condition | Note |
| High Temperature storage | Endurance test applying the high storage temperature for a long time. | +80⁰C , 48hrs | 2 |
| Low Temperature storage | Endurance test applying the low storage temperature for a long time. | -30⁰C , 48hrs | 1,2 |
| High Temperature Operation | Endurance test applying the electric stress (voltage & current) and the high thermal stress for a long time. | +70⁰C 48hrs | 2 |
| Low Temperature Operation | Endurance test applying the electric stress (voltage & current) and the low thermal stress for a long time. | -20⁰C , 48hrs | 1,2 |
| High Temperature / Humidity Operation | Endurance test applying the electric stress (voltage & current) and the high thermal with high humidity stress for a long time. | +40⁰C , 90% RH , 48hrs | 1,2 |
| Thermal Shock resistance | Endurance test applying the electric stress (voltage & current) during a cycle of low and high thermal stress. | 0⁰C,30min -> 25⁰C,5min -> 50⁰C,30min = 1 cycle 10 cycles | |
| Vibration test | Endurance test applying vibration to simulate transportation and use. | 10 - 55Hz , 15mm amplitude. |
举报投诉
初始化程序
1文章
24浏览量
6886
热点推荐
深入解析NHD - 0216K1Z - NSW - FBW - L液晶显示模块
、产品概述 NHD - 0216K1Z - NSW - FBW - L是一款2行×16字符的液晶显示
深入解析NHD - 0216K1Z - NSW - BBW - L字符液晶显示模块
深入剖析NHD - 0216K1Z - NSPG - FBW - L字符液晶显示模块
探索NHD - 0216K1Z - NS(RGB) - FBW - REV1字符液晶显示模块
探索NHD-0216K1Z-NSO-FBW-L字符液晶显示模块
探索NHD-0216K1Z-NSO-FBW-L字符液晶显示模块 在电子设备中,显示屏是人机交互的重要窗口,
NHD-0216K1Z-NSB-FBW-L字符液晶显示模块技术解析
NHD-0216K1Z-NSB-FBW-L字符液晶显示模块技术解析 在电子设备的设计中,
NHD - 0216K1Z - FSW - GBW - L字符液晶显示模块技术解析
探索NHD - 0216K1Z - FSW - FTW - FB1字符液晶显示模块
探索NHD - 0216K1Z - FSPG - FBW - L字符液晶显示模块
探索NHD - 0216K1Z - FSO - FBW - L字符液晶显示模块
探索NHD - 0216K1Z - FSA - GBW - L字符液晶显示模块
探索NHD - 0216K1Z - FSA - GBW - L字符液晶显示模块 在电子设计领域,
深入解析NHD - 0216K1Z - FSA - FBW - L字符液晶显示模块
探索NHD - 0216K1Z - FS(RGB) - FBW - rev1字符液晶显示模块
深入解析NHD - 0216K1Z - FS(RGB) - FBW液晶显示模块
深入解析NHD - 0216K1Z - FS(RGB) - FBW液晶显示模块 一、引言 在电子
