Newhaven Display字符液晶显示模块NHD技术解析
在电子设备的设计中,液晶显示模块是人机交互的重要组成部分。Newhaven Display推出的NHD字符液晶显示模块具有诸多特性,下面我们来详细了解其相关技术。
一、产品概述
NHD字符液晶显示模块为1行16字符显示,内置ST7066U控制器,采用+5.0V电源供电,具备1/16 duty、1/5 bias的驱动方式,并且符合RoHS标准。该模块在电子设备中可用于显示各种字符信息,为用户提供直观的交互界面。
二、机械与引脚设计
机械图纸
机械图纸给出了模块的外形尺寸和引脚分配。其标准公差为线性±0.3mm,显示类型为FSTN/Positive/Transflective/6:00视角,工作温度范围为 -20°C - 70°C,存储温度范围为 -30°C - 80°C,背光源为红色。
引脚说明与接线图
| Pin No. | Symbol | External Connection | Function Description |
| 1 | VSS | Power Supply | Ground |
| 2 | VDD | Power Supply | Supply Voltage for logic (+5.0V) |
| 3 | V0 | Adj Power Supply | Power supply for contrast (approx. 0.5V) |
| 4 | RS | MPU | Register select signal. RS=0: Command, RS=1: Data |
| 5 | R/W | MPU | Read/Write select signal, R/W=1: Read R/W: =0: Write |
| 6 | E | MPU | Operation enable signal. Falling edge triggered. |
| 7 - 10 | DB0 – DB3 | MPU | Four low order bi - directional three - state data bus lines. Not used during 4 - bit operation. |
| 11 - 14 | DB4 – DB7 | MPU | Four high order bi - directional three - state data bus lines. |
| 15 | LED+ | Power Supply | Power supply for LED Backlight (+5.0V via on - board resistor) |
| 16 | LED- | Power Supply | Ground for Backlight |
推荐使用2.54mm间距的引脚作为LCD连接器。
三、电气与光学特性
电气特性
| Item | Symbol | Condition | Min. | Typ. | Max. | Unit |
| Operating Temperature Range | Top | Absolute Max | -20 | - | +70 | ⁰C |
| Storage Temperature Range | Tst | Absolute Max | -30 | - | +80 | ⁰C |
| Supply Voltage | VDD | 4.7 | 5.0 | 5.5 | V | |
| Supply Current | IDD | Ta = 25°C, VDD = 5.0V | - | 1.5 | 2.5 | mA |
| Supply for LCD (contrast) | VDD - V0 | Ta = 25°C | - | 4.5 | - | V |
| “H” Level input | Vih | 0.7 VDD | - | VDD | V | |
| “L” Level input | Vil | 0 | - | 0.6 | V | |
| “H” Level output | Voh | 3.9 | - | - | V | |
| “L” Level output | Vol | - | - | 0.4 | V | |
| Backlight Supply Voltage | Vled | - | - | 5.0 | - | V |
| Backlight Supply Current | Iled | Vled = 5.0V | - | 30 | - | mA |
光学特性
| Viewing Angle – Vertical (top) | AV | Cr ≥ 3 | - | 20 | - | ⁰ |
| Viewing Angle – Vertical (bottom) | AV | Cr ≥ 3 | - | 50 | - | ⁰ |
| Viewing Angle – Horizontal (left) | AH | Cr ≥ 3 | - | 30 | - | ⁰ |
| Viewing Angle – Horizontal (right) | AH | Cr ≥ 3 | - | 30 | - | ⁰ |
| Contrast Ratio | Cr | 3 | 5 | - | - | |
| Response Time (rise) | Tr | - | - | 150 | 250 | ms |
| Response Time (fall) | Tf | - | - | 150 | 250 | ms |
这些特性决定了模块在不同环境下的显示效果和性能表现,工程师在设计时需要根据实际需求进行考量。
四、指令集与内置字体
指令表
模块提供了一系列指令,用于控制显示内容、光标位置等。例如,Clear Display指令可将DDRAM地址设置为“00H”并清除显示内容;Return Home指令可将DDRAM地址设置为“00H”并将光标返回原始位置。
内置字体表
内置字体表定义了不同编码对应的字符显示,涵盖了多种字符和符号,方便工程师进行字符显示的编程。
五、初始化程序示例
8位初始化
void command(char i)
P1 = i; D1 = 0; R_W = 0; E = 1;
Delay(1);
E = 0;
void write(char i)
P1 = i; DI = 1;
R_W = 0; E = 1;
Delay(1); E = 0;
void init()
E = 0;
Delay(10); command(0x30); Delay(10); command(0x30); command(0x10); Delay(30); command(0x30); command(0x38); Delay(100);
command(0x0c);
command(0x06);
4位初始化
P1 = i; D1 = 0;
i = i < < 4; R_W = 0; Nybble(); P1 = i; Nybble();
void write(char i)
Nybble(); i = i < < 4; DI = 1; P1 = i; R_W = 0; P1 = i; Nybble();
void Nybble()
E = 1;
Delay(1);
E = 0;
void init()
P1 = 0; P3 = 0;
Delay(100); P1 = 0x30;
Delay(30); Nybble();
Nybble(); P1 = 0x20; command(0x06); command(0x0F); Delay(10); Delay(10); Nybble(); command(0x10); Delay(10); command(0x28); Nybble();
这些初始化程序为工程师提供了快速上手的代码示例,方便在实际项目中进行开发。
六、质量测试
产品进行了多项质量测试,包括高温存储、低温存储、高温运行、低温运行、高温高湿运行、热冲击抵抗、振动测试和静电测试等。这些测试确保了产品在不同环境和条件下的可靠性和稳定性。
在实际设计中,电子工程师需要综合考虑模块的各项特性和性能,根据具体的应用场景进行合理的设计和优化。你在使用这类液晶显示模块时,有没有遇到过一些特殊的问题呢?欢迎在评论区分享你的经验。
初始化程序
1文章
24浏览量
6886
