MIC4680 POWER CONVERTER,MIC4680应用电路
关键字:MIC4680 POWER CONVERTER
General Description
The MIC4680 Super Switcher™ is an easy-to-use fixed or adjustable output voltage step-down (buck) switch-mode voltage regulator. The 200kHz MIC4680 achieves up to 1.3A of continuous output current over a wide input range in a 8-lead SOP (small outline package).
The MIC4680 is available in 3.3V and 5V fixed output versions or adjustable output down to 1.25V.
The MIC4680 has an input voltage range of 4V to 34V, with excellent line, load, and transient response. The regulator performs cycle-by-cycle current limiting and thermal shutdown for protection under fault conditions. In shutdown mode, the regulator draws less than 2ìA of standby current. The MIC4680 Super Switcher™ regulator requires a minimum number of external components and can operate using a standard series of inductors and capacitors. Frequency compensation is provided internally for fast transient response and ease of use.
The MIC4680 is available in the 8-lead SOP with a –40°C to +125°C junction temperature range.
Features
• SO-8 package with up to 1.3A output current
• All surface mount solution
• Only 4 external components required
• Fixed 200kHz operation
• 3.3V, 5V, and adjustable output versions
• Internally compensated with fast transient response
• Wide 4V to 34V operating input voltage range
• Less than 2μA typical shutdown-mode current
• Up to 90% efficiency
• Thermal shutdown
• Over current protection
Typical Applications
1.MIC4680 +6 to +34 input 3.3V/1A output power converter
2.MIC4680 +5 to +34 input 2.5V/1A output power converter
3.MIC4680 +7.5 to +34 input multi-output power converter
4.MIC4680 Constant Current and Constant Voltage Battery Charger
5.. MIC4680 +12V to –12V/150mA Buck-Boost Converter
6. MIC4680 5V to 3.3V/5A Power Supply
举报投诉
热点推荐
哪些产品要做MIC认证呢?
日本MIC认证(由日本总务省监管)主要针对无线通信类产品和连接公共电信网络的设备。下面用简单明了的方式告诉你——哪些产品必须做MIC认证、哪些不用。一、必须做MIC认证的产品1.含无线功能的产品
MIC21LV32评估板技术解析:多相降压控制器的工程实践
Microchip Technology EV71S00A MIC21LV32评估板方便全面评估MIC21LV32功能的特性和性能。MIC21LV32是一款恒定导通时间、双相同步降压控制器,采用独特的自适应导通时间控制架构,具有
MIC21LV33评估板技术解析与应用指南
Microchip Technology EV93M52A MIC21LV33评估板设计用于快速地演示MIC21LV33的功能和广泛用途。MIC21LV33是一款恒定导通时间、双相同步降压控制器
MIC2129评估板核心技术解析与应用指南
Microchip Technology EV23R43A评估板完全组装,设计用于评估和演示MIC2129的功能。 这些MIC2129是降压同步直流-直流控制器,采用自适应导通时间控制架构
MIC4607A MOSFET驱动器评估板用户指南总结
。MIC4607A评估板配备PWM信号测试插头、故障信号测试插头,以及对V~DD~ 和自举电路的UVLO保护功能。此评估板与3.3V和5V逻辑电平微控制器兼容。
MIC4607A三相MOSFET驱动器技术解析与应用指南
Microchip Technology MIC4607A三相MOSFET驱动器为1nF容性负载提供快速 (35ns) 传播延迟时间和20ns上升/下降时间。MIC4607A TTL输入可以是独立
MIC24097降压转换器核心技术解析与应用设计指南
Microchip Technology MIC24097降压转换器采用出色的自适应导通时间控制架构。该恒定频率同步降压转换器具有4.5V至20V输入电源范围和高达800kHz的可编程开关频率。MIC24097的输出电压可调节,低至0.6V,保证精度为 ±1%。
MIC24097评估板技术解析与应用指南
Microchip Technology MIC24097评估板经过完全组装和测试,用于演示MIC24097的功能。MIC24097转换器采用出色的自适应导通时间控制架构。该板基于降压拓扑,当输入端配有5V至20V电压时,可提供
MIC1551/53 IttyBitty RC定时器/振荡器技术解析与应用指南
采用电阻电容器(RC)计时方法,复制了传统555定时器的功能,在紧凑型SOT-23-5封装中提供精密计时。MIC1551可用作具有独立阈值和触发输入的不稳定(振荡器)或单稳态(单次)。MIC1553仅
Microchip MIC333/2333:重新定义低功耗高精度测量的零点漂移运算放大器
Microchip Technology MIC333/MIC2333零点漂移运算放大器具备输入失调电压校正功能,可实现极低的失调及失调漂移。这些放大器是低功耗设备,典型增益带宽积 (GBWP) 为
Analog Devices Inc. EVAL-ADN4680E评估套件数据手册
Analog Devices Inc. EVAL-ADN4680E评估套件设计用于快速轻松地演示ADN4680E四通道M-LVDS收发器。ADN4680E四通道M-LVDS收发器是驱动器和接收器
请问LTM4680输出电压配置电阻如何准确计算?
手册描述LTM4680可在VOUTn_CFG引脚与GND之间连入不同阻值的电阻配置不同的输出电压,手册table 1给了一些特定的离散值,但是手册中没有给出详细的计算公式。
某些asic对供电电压
发表于 06-19 06:07
特斯拉4680电池生产线取得重大进展
近日,特斯拉在电动汽车领域再传捷报。2 月 3 日,特斯拉在其 2024 年第四季度更新信中透露,公司自研的 4680 电池生产线已取得重大进展,产能达到每周可支持超过 2500 辆
TLV320AIC3106有MIC3R MIC3L两个引脚,能不能用这两个引脚单独各接一路MIC输入,从而形成两路MIC输入?
大家好,TLV320AIC3106有MIC3R MIC3L两个引脚,我看EVM上做MIC输入时这两个引脚接在一起用,我想问,能不能用这两个引脚单独各接一路MIC输入,从而形成两路
发表于 01-09 06:05
