一段ESP32S2代码
丙丁先生的自学旅程 来源:丙丁先生的自学旅程 作者:丙丁先生的自学旅 2025-11-11 07:25 次阅读
加入交流群
微信小助手二维码
扫码添加小助手
加入工程师交流群
* SPDX-FileCopyrightText: 2022 Espressif Systems (Shanghai) CO LTD
* SPDX-License-Identifier: Apache-2.0
#include "esp_check.h"
#include "led_strip_rmt_encoder.h"
static const char *TAG = "led_rmt_encoder";
typedef struct {
rmt_encoder_t base;
rmt_encoder_t *bytes_encoder;
rmt_encoder_t *copy_encoder;
int state;
rmt_symbol_word_t reset_code;
} rmt_led_strip_encoder_t;
static size_t rmt_encode_led_strip(rmt_encoder_t *encoder, rmt_channel_handle_t channel, const void *primary_data, size_t data_size, rmt_encode_state_t *ret_state)
rmt_led_strip_encoder_t *led_encoder = __containerof(encoder, rmt_led_strip_encoder_t, base);
rmt_encoder_handle_t bytes_encoder = led_encoder->bytes_encoder;
rmt_encoder_handle_t copy_encoder = led_encoder->copy_encoder;
rmt_encode_state_t session_state = 0;
rmt_encode_state_t state = 0;
size_t encoded_symbols = 0;
switch (led_encoder->state) {
case 0: // send RGB data
encoded_symbols += bytes_encoder->encode(bytes_encoder, channel, primary_data, data_size, &session_state);
if (session_state & RMT_ENCODING_COMPLETE) {
led_encoder->state = 1; // switch to next state when current encoding session finished
if (session_state & RMT_ENCODING_MEM_FULL) {
state |= RMT_ENCODING_MEM_FULL;
goto out; // yield if there's no free space for encoding artifacts
// fall-through
case 1: // send reset code
encoded_symbols += copy_encoder->encode(copy_encoder, channel, &led_encoder->reset_code,
sizeof(led_encoder->reset_code), &session_state);
led_encoder->state = 0; // back to the initial encoding session
state |= RMT_ENCODING_COMPLETE;
out:
*ret_state = state;
return encoded_symbols;
static esp_err_t rmt_del_led_strip_encoder(rmt_encoder_t *encoder)
rmt_del_encoder(led_encoder->bytes_encoder);
rmt_del_encoder(led_encoder->copy_encoder);
free(led_encoder);
return ESP_OK;
static esp_err_t rmt_led_strip_encoder_reset(rmt_encoder_t *encoder)
rmt_encoder_reset(led_encoder->bytes_encoder);
rmt_encoder_reset(led_encoder->copy_encoder);
return ESP_OK;
esp_err_t rmt_new_led_strip_encoder(const led_strip_encoder_config_t *config, rmt_encoder_handle_t *ret_encoder)
esp_err_t ret = ESP_OK;
rmt_led_strip_encoder_t *led_encoder = NULL;
ESP_GOTO_ON_FALSE(config && ret_encoder, ESP_ERR_INVALID_ARG, err, TAG, "invalid argument");
ESP_GOTO_ON_FALSE(config->led_model < LED_MODEL_INVALID, ESP_ERR_INVALID_ARG, err, TAG, "invalid led model");
led_encoder = calloc(1, sizeof(rmt_led_strip_encoder_t));
ESP_GOTO_ON_FALSE(led_encoder, ESP_ERR_NO_MEM, err, TAG, "no mem for led strip encoder");
led_encoder->base.encode = rmt_encode_led_strip;
led_encoder->base.del = rmt_del_led_strip_encoder;
led_encoder->base.reset = rmt_led_strip_encoder_reset;
rmt_bytes_encoder_config_t bytes_encoder_config;
uint32_t reset_ticks = config->resolution / 1000000 * 280 / 2; // reset code duration defaults to 280us to accomodate WS2812B-V5
if (config->led_model == LED_MODEL_SK6812) {
bytes_encoder_config = (rmt_bytes_encoder_config_t) {
.bit0 = {
.level0 = 1,
.duration0 = 0.3 * config->resolution / 1000000, // T0H=0.3us
.level1 = 0,
.duration1 = 0.9 * config->resolution / 1000000, // T0L=0.9us
.bit1 = {
.level0 = 1,
.duration0 = 0.6 * config->resolution / 1000000, // T1H=0.6us
.level1 = 0,
.duration1 = 0.6 * config->resolution / 1000000, // T1L=0.6us
.flags.msb_first = 1 // SK6812 transfer bit order: G7...G0R7...R0B7...B0(W7...W0)
} else if (config->led_model == LED_MODEL_WS2812) {
// different led strip might have its own timing requirements, following parameter is for WS2812
.bit0 = {
.level0 = 1,
.level1 = 0,
.bit1 = {
.level0 = 1,
.duration0 = 0.9 * config->resolution / 1000000, // T1H=0.9us
.level1 = 0,
.duration1 = 0.3 * config->resolution / 1000000, // T1L=0.3us
.flags.msb_first = 1 // WS2812 transfer bit order: G7...G0R7...R0B7...B0
} else if (config->led_model == LED_MODEL_WS2811) {
// different led strip might have its own timing requirements, following parameter is for WS2811
.bit0 = {
.level0 = 1,
.duration0 = 0.5 * config->resolution / 1000000., // T0H=0.5us
.level1 = 0,
.duration1 = 2.0 * config->resolution / 1000000., // T0L=2.0us
.bit1 = {
.level0 = 1,
.duration0 = 1.2 * config->resolution / 1000000., // T1H=1.2us
.level1 = 0,
.duration1 = 1.3 * config->resolution / 1000000., // T1L=1.3us
reset_ticks = config->resolution / 1000000 * 50 / 2; // divide by 2... signal is sent twice
} else {
assert(false);
ESP_GOTO_ON_ERROR(rmt_new_bytes_encoder(&bytes_encoder_config, &led_encoder->bytes_encoder), err, TAG, "create bytes encoder failed");
rmt_copy_encoder_config_t copy_encoder_config = {};
ESP_GOTO_ON_ERROR(rmt_new_copy_encoder(©_encoder_config, &led_encoder->copy_encoder), err, TAG, "create copy encoder failed");
led_encoder->reset_code = (rmt_symbol_word_t) {
.level0 = 0,
.duration0 = reset_ticks,
.level1 = 0,
.duration1 = reset_ticks,
*ret_encoder = &led_encoder->base;
return ESP_OK;
err:
if (led_encoder) {
if (led_encoder->bytes_encoder) {
if (led_encoder->copy_encoder) {
free(led_encoder);
return ret;
  • 代码
  • esp32s2
加入交流群
微信小助手二维码
扫码添加小助手
加入工程师交流群
    热点推荐
    ESP32/ESP8266开发板单向对多ESP-NOW无线通信
    通过ESP-NOW无线通信协议实现ESP32开发板向多个ESP32/ESP 8266开发板发送数据。
    的头像 发表于 03-13 09:23 335次阅读
    <b class='flag-5'>ESP32</b>/<b class='flag-5'>ESP</b>8266开发板单向<b class='flag-5'>一</b>对多<b class='flag-5'>ESP</b>-NOW无线通信
    ESP32-S3系列】AD35-S3(AI红色桌宠)上手指南
    AD35-S3是深圳市启明云端有限公司推出的基于ESP32-S3-WROOM-1的新一代桌宠,有丰富的外设接口外,适用于AIoT领域的多种应用场景,例如唤醒词检测和语音命令识别、智能家居、智能家电
    的头像 发表于 02-26 18:05 435次阅读
    【<b class='flag-5'>ESP32-S</b>3系列】AD35-<b class='flag-5'>S</b>3(AI红色桌宠)上手指南
    ESP32-S2-MINI-2:高性能、高集成度的物联网Wi-Fi模组解析
    ESP32-S2-MINI-2款紧凑的2.4 GHz Wi-Fi(802.11 b/g/n)模块,内置ESP32-S2 系列芯片(版本v1.0),搭载Xtensa单核32位LX7微控制器。该模块
    的头像 发表于 02-04 17:43 1278次阅读
    <b class='flag-5'>ESP32-S2-MINI-2</b>:高性能、高集成度的物联网Wi-Fi模组解析
    乐鑫科技ESP32-S3开发板+超声波雾化,给智能鱼缸整点美学氛围
    我们为什么要给智能鱼缸弄上雾化?美学氛围当然是方面,但更重要的功能是局部加湿,为水面植物与周围空气提供柔和湿度。因此我们特意推出本期内容:用乐鑫科技ESP32-S3开发板和超声波雾化模块让水面形成
    的头像 发表于 12-08 18:04 1001次阅读
    乐鑫科技<b class='flag-5'>ESP32-S</b>3开发板+超声波雾化,给智能鱼缸整点美学氛围
    VSCode + ESP-IDF环境下给ESP32-S3项目添加头文件
    的头像 发表于 11-28 07:27 3288次阅读
    ESP32S工具链
    Xtensa LX6 ESP32ESP32-S2 xtensa-esp-elf 早期ESP32的基础架构 2. 对你的影响 你正在开发
    发表于 11-26 07:33
    #ESP32S3野牛小智
    ESP32
    丙丁先生
    发布于 :2025年11月25日 08:34:06
    低成本开源!用乐鑫科技ESP32-S3开发板轻松驱动无刷电机,保姆级教程来了!
    想用ESP32-S3开发板驱动无刷电机却不知从何下手?本教程将手把手教你完成从硬件连接到软件编程的全流程,无论你是新手还是有定经验的开发者,都能轻松掌握!本教程代码已全部开源!后台私信关键词
    的头像 发表于 11-06 18:03 1187次阅读
    低成本开源!用乐鑫科技<b class='flag-5'>ESP32-S</b>3开发板轻松驱动无刷电机,保姆级教程来了!
    快速上手!带你用LVGL工具完成乐鑫科技ESP32-S3 2.8寸串口屏UI开发!代码完全开源!
    酷炫的LVGL界面效果!本教程代码全部开源!后台私信关键词“S3-2.8寸屏LVGL开发“自动获取ESP32-S32.8寸串口屏LVGL开发源代码百度网盘链接!串
    的头像 发表于 10-30 18:04 2473次阅读
    快速上手!带你用LVGL工具完成乐鑫科技<b class='flag-5'>ESP32-S</b>3 2.8寸串口屏UI开发!<b class='flag-5'>代码</b>完全开源!
    ESP32 I2S音频总线学习笔记(二):I2S读取INMP441音频数据
    在这上篇文章中,我们介绍了ESP32 I2S音频总线的相关知识,简要了解了什么是I2S总线、它的通信格式,以及相关的底层API函数,这篇文章将介绍
    的头像 发表于 10-23 19:55 5053次阅读
    <b class='flag-5'>ESP32</b> I<b class='flag-5'>2S</b>音频总线学习笔记(二):I<b class='flag-5'>2S</b>读取INMP441音频数据
    ESP32-S3的MicroPython开发环境搭建
    本文通过搭建Thonny IDE开发环境,了解了如何给ESP32-S3烧录MircoPython固件和MircoPython应用程序。
    的头像 发表于 09-11 16:02 2078次阅读
    <b class='flag-5'>ESP32-S</b>3的MicroPython开发环境搭建
    文读懂WAV音频文件格式
    本文主要为后面ESP32 I2S音频系列文章做铺垫,所以本篇将介绍WAV音频文件格式,并通过C代码生成一段1S的正弦波WAV音频写入到SD卡
    的头像 发表于 08-25 17:49 5569次阅读
    <b class='flag-5'>一</b>文读懂WAV音频文件格式
    启明云端ESP32-S3 2.8寸串口屏到手了?如何上手?看这篇!
    【场外插播】ESP32-S32.8寸串口屏、MX1.25-7P线、MX1.25-8P线我们都带来了,开箱展示如下【竞猜继续】ESP32-S32.8寸串口屏到手还不知道如何上手点屏?不要担心,我们的上手指南来了!
    的头像 发表于 07-07 18:04 1168次阅读
    启明云端<b class='flag-5'>ESP32-S</b>3 2.8寸串口屏到手了?如何上手?看这篇!
    ESP32-P4 C5开发板烧录小智全流程!速看!
    没错,你没有看错!我们带着WT99P4C5-S1开发板烧录小智全流程走来了!开发板搭载乐鑫科技ESP32-P4和ESP32-C5芯片,代码完全开源,支持灵活二次开发。什么?文字教程不好
    的头像 发表于 07-04 18:03 2987次阅读
    <b class='flag-5'>ESP32</b>-P4 C5开发板烧录小智全流程!速看!
    ESP32-S3开发板烧录小智AI系统全流程指南
    在AI语音交互领域不断发展的今天,开发者们对于功能强大、开源灵活的开发板需求日益增长。今天,我们就来详细了解ESP32AgentDevKit烧录小智的全流程,这款搭载乐鑫科技ESP32-S3芯片
    的头像 发表于 06-16 18:01 8995次阅读
    <b class='flag-5'>ESP32-S</b>3开发板烧录小智AI系统全流程指南
