本期为大家推送迪文开发者论坛获奖开源案例——AI智能交互新方案:基于T5L智能屏的AI DeepSeek大模型。该方案通过T5L串口与AI模块开发板进行数据交互,支持用户与屏幕智能实时对话交互,并同步展示动态表情,构建了具有情感化交互能力的AI终端解决新方案。
UI素材展示
C51工程设计
(1)屏幕主要程序如下:
#defineMAX_PACKETS20//预设最大包数量typedefstruct { unsignedchar*indata;//数据指针 intlength;//包长度} Packet;intsplit_packets(constunsignedchar*indata,intdata_len, Packet *packets,int*packet_count){ intpositions[MAX_PACKETS] = {0}; intcount =0; inti;//查找所有包头位置 for( i =0; i <= data_len - 2&& count < MAX_PACKETS; ) { if (indata == 0x5A &&indata[i+1] == 0xA5) { positions[count++] = i; i += 2;//跳过包头 } else { i++; } } if (count == 0) return -1; *packet_count = count; for ( i = 0; i < count; i++) { int start = positions; int end = (i < count-1) ?positions[i+1] : data_len; packets.indata = indata + start; packets.length = end - start; } return 0;}#defineOutGbkLen 256unsignedchar HuanBuffdata[1024];voidHandleRecData(unsigned char *inputdata,unsigned char len){ char emotions=0; char emoarr[2]; memset(HuanBuffdata,0,sizeof(HuanBuffdata)); memcpy(HuanBuffdata,inputdata,len); switch(HuanBuffdata[2]){ case 1://表情 if(HuanBuffdata[3]>20) emotions=0; else emotions=HuanBuffdata[3]; emoarr[0]=0; emoarr[1]=emotions+1; write_dgusii_vp(0x3000,emoarr,1); break; case2://网络状态 break; case3://通知消息 write_dgusii_vp(0x2000,&HuanBuffdata[3],strlen(&HuanBuffdata[3])/2); break; case4://聊天信息 write_dgusii_vp(0x4000,&HuanBuffdata[3],strlen(&HuanBuffdata[3])/2); break; }}voidDispDataHandle(void){ inti ; intdata_len = uart4_rx_count; Packet packets[MAX_PACKETS];//栈内存分配 intpacket_count; if(split_packets(Uart4_Rx, data_len,packets, &packet_count) ==0) { for( i =0; i < packet_count; i++){ HandleRecData(packets.indata,packets.length); } }}
(2)AI模块开发板程序如下:
voidXINGZHI_1_54_TFT_LcdDisplay::SetChatMessage(constchar* role,constchar* content) { DisplayLockGuardlock(this); if(chat_message_label_ ==nullptr) { return; } lv_label_set_text(chat_message_label_, content); charsenddata[10]; inti=0; memset(senddata,0,sizeof(senddata)); senddata[i++]=0x5a; senddata[i++]=0xa5; senddata[i++]=0x4; uart_write_bytes(USART_UX,senddata,i); uint16_tunicode_string[256];//足够大的缓冲区 memset(unicode_string,0,sizeof(unicode_string)); uint32_tretlen=utf8_to_unicode((constuint8_t*)content,strlen(content),unicode_string); uint8_tgbk_string[256];//足够大的缓冲区 UnicodeToGbk(unicode_string,gbk_string,sizeof(gbk_string)); uart_write_bytes(USART_UX,gbk_string,strlen((char*)gbk_string));}voidXINGZHI_1_54_TFT_LcdDisplay::SetStatus(constchar* status) { DisplayLockGuardlock(this); if(status_label_ ==nullptr) { return; } lv_label_set_text(status_label_, status); lv_obj_clear_flag(status_label_, LV_OBJ_FLAG_HIDDEN); lv_obj_add_flag(notification_label_, LV_OBJ_FLAG_HIDDEN); charsenddata[10];inti=0; memset(senddata,0,sizeof(senddata)); senddata[i++]=0x5a; senddata[i++]=0xa5; senddata[i++]=0x3; uart_write_bytes(USART_UX,senddata,i); uint16_tunicode_string[256];//足够大的缓冲区 memset(unicode_string,0,sizeof(unicode_string)); uint32_tretlen=utf8_to_unicode((constuint8_t*)status,strlen(status),unicode_string); uint8_tgbk_string[256];//足够大的缓冲区 UnicodeToGbk(unicode_string,gbk_string,sizeof(gbk_string)); uart_write_bytes(USART_UX,gbk_string,strlen((char*)gbk_string));}
AI
91文章
41171浏览量
302624 -
大模型
2文章
3777浏览量
5273 -
DeepSeek
2文章
840浏览量
3406
边缘AI算力临界点:深度解析176TOPS香橙派AI Station的产业价值
大模型 ai coding 比较
乐鑫携手 Bosch Sensortec(博世传感器)推出 AI 智能交互方案
【开源获奖案例】AI智能交互新方案:基于T5L智能屏的AI DeepSeek大模型
