Keepalive基础知识
马哥Linux运维 来源:马哥Linux运维 2024-12-19 09:57 次阅读
加入交流群
微信小助手二维码
扫码添加小助手
加入工程师交流群
Keepalive
1 keepalived介绍
官网:http://keepalived.org/
功能:
基于vrrp协议完成地址流动
为vip地址所在的节点生成ipvs规则(在配置文件中预先定义)
为ipvs集群的各RS做健康状态检测
基于脚本调用接口完成脚本中定义的功能,进而影响集群事务,以此支持nginx、haproxy等服务
2 Keepalived 架构
官方文档:
https://keepalived.org/doc/
http://keepalived.org/documentation.html
用户空间核心组件:
vrrp stack:VIP消息通告 虚拟ip
checkers:监测real server(简单来说 就是监控后端真实服务器的服务)是否存活
system call:实现 vrrp 协议状态转换时调用脚本的功能
SMTP:邮件组件(报警邮件)
IPVS wrapper:生成IPVS规则(直接生成ipvsadm)
Netlink Reflector:网络接口(将虚拟地址ip(vip)地址飘动)
WatchDog:监控进程(整个架构是否有问题)
控制组件:提供keepalived.conf 的解析器,完成Keepalived配置
IO复用器:针对网络目的而优化的自己的线程抽象
内存管理组件:为某些通用的内存管理功能(例如分配,重新分配,发布等)提供访问权限
keeplive可以配合ngnix等软件,反向代理
3安装keepalive
yum  install   keepalived  -y
3.1 编译安装 keepalived
yum install gcc curl openssl-devel libnl3-devel net-snmp-devel  -y
# 安装依赖包环境
https://keepalived.org/download.html
# 官网下载安装包
wget https://keepalived.org/software/keepalived-2.2.2.tar.gz
tar  xf   keepalived-2.2.2.tar.gz
cd   keepalived-2.2.2/
./configure --prefix=/usr/local/keepalived
make   &&  make  install
自动生成service文件
#生成怕并修改配置文件
mkdir    /etc/keepalived
cp /usr/local/keepalived/etc/keepalived/keepalived.conf  /etc/keepalived/keepalived.conf
需要修改配置文件的21行  网卡名称, 否则起不来
sed  -i   's/eth0/ens33/'
4 Keepalived 相关文件
软件包名:keepalived
主程序文件:/usr/sbin/keepalived
主配置文件:/etc/keepalived/keepalived.conf
配置文件示例:/usr/share/doc/keepalived/
Unit File:/lib/systemd/system/keepalived.service
Unit File的环境配置文件:
/etc/sysconfig/keepalived CentOS
4.1配置组成
/etc/keepalived/keepalived.conf 配置组成
GLOBAL CONFIGURATION
Global definitions(全局配置):定义邮件配置,route_id ,vrrp配置,组播地址 等
VRRP CONFIGURATION
VRRP instance(s):定义vrrp协议中的每个vrrp虚拟路由器的规则,基本信息
LVS CONFIGURATION(lvs调度服务器的规则设置)
Virtual server group(s)
Virtual server(s):LVS集群的VS和RS
4.2全局配置
#/etc/keepalived/keepalived.conf
global_defs {
 notification_email {
 root@localhost
 #keepalived 发生故障切换时邮件发送的目标邮箱,可以按行区分写多个
 root@localhost
 360601212@qq.com
 notification_email_from keepalived@localhost  #发邮件的地址
 smtp_server 127.0.0.1   #邮件服务器地址
 smtp_connect_timeout 30   #邮件服务器连接timeout
 router_id   LVS01
 #每个keepalived主机唯一标识,建议使用当前主机名,但多节点重名不影响
 vrrp_skip_check_adv_addr
 #对所有通告报文都检查,会比较消耗性能,启用此配置后,如果收到的通告报文和上一个报文是同一个路由器,则跳过检查,默认值为全检查
vrrp_strict
#严格遵守VRRP协议,启用此项后以下状况将无法启动服务:1.无VIP地址 2.配置了单播邻居 3.在VRRP版本2中有IPv6地址,开启动此项并且没有配置vrrp_iptables时会自动开启iptables防火墙规则,默认导致VIP无法访问,建议不加此项配置。
 vrrp_garp_interval 0
 #gratuitous ARP messages 免费ARP报文发送延迟,0表示不延迟
 vrrp_gna_interval 0
 #unsolicited NA messages (不请自来)消息发送延迟
 vrrp_mcast_group4 225.0.0.18
 #指定组播IP地址范围:224.0.0.0到239.255.255.255,默认值:224.0.0.18
 vrrp_iptables
 #此项和vrrp_strict同时开启时,则不会添加防火墙规则,如果无配置vrrp_strict项,则无需启用此项配置
4.3配置虚拟路由器
vrrp_instance  {
#为vrrp的实例名,一般为业务名称
 配置参数
#配置参数:
state MASTER|BACKUP
#当前节点在此虚拟路由器上的初始状态,状态为MASTER或者BACKUP
interface IFACE_NAME
#绑定为当前虚拟路由器使用的物理接口,如:eth0,bond0,br0,可以和VIP不在一个网卡
virtual_router_id VRID
#每个虚拟路由器惟一标识,范围:0-255,每个虚拟路由器此值必须唯一,否则服务无法启动,同属一个虚拟路由器的多个keepalived节点必须相同,务必要确认在同一网络中此值必须唯一
priority 100
#当前物理节点在此虚拟路由器的优先级,范围:1-254,值越大优先级越高,每个keepalived主机节点此值不同
advert_int 1
#vrrp通告的时间间隔,默认1s
authentication {
#认证机制
 auth_type AH|PASS
 #AH为IPSEC认证(不推荐),PASS为简单密码(建议使用)
 auth_pass
 #预共享密钥,仅前8位有效,同一个虚拟路由器的多个keepalived节点必须一样
include    /etc/keealived/conf.d/*.conf
virtual_ipaddress {
#虚拟IP,生产环境可能指定上百个IP地址
 / brd  dev  scope  label
范例:
[root@localhost keepalived]#vim keepalived.conf
global_defs {
     sysadmin@firewall.loc
   notification_email_from Alexandre.Cassen@firewall.loc
   smtp_server 127.0.0.1  #邮箱地址写成自己
   router_id lvs_01   #修改成主机名
   #vrrp_strict   注释严格模式
   vrrp_gna_interval 0
include   /etc/keepalived/conf.d/*.conf  #添加子配置文件
[root@localhost keepalived]#mkdir  conf.d
[root@localhost conf.d]# vim  conf.d/test.conf
vrrp_instance VI_1 {
    state MASTER
    interface ens33   #修改网卡
    virtual_router_id 51  #路由器id 需要主从保持一致
    priority 100
    advert_int 1
    authentication {
        auth_type PASS
        auth_pass 1111
    virtual_ipaddress {
    192.168.91.188/24   #设置虚拟ip
将配置文件复制到从节点
scp  keepalived.conf    192.168.91.11:/etc/keepalived/
scp  keepalived.conf    192.168.91.11:/etc/conf.d/test.conf
修改配置文件
global_defs {
   router_id lvs_02  #修改成主机名
   #vrrp_strict   注释严格模式
   vrrp_gna_interval 0
    state BACKUP       #修改类型为备节点
    interface ens33
    virtual_router_id 51  #路由器id 需要主从保持一致   不用修改
    priority 80           #优先级调小
    advert_int 1
    authentication {
        auth_type PASS
        auth_pass 1111
    virtual_ipaddress {
4.3.1各种模式实验(依托于大实验成功后)
抢占模式,非抢占模式,延迟抢占模式
[root@localhost keepalived]#tcpdump -i ens33 -nn host 224.0.0.18
#启动服务可以抓包查看
[root@localhost ~]#ping 192.168.91.10
#真实服务器ping是可以通的
可以做实验 一直抓包
#非抢占模式
默认模式 使用的 抢占式
主节点会抢占回来,会造成 两次网络动荡。
#注意:要关闭 VIP抢占,必须将各 keepalived 服务器state配置为BACKUP
#非抢占式
#1主机配置
 state BACKUP   #都为BACKUP
 interface ens33
 virtual_router_id 66
 priority 100  #优先级高
 advert_int 1
 nopreempt     #添加此行,都为nopreempt
#2主机配置
 interface ens33
 priority 80    #优先级低
 advert_int 1
#延迟抢占
preempt_delay #   #指定抢占延迟时间为#s,默认延迟300s
#注意:需要各keepalived服务器state为BACKUP,并且不要启用 vrrp_strict
#1主机配置
 interface eth0
 priority 100     #优先级高
 advert_int 1
 preempt_delay 30 #抢占延迟模式,默认延迟300s
 #2主机配置
 interface eth0
 virtual_router_id 66:
 priority 80     #优先级低
 advert_int 1
 priority 80   #优先级高
 advert_int 1
4.3.2 单播多播地址
修改多播:
#两边都要加主从
global_defs {
     acassen@firewall.loc
     failover@firewall.loc
   router_id LVS_R1
   vrrp_mcast_group4 234.6.6.6
   #添加此行
   0-127
   128-191
   192-223
   224-239
[root@localhost ~]# tcpdump -i ens33 -nn host 234.6.6.6
#抓包查看查看
[root@localhost keepalived]#systemctl stop keepalived.service
#模拟故障,可以正常切换
修改单播:
#在所有节点vrrp_instance语句块中设置对方主机的IP,建议设置为专用于对应心跳线网络的地址,而非
使用业务网络
unicast_src_ip  #指定发送单播的源IP
unicast_peer {
     #指定接收单播的对方目标主机IP
#主服务器
  state MASRER
  interface eth0
  priority 100
  advert_int 1
  authentication {
    auth_type PASS
    auth_pass 123456
  virtual_ipaddress {
    10.0.0.10/24 dev eth0 label eth0:1
  unicast_src_ip 192.168.91.100   #本机IP     master 100   backup101
  unicast_peer{
  192.168.91.101 #指向对方主机IP 如果有多个keepalived,再下面加其它节点的I
vrrp_instance VI_2 {
  state BACKUP
  interface eth0
  priority 80
  advert_int 1
  authentication {
    auth_type PASS
    auth_pass 123456
  virtual_ipaddress {
    10.0.0.11/24 dev eth0 label eth0:1
  unicast_peer {
  192.168.91.101 #指向对方主机IP 如果有多个keepalived,再下面加其它节点的IP
备服务器
  state BACKUP
  interface eth0
  priority 100
  advert_int 1
  authentication {
    auth_type PASS
    auth_pass 123456
  virtual_ipaddress {
  state MASTER
  interface eth0
  priority 80
  advert_int 1
  authentication {
    auth_type PASS
    auth_pass 123456
  virtual_ipaddress {
#复制段
  unicast_peer {
   192.168.91.101
unicast_src_ip 192.168.91.101
  unicast_peer {
   192.168.91.100
[root@localhost ~]#tcpdump -i ens33 host -nn 192.168.91.100
#在从节点抓包验证
#复制有问题试试这段
    unicast_peer {
    192.168.91.101
4.3.3 通知脚本
当前节点成为主节点时触发的脚本
notify_master |
当前节点转为备节点时触发的脚本
notify_backup |
当前节点转为“失败”状态时触发的脚本
notify_fault |
通用格式的通知触发机制,一个脚本可完成以上三种状态的转换时的通知
notify |
当停止VRRP时触发的脚本
notify_stop |
#配置邮箱
[root@localhost opt]#vim /etc/mail.rc
set from=940132245@qq.com
set smtp=smtp.qq.com
set smtp-auth-user=940132245@qq.com
set smtp-auth-password=
[root@localhost opt]#vim keepalive.sh
#!/bin/bash
contact='940132245@qq.com'
notify() {
 mailsubject="$(hostname) to be $1, vip floating"
 mailbody="$(date +'%F %T'): vrrp transition, $(hostname) changed to be $1"
 echo "$mailbody" | mail -s "$mailsubject" $contact:
case $1 in
master)
 notify master
backup)
 notify backup
fault)
 notify fault
 echo "Usage: $(basename $0) {master|backup|fault}"
 exit 1
esac
[root@localhost opt]#vim /etc/keepalived/keepalived.conf
    state BACKUP
    interface ens33
    priority 100
    preempt_delay 30
    advert_int 1
    authentication {
        auth_type PASS
        auth_pass 1111
    virtual_ipaddress {
        192.168.91.16
   notify_master "/opt/keepalive.sh master"
   notify_backup "/opt/keepalive.sh backup"
   notify_fault "/opt/keepalive.sh fault"
[root@ka1-centos7 ~]#chmod +x   /etc/keepalived/keepalived.conf
#模拟master故障
[root@ka1-centos7 ~]#killall keepalived
4.3.4 日志功能
开启单独日志功能
[root@localhost opt]#keepalived --help
#查看帮助
[root@localhost opt]#ps aux |grep keep
root      25326  0.0  0.0 118616  1372 ?        Ss   11月20   0:00 /usr/sbin/keepalived -D
root      25327  0.0  0.1 127480  3336 ?        S    11月20   0:01 /usr/sbin/keepalived -D
root      25328  0.0  0.1 129500  2852 ?        S    11月20   0:01 /usr/sbin/keepalived -D
root      26877  0.0  0.0 112676   980 pts/0    S+   00:37   0:00 grep --color=auto keep
[root@localhost opt]#vim /lib/systemd/system/keepalived.service
EnvironmentFile=-/etc/sysconfig/keepalived
ExecStart=/usr/sbin/keepalived $KEEPALIVED_OPTIONS
[root@localhost opt]#vim /etc/sysconfig/keepalived
KEEPALIVED_OPTIONS="-D -S 6"
[root@localhost opt]#vim /etc/rsyslog.conf
# Save boot messages also to boot.log
local7.*                                                /var/log/boot.log
local6.*                                                /var/log/keepalived.log
[root@localhost opt]#systemctl restart keepalived.service rsyslog.service
[root@localhost opt]#cat /var/log/keepalived.log
#查看日志文件
实际操作:
LVS + Keepalived 高可用群集
环境
主keepalived:192.168.91.100     lvs
备keepalived:192.168.91.101     lvs
web1:192.168.91.102
web2:192.168.91.103
vip:192.168.91.188
客户机访问
systemctl stop firewalld.service
setenforce 0
[root@localhost ~]#systemctl stop firewalld.service
[root@localhost ~]#setenforce 0
[root@localhost ~]#yum install ipvsadm keepalived -y
[root@localhost ~]#modprobe ip_vs
[root@localhost ~]#cat /proc/net/ip_vs
IP Virtual Server version 1.2.1 (size=4096)
Prot LocalAddress:Port Scheduler Flags
  -> RemoteAddress:Port Forward Weight ActiveConn InActConn
[root@localhost keepalived]#ipvsadm-save > /etc/sysconfig/ipvsadm
[root@localhost keepalived]#systemctl start ipvsadm.service
[root@localhost keepalived]#cd /etc/keepalived/
[root@localhost keepalived]#cp keepalived.conf keepalived.conf.bak
#复制一份
global_defs {
   router_id HA_TEST_R2                  ####本路由器的服务器名称 HA_TEST_R2
vrrp_instance VI_1 {                     ####定义VRRP热备实列
   state BACKUP                          ####热备状态,backup表示辅服务器
   interface ens33                       ####表示承载VIP地址的物理接口
   virtual_router_id 1                   ####虚拟路由器的ID号,每个热备组保持一致
   priority 99                           ####优先级,优先级越大优先级越高
   advert_int 1                          ####通告间隔秒数(心跳频率)
   authentication {                      ####认证信息,每个热备组保持一致
      auth_type PASS                     ####认证类型
      auth_pass 123456                   ####认证密码
   virtual_ipaddress {                   ####漂移地址(VIP),可以是多个
      192.168.100.10
#需要修改项
global_defs {
   #修改邮箱指向自己(10行)
   router_id LVS_01
   #指定服务器名称主备需要不一样(12行)
   #vrrp_strict
   #14行需要注释否则服务启动有问题
   vrrp_gna_interval 0
    state MASTER
    #指定服务器类型MASTER为主 BACKUP为备(20行)
    interface ens33
    #修改网卡名称为ens33(21)
    virtual_router_id 10
    #指定虚拟路由器的ID号主备需要一致
    #nopreempt
    #非抢占模式两个节点都需要配置去掉注释
    priority 100
    #设定优先级数字越大优先级越高,准备需要不一样
    advert_int 1
    #通告间隔(查看是否存活)
    authentication {
        auth_type PASS
        #认证类型
        auth_pass 123456
        #修改验证密码,主备需要一样(27行)
    virtual_ipaddress {
        192.168.91.188
        #指定群集vip地址
virtual_server 192.168.91.188 80 {
    delay_loop 6
    #健康间隔时间6秒
    lb_algo rr
    #调度算法轮询
    lb_kind DR
    #lvs模式为DR
    persistence_timeout 0
    #连接保持时间改为0 否则 无法体现效果
    protocol TCP
    #采用协议
 real_server 192.168.91.103 80 {
 #43行修改地址为真实主机地址
        weight 1
        #45行删除
        #节点权重
        TCP_CHECK {
            connect_port 80
            #检查目标端口
            connect_timeout 3
            #连接超时
            nb_get_retry 3
            #重试次数
            delay_before_retry 3
            #重试间隔时间
 real_server 192.168.91.105 80 {
 #第二个
        weight 1
        TCP_CHECK{
            connect_port 80
            connect_timeout 3
            nb_get_retry 3
#从服务器配置
setenforce 0
[root@localhost keepalived]#scp keepalived.conf root@192.168.91.101:/etc/keepalived/
#将配置文件拷入 从服务器
[root@localhost keepalived]#systemctl start keepalived.service
[root@localhost keepalived]#ip a
[root@localhost keepalived]#vim /etc/sysctl.conf
[root@localhost keepalived]#sysctl -p
net.ipv4.conf.all.send_redirects = 0
net.ipv4.conf.default.send_redirects = 0
net.ipv4.conf.ens33.send_redirects = 0
#备份keepalive
12    router_id LVS_02
20     state BACKUP
23     priority 99
[root@localhost keepalived]#ipvsadm -ln
节点模式
[root@localhost ~]#systemctl start httpd
[root@localhost ~]#yum install httpd -y
[root@localhost html]#ifconfig lo:0 192.168.91.188 netmask 255.255.255.255
[root@localhost html]#vim /etc/sysctl.conf
[root@localhost html]#sysctl -p
net.ipv4.conf.all.arp_ignore = 1
net.ipv4.conf.all.arp_announce = 2
net.ipv4.conf.default.arp_ignore = 1
net.ipv4.conf.default.arp_announce = 2
net.ipv4.conf.lo.arp_ignore = 1
net.ipv4.conf.lo.arp_announce = 2
[root@localhost network-scripts]#route add -host 192.168.91.188 dev lo:0
#设置路由
5 面试重点 keepalived 主上也有188 从188
#模拟脑裂
[root@localhost keepalived]#iptables -A INPUT -s 192.168.91.100 -j REJECT
#在备份主机中加入此项
#可以在主备上都发现vip地址
脑裂解释
什么是脑裂?
在高可用(HA)系统中,当联系2个节点的“心跳线”断开时,本来为一整体、动作协调的HA系统,就分裂成为2个独立的个体。
由于相互失去了联系,都以为是对方出了故障。两个节点上的HA软件像“裂脑人”一样,争抢“共享
资源”、争起“应用服务”,就会发生严重后果。共享资源被瓜分、两边“服务”都起不来了;或者两边
“服务”都起来了,但同时读写“共享存储”,导致数据损坏
都有哪些原因导致脑裂?
高可用服务器对之间心跳线链路发生故障,导致无法正常通信。
因心跳线坏了(包括断了,老化)。
因网卡及相关驱动坏了,ip配置及冲突问题(网卡直连)
因心跳线间连接的设备故障(网卡及交换机)
高可用服务器上开启了 iptables防火墙阻挡了心跳消息传输。
高可用服务器上心跳网卡地址等信息配置不正确,导致发送心跳失败
其他服务配置不当等原因,如心跳方式不同,心跳广插冲突、软件Bug等。
多组keepalive服务器造成   组播冲突    1.换组播地址   2.改成单播
默认:
单播:
组播:
广播:
A   1 -127
B   128-191
C   192-223
D   224-239          224.0.0.18
20. 如何解决keepalived脑裂问题?
在实际生产环境中,我们从以下方面防止脑裂:
#同时使用串行电缆和以太网电缆连接、同时使用两条心跳线路,这样一条线路断了,另外一条还是好的,依然能传送心跳消息
#当检查脑裂时强行关闭一个心跳节点(这个功能需要特殊设备支持,如stonith、fence)相当于备节点接收不到心跳消息,通过单独的线路发送关机命令关闭主节点的电源
rsyslog   分割日志
#做好对脑裂的监控报警解决常见方案:
如果开启防火墙,一定要让心跳消息通过,一般通过允许IP段的形式解决
可以拉一条以太网网线或者串口线作为主被节点心跳线路的冗余
开发检测程序通过监控软件检测脑裂
keepalived      lvs      负载均衡  反向代理
lvs   高可用
后端服务器的 健康性检查问题
正向代理作用:    加快访问速度     可以绕过防火墙
代理的客户端
我要访问   google       正向代理服务器             google 服务器
反向代理:   负载均衡     优化资源
代理的服务端的
客户端 不需要知道服务端到底是什么样子的,只要能访问就行
keepalived  脑裂
vrrp  协议  心跳线收不到
6.实现其它应用的高可用性VRRP Script
keepalived利用 VRRP Script 技术,可以调用外部的辅助脚本进行资源监控,并根据监控的结果实现优先动态调整,从而实现其它应用的高可用性功能
任何软件组合 形成 高科用的 架构
vrrp script
手动编写脚本 , 来实现 故障的切换
参考配置文件:
/usr/share/doc/keepalived/keepalived.conf.vrrp.localcheck
6.1VRRP Script配置
分两步实现:
定义脚本
vrrp_script:自定义资源监控脚本,vrrp实例根据脚本返回值,公共定义,可被多个实例调用,定义在vrrp实例之外的独立配置块,一般放在global_defs设置块之后。通常此脚本用于监控指定应用的状态。一旦发现应用的状态异常,则触发对MASTER节点的权重减至低于SLAVE节点,从而实现 VIP 切换到 SLAVE 节点
vrrp_script  {
 script |  #此脚本返回值为非0时,会触发下面OPTIONS执行
 OPTIONS
vrrp_script   cxk   {
 script   "/opt/nginx.sh"
 interval  5    每个5s  执行上面的脚本 测试  nginx  是否存活
  weight   -30   自动减优先级  30
  fall     2    nginx 测试失败了   1次失败不算 需要2次失败 才认定你真的死了
  rise     2    ngnix  恢复了  测试2次都是正常 才让你变回主
if  systemctl   status  nginx
then
else
调用脚本
track_script:调用vrrp_script定义的脚本去监控资源,定义在VRRP实例之内,调用事先定义的vrrp_script
track_script {
 SCRIPT_NAME_1
 SCRIPT_NAME_2
6.2定义VRRP script
vrrp_script  { #定义一个检测脚本,在global_defs 之外配置
   script | #shell命令或脚本路径(注意执行权限)   0 不会执行以下操作,   1 就会执行以下操作
   interval  #间隔时间,单位为秒,默认1秒
   timeout  #超时时间
   weight   #默认为0,如果设置此值为负数,当上面脚本返回值为非0时,会将此值与本节点权重相加可以降低本节点权重,即表示fall. 如果是正数,当脚本返回值为0,会将此值与本节点权重相加可以提高本节点权重,即表示 rise.通常使用负值
   fall        #执行脚本连续几次都失败,则转换为失败,建议设为2以上
   rise   #执行脚本连续几次都成功,把服务器从失败标记为成功
   user USERNAME [GROUPNAME] #执行监测脚本的用户或组
   init_fail     #设置默认标记为失败状态,监测成功之后再转换为成功状态
实际操作:
[root@localhost keepalived]#vim /etc/keepalived/ng.sh
#编写脚本
#!/bin/bash
ng=$(ps -elf |grep nginx |egrep -cv "grep|$$")
if [ $ng -eq 0 ]
then
systemctl stop keealived
fi
killall  -0   nginx
killall  -0   mysql
[root@localhost keepalived]#chmod +x /etc/keepalived/ng.sh
#权限
[root@localhost keepalived]#vim /etc/keepalived/keepalived.conf
# 全局配置下配置
#脚本不要忘记加执行权限
global{
vrrp_script check_down {
        script  "/etc/keepalived/ng.sh"
        interval 1
        weight -30
        fall  3
        rise 2
        timeout 2
        script  "/etc/keepalived/ng.sh"   #指明脚本的位置
        interval 1            #每隔1s 执行一次检测
        weight -30             #如果 脚本执行失败自动减少优先级30
        fall  3                # 3次不成功才标注为失败
        rise 2                 #nginx  重新起来后检测两次成功 才真的成功
        timeout 2               #超时时间  2s
    state MASTER
    interface ens33
    priority 100
    advert_int 1
    authentication {
        auth_type PASS
        auth_pass 1111
    virtual_ipaddress {
        192.168.91.188
    track_script {
     check_down
反向代理模块
upstream  反向代理模块 在  http模块下
upstream w1 {
#定义反向代理 组名  w1
        server 192.168.91.102:80;
        #第一台代理服务器
        server 192.168.91.103:80;
        #第二台代理服务器
server 模块下
        location / {
        proxy_pass http://w1;
        #调用  upstream  模块
6.3实际操作
后端服务器
7-3
7-4
setenforce 0
echo  7-3 > /var/www/html/index.html
setenforce 0
echo  7-4 > /var/www/html/index.html
代理服务器
7-1
7-2
setenforce 0
yum install  epel-release.noarch -y
yum install  -y  nginx
systemctl start nginx
vim   /etc/nginx/nginx.conf
 upstream web  {
    server 192.168.91.102;
    server 192.168.91.103;
 location /  {
         proxy_pass  http://web;
scp   /etc/nginx/nginx.conf    192.168.91.101:/etc/nginx/nginx.conf
setenforce 0
安装keepalived 7-1 7-2
7-1   7-2 都要操作
7-1
! Configuration File for keepalived
global_defs {
   smtp_server 127.0.0.1      # 修改邮箱地址
   router_id LVS01            # 修改名称
   #vrrp_strict              #关闭严格模式
   vrrp_gna_interval 0
        interval 1
        weight -30
        fall  3
        rise 2
        timeout 2
        timeout 2               #超时时间  2s
    state MASTER
    interface ens33    #修改网卡的名称
    priority 100
    advert_int 1
    authentication {
         auth_type PASS
         auth_pass 1111
    virtual_ipaddress {
        192.168.91.188   #修改vip
     track_script {
     check_down
killall   -0    nginx
scp  /etc/keepalived/keepalived.conf   192.168.91.101://etc/keepalived/
7-2  上操作
从节点做修改   192.168.91.101
 global_defs {
   router_id LVS01
   #vrrp_strict
   vrrp_gna_interval 0
        interval 1
        weight -30
        fall  3
        rise 2
        timeout 2
    state BACKUP    #变成backup
    interface ens33
    priority 80   #调整优先级
    advert_int 1
    authentication {
         auth_type PASS
         auth_pass 1111
    virtual_ipaddress {
     track_script {
     check_down
killall   -0    nginx
链接:https://www.cnblogs.com/zhj0708/p/18276824
  • 架构
  • Keepalived
原文标题:Keepalive
文章出处:【微信号:magedu-Linux,微信公众号:马哥Linux运维】欢迎添加关注!文章转载请注明出处。
加入交流群
微信小助手二维码
扫码添加小助手
加入工程师交流群
    热点推荐
    步进电机的基础知识
    步进电机基础知识
    发表于 03-07 16:58 5508次阅读
    步进电机的<b class='flag-5'>基础知识</b>
    电气技术基础知识
    电气技术基础知识
    的头像 发表于 12-14 09:11 2667次阅读
    电气技术<b class='flag-5'>基础知识</b>
    labview基础知识
    labview基础知识labview基础知识labview基础知识labview基础知识
    发表于 03-08 17:56
    通信基础知识教程
    通信基础知识 1、电信基础知识2、通信电源技术3、配线设备结构、原理与防护4、防雷基础知识5、EMC基础知识6、防腐蚀原理与技术7、产品安
    发表于 03-04 16:48 34次下载
    QC基础知识
    QC基础知识阐述
    发表于 06-02 10:01 154次下载
    软板基础知识
    软板基础知识
    发表于 06-30 19:22 1605次阅读
    电子电路基础知识
    电子电路基础知识 电路基础知识(一)电路基础知识(1
    发表于 01-15 09:47 25w次阅读
    电池基础知识(集全版)
    电池基础知识(集全版)  电池基础知识
    发表于 11-10 14:19 3046次阅读
    电池隔膜基础知识
    电池隔膜基础知识
    发表于 11-17 13:40 1612次阅读
    计算机基础知识介绍
    计算机基础知识计算机基础知识计算机基础知识
    发表于 12-03 16:13 0次下载
    使用Eclipse基础知识
    使用Eclipse 基础知识 使用Eclipse 基础知识 适合初学者学习使用
    发表于 02-26 10:30 0次下载
    synplify基础知识说明
    synplify基础知识说明
    发表于 06-17 17:40 25次下载
    电源管理基础知识电源管理基础知识电源管理基础知识
    发表于 09-15 14:36 76次下载
    电源管理<b class='flag-5'>基础知识</b>电源管理<b class='flag-5'>基础知识</b>电源管理<b class='flag-5'>基础知识</b>
    C++基础知识
    C++基础知识
    的头像 发表于 01-12 11:00 2503次阅读
    C++<b class='flag-5'>基础知识</b>
    优质LDO基础知识分享
    本节分享下LDO的基础知识,主要来源于Ti的文档《LDO基础知识》。
    的头像 发表于 03-26 11:03 2647次阅读
