Intel Bay Trail J1900处理器, 6*COM, 10*USB, 1*LAN, 1*Mini-PCIe
- 采用Intel Bay Trail J1900处理器
- 提供6*COM, 10*USB, 1*百兆LAN
- 提供1*VGA, 1*LVDS, 支持双屏异显
- 提供1*Mini-PCIe (支持Wifi)
规格
| General | |
| CPU | Intel® Bay Trail J1900 CPU, Quad-core, up to 2.42 GHz, TDP10W |
| Chipset | Null |
| Memory | Up to 8 GB DDR3L 1333 MHz, 1*SO-DIMM |
| Storage | 2*SATA 2.0 |
| Expansion Interface | 1*Mini-PCIe (Wifi Supported) |
| BIOS | AMI UEFI BIOS |
| System | Windows 7/8/10, Linux, Android |
| I/O Interface | |
| Serial Port | 6*RS232 (COM3 TTL optional) |
| USB | 10*USB 2.0 (4*on rear I/O, 6*header) |
| Ethernet | 1*Realtek® PCI-E LAN for 100Mbps |
| Audio | Realtek® ALC662 5.1 channel HDA Codec, supports MIC/Line-outPorts |
| PS/2 | 1*PS/2 (Keyboard and Mouse Supported) |
| Parallel Port | 1*LPT |
| GPIO | 8 programmable GPIO |
| Feature Interface | Null |
| Display | |
| Display Interface |
1*VGA: max resolution up to 2560*1600@60Hz |
| Multiple Display | Dual |
| Mechanical & Environment | |
| Dimension | Mini-ITX, 170*170mm |
| Power Input | ATX PSU |
| Temperature | Operation: 0℃~60℃, Storage: -25℃~75℃ |
| Relative Humidity | Operation: 10%~90%, Storage: 5%~95%, non-condensing |
举报投诉
嵌入式主板
7文章
6107浏览量
37164 -
安卓
5文章
2187浏览量
60534 -
信步科技
7文章
264浏览量
7969
热点推荐
信步科技SV1-H2726C规格英文版
H270 chipset
Double-layer Rear I/O which can expand to 18*COM and 18*USB (use SV-M5 I/O Extension
信步科技SV1-19016EP规格英文版
Control, DC 12V or ATX Input.
Supports Intel Bay Trail J1900 CPU
6*COM, 8*USB, 1*1000 Mbps LAN
信步科技SV1-H1126C规格英文版
chipset
Double-layer Rear I/O which can expand to 18*COM and 18*USB (use SV-M5 I/O Extension Modules
信步科技SV1-H8116主板规格英文版
Intel 4th Gen Core i3/i5/i7 CPU (LGA1150) with H81, 6*COM, 1*LAN, 1*PCI-E 16X, 1*Mini-PCIe
信步科技NVR SV1-1908主板规格英文版
(RS485, 4*in/2*out GPIO) Supports dual display of 1*VGA and 2*HDMI 规格 General CPU Intel Bay Trail
Intel Bay Trail J1900处理器, 9*SATA, 2*Intel千兆LAN, 1*Mini-PCIe, NVR 专用报警端子 采用Intel Bay Trail J1900处理器
信步科技SV1-19016-C主板规格英文版
