电子发烧友App
硬声App
电子发烧友网>通信网络>通信设计应用>Using a EconOscillator to Cloc
收藏
查看更多
A 160 W CRT TV Power Supply using NCP1337
A 160 W CRT TV Power Supply using NCP1337Valley switching converters, also known asquasi?resonant
2009-03-27 16:03:33
A Low-Noise-Amplifier at 1.9 GHz using BFP405
This application note describes a low noise amplifier at 1.9GHz using SIEMENSSIEGET a25 BFP405.
2009-05-12 14:10:12
A Low-Noise-Amplifier shows good Noise Figure performance at 1.9 GHz using BF
This application note describes a low noise amplifier at 1.9GHz using SiemensSIEGETa25 BFP405.
2009-05-12 13:36:57
A Low-Noise-Amplifier with good IP3out - performance at 1.9 GHz using BFP405
This application note describes a low noise amplifier at 1.9GHz using SIEMENSSIEGETa25 BFP405.
2009-05-12 13:52:47
A Low-Noise-Amplifier with good IP3outperformance at 1.9 GHz using BFP420
This application note describes a low noise amplifier at 1.9GHz using SIEMENSSIEGETa25 BFP420.
2009-05-12 13:33:19
A Medium-Power-Amplifier at 1.9 GHz using BFP450
, circuit layout and measured data of a medium power amplifier at1.9GHz using Siemens SIEGET? BFP450.
2009-05-12 13:39:47
A Model Checking Example--Solving Sudoku Using Simulink Design Verifier
Formal verification methods prove mathematically that a design does not contain unwanted behavior.
2011-07-18 09:39:54
Using Android for Image Processing
2013-05-16 15:50:51
Using RSLinx OPC Server
2013-05-16 15:37:09
Using the ATF1500(A) CPLD
The ATF1500(A) is a high-performance,high-density Flash-based complex PLD.It has flexible
2009-05-13 10:09:39
Using the IBM43RF0100EV19 1900 MHz LNA Evaluation Board
Using the IBM43RF0100EV19 1900 MHz LNA Evaluation BoardThis application note describes using
2009-05-12 11:40:53
Using_an_MPU_to_Enforce_Spatial_Separation
2018-01-25 10:47:11
??? Error using ==> syms at 61 Not a valid variable name.
遇到这种情况怎么处理啊,matlab2010a,卸载了重新安装一遍还是不好使
2016-11-12 11:38:50
AD15的安装警告you are not using a valid license
安装altium designer 15后警告you are not using a valid license,该怎么办?
2019-01-30 09:38:27
Advantages of Using a MicroMonitor and a Simple Application Demonstrating the
Advantages of Using a MicroMonitor and a Simple Application Demonstrating the Use of a
2008-09-24 17:04:32
Design Optimization Using Quartus II
2017-09-28 12:39:12
2017-09-30 08:49:03
Estimation of IMU and MARG orientation using a
2016-08-17 12:23:29
LEARNING_ROBOTICS_USING_PYTHON
2016-09-28 11:44:25
Low-Noise-Amplifier optimised for minimum Noise Figure at 1.9 GHz using BFP420
, circuit layout and measured data of a low noise amplifier at1.9GHz using SIEMENS SIEGET?25 BFP420.
2009-05-12 13:48:36
Quick guide to making a mobile app for the TI SensorTag using JavaScript
be quite a challenge to develop mobile applications for the Internet of Things (IoT) using Bluetooth
2018-06-21 08:56:26
RT_USING_HEAP该怎样去理解呢
在阅读rtt代码是发现RT_USING_HEAP宏(/* Using Dynamic Heap Management */)scheduler.c --> void
2022-04-06 18:17:10
SMBus Design Using Low Power Microcontroller
to demonstrate the implementation of a SMBus-based system using Texas Instrument’s MSP430 SMBus Library.特性
2015-03-23 10:02:29
VOLTAGE QUADRUPLER USING TD310
VOLTAGE QUADRUPLER USING TD310The TD310 is a triple MOS or IGBT driver whichintegrates all
2009-05-12 09:57:13
Video Processing Using FPGAs in Video Surveillance Systems
Video Processing Using FPGAs in Video Surveillance SystemsVideo surveillance systems are a key
2008-08-08 12:32:39
matlab Error using ==> open at 162
Error using ==> open at 162,怎么打不开文件啊?????跪求高手指点迷津!!!!
2012-06-23 17:15:57
【已解决】求助:bus命名规则using the same base name...
): Bus "Voltage10[11..0]" found using same base name as "Voltage1", which might lead to a name conflict.已解决,答案3楼
2015-04-07 23:28:55
三叶草翻译--Using EAGLE: Schematic --来自于sparkfun
is the first of a two-part Using EAGLE series, and it’s devoted entirely to the schematic-designing side
2015-07-18 11:23:07
使用DS1075 EconOscillator作8051微处理器的时钟
本应用指南介绍了Dallas Semiconductor的DS1075 EconOscillator芯片如何用作各种类型的时钟控制逻辑,如微处理器、FPGA及CPLD电路。
2014-09-23 10:33:40
单片机中断 的interrupt 0 using 1中的interrupt和using作用
void INT0()interrupt 0 using 1{.........}interrupt 0指明是外部中断0;interrupt 1指明是定时器中断0; interrupt 2指明是外部
2012-07-23 22:59:20
请问BSP_USING_ON_CHIP_FLASH是在哪里打开的?
要用片内FLASH时的BSP_USING_ON_CHIP_FLASH在Studio的RT-Thread Setting里有没有开关?我找了半天好像没找到呢。 我就手工在rtconfig.h里加了一句
2023-05-11 14:25:32
使用DAC作为功能发生器-Using the DAC as
devices using the on-chip digital-toanalog converter (DAC).Features• Four different waveforms expandable toany periodic func
2009-01-23 23:14:5412
Designing a System Using the A
The ADAU1701/ADAU1702 can be used in a system without a microcontroller by using the self-boot
2009-04-16 23:56:2018
Using Cyclone Devices in Multi
Using Cyclone Devices in Multiple-Voltage Systems To meet the demand for higher system speed
2009-05-14 10:45:2118
Detecting Fast RF Bursts Using
Detecting Fast RF Bursts Using Log Amps:Monolithic logarithmic amplifi ers (log amps) can handle
2009-09-23 22:53:125
USB Mass Storage Device Using
USB Mass Storage Device Using a PIC MCU:In recent years, there has been immense growth inUniversal
2009-09-29 11:58:4550
Using a SAR Analog-to-Digital
Using a SAR Analog-to-Digital Converter for Current Measurement in Motor Control Applications
2009-10-01 19:02:2111
Using Cyclone III FPGAs for Cl
Using Cycl
2009-11-27 13:55:2515
Battery equalization using a p
Battery equalization using a plug-in charger in a hybrid electric vehicle
2009-11-28 11:56:3511
Using the Apple Universal Dock
Using the Apple Universal DockCongratulations on purchasing your Apple Universal Dock.You can use
2009-12-10 14:46:4657
Tiny audio amplifier using LM3
Tiny audio amplifier using LM386:The Tiny Audio Amplifier kit is a good choice for battery
2009-12-26 08:34:2851
Using Wavelet Eigenvalues as t
Using Wavelet Eigenvalues as the Input of Pi-sigma Network to Recognize Movement Pattern
2010-02-22 11:38:0113
Using Allegro PCB SI to Analyz
Using Allegro PCB SI to Analyze a Board’s Power Delivery System from Power Source to Die Pad:Slide
2010-04-05 06:23:270
Using the DLP Pico 2.0 Kit for
onto a  scene or object, usually using a projector, laser scanner or laser interference-based stripe generating system. When combi
2010-06-01 09:10:3913
Using References to Generate O
This application report describes the process for using references to generate offsets forTexas Instrument’s TLC55XX family data converters.
2010-06-02 08:39:0613
Using the TMS320C5402 DMA Chan
This application report presents a hardware and software solution for using the DMA channels
2010-06-04 16:21:457
ABSTRACTThis application report presents hardware and software solutions for using the DMA
2010-06-06 15:36:2710
Using the AGC,DRC and Beep gen
ABSTRACTThe new AIC devices have the built-in feature of AGC, DRC, and the Beep Generator. Using
2010-06-25 22:54:1620
SPEECH CONTROL FOR CAR USING T
AbstractThis paper presents a design of voice module designed for using in cars. This module
2010-07-05 11:12:0913
Using the CC1000 in On-Off Key
at two different fabs using identical manufacturing processes and two slightly different mask sets. The two chips are ident
2010-07-06 15:11:4420
Using Non-Contact AFM to Image
eithercapillary wetting (“bridging”) orstrong perturbations of the liquidsurface profile. Using a 5500 AFMsystem with Mac M
2010-08-02 11:47:2411
Using the Agilent U2300A Serie
Using the
2010-08-22 12:34:5618
Using the DS4412 to Margin the
Using the
2009-01-06 13:45:20776
Display Backlighting Using Hig
Display Backlighting Using High-Brightness LEDs and SEPIC Power Modules Abstract:
2009-02-06 12:16:381091
Using a UART to Implement a 1-
Using a UA
2009-03-31 22:18:451771
12-Bit Thermometer Using an 8-
12-Bit Thermometer Using an 8-Bit µC and Assembler This application note explains how to implement
2009-03-31 22:25:39730
Using the DS32kHz with Dallas
Using the DS32kHz with Dallas Real-Time Clocks Abstract: This application note describes how
2009-03-31 22:27:51678
White Paper 2: Using the 1-Wir
is a completely open source, portable C library to create a 1-Wire master using the DS2480B serial
2009-04-17 09:37:101021
Abstract: This application note describes how to reduce current consumption when using the DS32kHz
2009-04-17 10:17:42806
This application note explains how to implement a 12-bit digital thermometer using a low-cost
2009-04-17 10:18:351321
Temperature Monitoring Using t
multiple temperatures in a system. This application note explains how to measure temperature using remote sensing diodes in single-ended or diff
2009-04-17 11:36:161788
使用DS1307的PIC单片机-Using a DS1307
Abstract: This application note is intended to demonstrate an application using the DS1307
2009-04-21 09:50:441359
评估马克西姆实时钟表的准确性-Evaluating the
(RTCs) using available accurate time sources and the Maxim evaluation kits. Evaluating the accuracy of Maxim real-time cloc
2009-04-21 10:45:381314
使用DS32kHz达拉斯实时时钟-Using the DS3
2009-04-21 10:49:551099
EconOscillator Comparison
Abstract: Dallas Semiconductor manufactures several EconOscillators™ (DS1065, DS1077/DS1077L, DS1085/DS1085L, and DS1086). Since many of the features of these devices cannot easily be categorized into fields in the on-line parametric
2009-04-22 10:26:47829
DS1077 5V的EconOscillator建筑与在线互
Abstract: The DS1077 is a programmable (via 2-wire) dual-output EconOscillator
2009-04-22 11:00:49516
DS1077L EconOscillator建筑与在线互动式
Abstract: Theory of operation and description of the DS1077 dual-output all-silicon EconOscillator
2009-04-22 11:16:53910
Skew Correction Using Delay Li
Abstract: This application note describes using delay lines to correct system timing or "skew
2009-04-22 11:21:131151
Using the
2009-04-23 08:42:35898
使用DS1086作为单片机的时钟上以降低电磁干扰-Using
Abstract: The DS1086 spread spectrum EconOscillator™ can be used to reduce radiated emissions
2009-04-23 14:34:261452
利用液晶的MAXQ微控制器-Using an LCD wit
using an LCD with a MAXQ Microcontroller. The note covers LCD basics, how to choose one of the available LCD types, and how to connect an LC
2009-04-23 17:20:21760
Using a PC's RS-232 Serial
Using a PC
2009-04-24 15:58:201318
Using Maxim SPI-compatible Dis
Using Maxi
2009-04-26 16:32:40925
Using Maxi
2009-04-27 09:50:061106
利用数字电位器的调节降压DC-DC转换器设计-Using D
an adjustable voltage supply using a MAX1776 step-down DC-DC converter. A reference design using the DS3903 is shown that features the ability to prod
2009-04-28 13:49:322095
Using Dallas' 1-Wire ICs i
design for using Dallas Semiconductor 1-Wire® products with low-side N-channel safety FETs. Critical design considerations concerning the
2009-04-30 14:18:571058
Using the MAXQ3180 Analog Fron
Using the MAXQ3180 Analog Front-End in a Single-Phase Configuration Abstract: This application note
2009-08-11 11:55:35709
Using the Serial Port on the M
Using the Serial Port on the MAXQ610 Microcontroller Abstract: The MAXQ610 microcontroller
2009-08-13 12:05:561342
PLD Programming Using VHDL
本文详细讨论了VHDL语句对PLD设计的影响和设计经验,经典文章,值得仔细阅读消化。, PLD Programming Using VHDL
2012-01-17 11:20:540
DS1086 EconOscillator 可编程时钟发生器
DS1086 EconOscillator™是可编程的时钟发生器,它可以在260kHz至133MHz的频率范围内产生扩展频谱(抖动)方波输出。
2012-03-22 15:43:011175
DS1086L 3.3V扩频EconOscillator
DS1086L EconOscillator™是一种3.3V、可编程时钟发生器,可产生频率在130kHz至66.6MHz、经过频谱扩展(抖动)的方波输出。
2012-03-22 15:45:06863
DS1086,DS1086H,DS1086Z扩频EconOscillator
The DS1086 EconOscillator is a programmable clockgenerator that produces a spread-spectrum
2012-03-23 11:12:3618
ADC Convertor Using the MAX 10 FPGA Development Kit
ADC_Convertor_Using_MAX_10_FPGA_Development_Kit
2015-12-07 18:20:159
Two-Way_Audio_Communications_using_the_CC1110_or_CC2510_and_the_TLV320AIC26_Codec
Two-Way Audio Communications using the CC1110 or CC2510 and the TLV320A
2016-01-12 15:36:0912
(ebook) Chu - FPGA Prototyping Using Verilog Examples
2016-06-03 16:16:5314
DSP applications using C and the TMS320C6x DSK
2016-06-21 16:49:3314
Using the FreeRTOS Real Time Kernel
Free RTOS Book Using the FreeRTOS Real Time Kernel - A Practical Guide - NXP LPC17xx Edition
2016-07-13 15:11:0830
Step-by-step-design-of-a-basic-embedded-system-using-an-Intel-MAX10-FPGA.pdf
2017-01-22 19:43:5122
Topics on Using the LM6181-A New
Topics on Using the LM6181-A New Current Feedback Amplifier
2017-03-23 17:34:500
Using the TMS320VC5509/5510 Enhanced HPI
2017-10-20 11:29:398
Circuit.Cellar.-.Cortex-M3.Applications.Using.Stellaris.MCUs
2017-10-26 09:24:442
ARMCompiler toolchain v5.02 for_using_the_assembler
2017-10-30 09:18:2613
单片机直接驱动段式液晶——Direct Driving of LCD Using General Purpose IO分析
2018-01-18 16:26:4813
单片机C51中interrupt和using应该如何使用详细方法说明
1; interrupt 4 指明是串行口中断; using 0 是第0组寄存器; using 1 是第1组寄存器; using 2 是第2组寄存器; using 3 是第3组寄存器;
2019-09-25 17:17:003
Efficient packet classification using TCAM
Efficient packet classification using TCAM(现代电源技术基础课程)-Efficient packet classification using TCAM
2021-08-04 16:23:0414
Using docker for embedded systems development 用Docker做嵌入式开发,有想法
原文地址:https://dev.to/dalimay28/using-docker-for-embedded-systems-development-b16
2021-11-02 19:05:5912
51单片机编程之中断函数using关键字的作用
2021-11-20 16:36:057
"Scalable, Distributed Systems Using Akka, Spring Boot, DDD, and Java--转"
2021-12-01 18:06:146
已全部加载完成
