The TRF370317 is a low-noise direct quadrature modulator, capable of converting complex modulated signals from baseband or IF directly up to RF. The TRF370317 is a high-performance, superior-linearity device that is ideal to RF frequencies of 400 MHz through 4 GHz. The modulator is implemented as a double-balanced mixer. The RF output block consists of a differential to single-ended converter and an RF amplifier capable of driving a single-ended 50- load without any need of external components. The TRF370317 requires a 1.7-V common-mode voltage for optimum linearity performance.
Frequency (Min) (MHz) |
Frequency (Max) (MHz) |
I/Q Input Common-Mode Voltage (Typ) |
PLL/VCO |
P1dB (Typ) (dBm) |
Output IP3 (Typ) (dBm) |
Noise Floor (Typ) (dBm/Hz) |
Unadjusted Carrier Suppression (Typ) (dBm) |
Unadjusted Sideband Suppression (Typ) (dBc) |
Supply (V) |
Package Group |
Package Size: mm2:W x L (PKG) |
Pin/Package |
TRF370317 | TRF370315 | TRF370333 | TRF370417 | TRF3705 | TRF37T05 |
400 | 350 | 350 | 50 | 300 | 300 |
4000 | 4000 | 4000 | 6000 | 4000 | 4000 |
1.7 | 1.5 | 3.3 | 1.7 | 0.25 | 0.25 |
No | No | No | No | No | No |
12 | 9 | 9 | 12 | 13 | 13 |
26.5 | 23 | 23 | 26.5 | 30 | 30 |
-163 | -163 | -163 | -162 | -160 | -160 |
-40 | -40 | -40 | -38 | -45 | -45 |
-45 | -40 | -40 | -50 | -45 | -45 |
5 | 5 | 5 | 5 | 3.3 | 3.3 |
VQFN | VQFN | VQFN | VQFN | VQFN | VQFN |
24VQFN: 16 mm2: 4 x 4(VQFN) | 24VQFN: 16 mm2: 4 x 4(VQFN) | 24VQFN: 16 mm2: 4 x 4(VQFN) | 24VQFN: 16 mm2: 4 x 4(VQFN) | 24VQFN: 16 mm2: 4 x 4(VQFN) | 24VQFN: 16 mm2: 4 x 4(VQFN) |
24VQFN | 24VQFN | 24VQFN | 24VQFN | 24VQFN | 24VQFN |
