来源:strongerHuang
最近看到有一些网友在讨论关于:瑞萨RA单片机在e2 studio环境下printf编译出错的问题。
这个问题我之前也遇到过,今天就来分享一下我得出的解决办法。
问题点:在e2 studio集成开发环境下,使用串口printf打印时,会类似出现一个这样的错误:
C:/Renesas/RA/e2studio_v2024-10_fsp_v5.6.0/toolchains/gcc_arm/13.2.rel1/bin/../lib/gcc/arm-none-eabi/13.2.1/../../../../arm-none-eabi/bin/ld.exe:C:/Renesas/RA/e2studio_v2024-10_fsp_v5.6.0/toolchains/gcc_arm/13.2.rel1/bin/../lib/gcc/arm-none-eabi/13.2.1/thumb/v8-m.main+dp/hardlibg_nano.a(libc_a-closer.o):infunction `_close_r'(.text._close_r+0xc): undefined reference to `_close' C:/Renesas/RA/e2studio_ -10_fsp_v5.6.0/toolchains/gcc_arm/13.2.rel1/bin/../lib/gcc/arm-none-eabi/13.2.1/../../../../arm-none-eabi/bin/ld.exe:C:/Renesas/RA/e2studio_v2024-10_fsp_v5.6.0/toolchains/gcc_arm/13.2.rel1/bin/../lib/gcc/arm-none-eabi/13.2.1/thumb/v8-m.main+dp/hardlibg_nano.a(libc_a-lseekr.o):infunction `_lseek_r'(.text._lseek_r+0x10): undefined reference to `_lseek' C:/Renesas/RA/e2studio_v2024-10_fsp_v5.6.0/toolchains/gcc_arm/13.2.rel1/bin/../lib/gcc/arm-none-eabi/13.2.1/../../../../arm-none-eabi/bin/ld.exe:C:/Renesas/RA/e2studio_v2024-10_fsp_v5.6.0/toolchains/gcc_arm/13.2.rel1/bin/../lib/gcc/arm-none-eabi/13.2.1/thumb/v8-m.main+dp/hardlibg_nano.a(libc_a-readr.o):infunction `_read_r'(.text._read_r+0x10): undefined reference to `_read' C:/Renesas/RA/e2studio_v2024-10_fsp_v5.6.0/toolchains/gcc_arm/13.2.rel1/bin/../lib/gcc/arm-none-eabi/13.2.1/../../../../arm-none-eabi/bin/ld.exe:C:/Renesas/RA/e2studio_v2024-10_fsp_v5.6.0/toolchains/gcc_arm/13.2.rel1/bin/../lib/gcc/arm-none-eabi/13.2.1/thumb/v8-m.main+dp/hardlibg_nano.a(libc_a-fstatr.o):infunction `_fstat_r'(.text._fstat_r+0xe): undefined reference to `_fstat' C:/Renesas/RA/e2studio_v2024-10_fsp_v5.6.0/toolchains/gcc_arm/13.2.rel1/bin/../lib/gcc/arm-none-eabi/13.2.1/../../../../arm-none-eabi/bin/ld.exe:C:/Renesas/RA/e2studio_v2024-10_fsp_v5.6.0/toolchains/gcc_arm/13.2.rel1/bin/../lib/gcc/arm-none-eabi/13.2.1/thumb/v8-m.main+dp/hardlibg_nano.a(libc_a-isattyr.o):infunction `_isatty_r'(.text._isatty_r+0xc): undefined reference to `_isatty' collect2.exe: error: ld returned1exit status make:***[makefile:96:RA8D1_DEBUG.elf]Error1 BuildFailed.6errors,0warnings. (took 190ms)左右滑动查看全部
网上最多的解决办法
在这个路径下:
项目->C/C++Project Settings->C/C++构建->设置->GUU ArmCrossC Linker->Miscellaneous
左右滑动查看全部
勾选【Use float with nano printf (-u _ printf float)】这个选项,并清空【Other linker flags】里面的内容。
但是,在e2 studio V5版本(比如:V5.6.0)环境下,这个解决方法“失效”了,编译还是会出现【错误】。
网上又有了一种解决办法
在同样的路径下,勾选【Do not use syscalls (--specs=nosys.specs)】这个选项,如下图:
这样,确实能解决【编译出错】的问题,也能正常printf打印输出。
但会出现【警告】,如下图:
还有一种最理想的解决办法
这个办法不会错误,也不会警告,也是我在用。那就是在同样的路径下,【Other linker flags】这里添加:
--specs=rdimon.specs
警告这样的配置之后,编译就会:0错误,0警告。
这里的配置,在e2 studio以前的老版本是默认的,但这后面的版本,这里的配置默认是“空”了,我也搞不懂为啥。
这个解决办法在网上不容找到,我找到了一个地方:
https://community.renesas.com/mcu/ra/f/forum/32521/fsp5-0-0-cannot-print-data-to-uart-by-redirecting-printf
以上三种解决办法,推荐用最后一种。
本文就分享到这里,希望对你有所帮助。
单片机
6078文章
45581浏览量
673732 -
瑞萨
38文章
22518浏览量
91202 -
串口
15文章
1627浏览量
83356 -
Studio
2文章
227浏览量
30795 -
Printf
84浏览量
14824
瑞萨RA8快速上手指南:Cortex-M85内核瑞萨RA8开发环境搭建 并点亮一个LED
瑞萨RA单片机在e2 studio环境下printf编译出错的问题解析
