Grafana 是一个开源数据可视化平台,广泛用于监控和分析系统性能、应用程序指标和其他数据。它支持多种数据源,如 Prometheus、Graphite、InfluxDB 和 MySQL,通过友好的用户界面,用户可以轻松创建和自定义动态仪表板,以实时展示关键指标和数据趋势
华为云端口放行
•服务器放行对应端口 9955
Docker 安装并配置镜像加速
1、购买华为云 Flexus X 实例
Flexus云服务器X实例-华为云 (huaweicloud.com)
2、docker 安装
yuminstall -ydocker-ce
3、验证 Docker 是否安装成功,启动 docker 服务并设置开机自启动,且查看 docker 状态
docker --versionsystemctl enable dockersystemctl start dockersystemctl status docker
4、docker-ce 下载
wget-O/etc/yum.repos.d/docker-ce.repo https://mirrors.huaweicloud.com/docker-ce/linux/centos/docker-ce.repo
5、路径/etc/yum.repos.d 修改配置文件
[docker-ce-stable]name=Docker CEStable -$basearchbaseurl=https://repo.huaweicloud.com/docker-ce/linux/centos/9.9/$basearch/stableenabled=1gpgcheck=1gpgkey=https://repo.huaweicloud.com/docker-ce/linux/centos/gpg[docker-ce-stable-debuginfo]name=Docker CEStable -Debuginfo $basearchbaseurl=https://repo.huaweicloud.com/docker-ce/linux/centos/9.9/debug-$basearch/stableenabled=0gpgcheck=1gpgkey=https://repo.huaweicloud.com/docker-ce/linux/centos/gpg[docker-ce-stable-source]name=Docker CEStable -Sourcesbaseurl=https://repo.huaweicloud.com/docker-ce/linux/centos/9.9/source/stableenabled=0gpgcheck=1gpgkey=https://repo.huaweicloud.com/docker-ce/linux/centos/gpg[docker-ce-test]name=Docker CETest -$basearchbaseurl=https://repo.huaweicloud.com/docker-ce/linux/centos/9.9/$basearch/testenabled=0gpgcheck=1gpgkey=https://repo.huaweicloud.com/docker-ce/linux/centos/gpg[docker-ce-test-debuginfo]name=Docker CETest -Debuginfo $basearchbaseurl=https://repo.huaweicloud.com/docker-ce/linux/centos/9.9/debug-$basearch/testenabled=0gpgcheck=1gpgkey=https://repo.huaweicloud.com/docker-ce/linux/centos/gpg[docker-ce-test-source]name=Docker CETest -Sourcesbaseurl=https://repo.huaweicloud.com/docker-ce/linux/centos/9.9/source/testenabled=0gpgcheck=1gpgkey=https://repo.huaweicloud.com/docker-ce/linux/centos/gpg[docker-ce-nightly]name=Docker CENightly -$basearchbaseurl=https://repo.huaweicloud.com/docker-ce/linux/centos/9.9/$basearch/nightlyenabled=0gpgcheck=1gpgkey=https://repo.huaweicloud.com/docker-ce/linux/centos/gpg[docker-ce-nightly-debuginfo]name=Docker CENightly -Debuginfo $basearchbaseurl=https://repo.huaweicloud.com/docker-ce/linux/centos/9.9/debug-$basearch/nightlyenabled=0gpgcheck=1gpgkey=https://repo.huaweicloud.com/docker-ce/linux/centos/gpg[docker-ce-nightly-source]name=Docker CENightly -Sourcesbaseurl=https://repo.huaweicloud.com/docker-ce/linux/centos/9.9/source/nightlyenabled=0gpgcheck=1gpgkey=https://repo.huaweicloud.com/docker-ce/linux/centos/gpg
6、清除和构建缓存
yumclean allyummakecache
7、docker 配置镜像加速(在华为云镜像中心可获取自己的镜像加速配置)
8、创建镜像加速配置文件
vim/etc/docker/daemon.json
{"registry-mirrors":[ "https://fd0cfec0ac0d446db7fd9d27e92d4a8e.mirror.swr.myhuaweicloud.com"]}
9、重新加载配置文件,重新启动 docker,查看是否配置成功
systemctldaemon-reloadsystemctlrestart docker.service
10、docker info 查看配置信息,是否配置成功镜像加速
dockerinfo
搭建 Grafana 开源数据可视化平台
1、拉取 Grafana 镜像
dockerpull grafana/grafana
2、检查镜像是否拉取成功
dockerimages
3、运行容器
dockerrun --restartalways -p3000:3000 --namegrafana -dgrafana/grafana
docker run:启动一个新的容器实例。
--restart always:设置容器在 Docker 服务重启时总是自动重启,确保 Grafana 持续运行。
-p 3000:3000:将主机的 3000 端口映射到容器的 3000 端口,使得外部可以通过访问主机的 3000 端口来访问 Grafana。
--name grafana:为容器指定一个名称"grafana",方便后续管理和查找。
-d:在后台运行容器(即分离模式),允许用户在启动容器后继续使用终端。
grafana/grafana:指定要使用的镜像,这里是 Grafana 的官方镜像
4、检查容器状态
docker ps
5、关闭防火墙
systemctlstop firewalldsystemctlstatus firewalld
6、浏览器地址访问公网 IP:3000
7、默认情况下,Grafana 的登录账号和密码都是:
•用户名: admin
•密码: admin
8、成功搭建
9、平台语言更换
总结
华为云服务器 Flexus X 实例,Docker 集成搭建 Grafana 开源数据可视化平台,监控和分析系统性能、应用程序指标和其他数据,通过友好的用户界面,用户可以轻松创建和自定义动态仪表板,以实时展示关键指标和数据趋势,如果有小伙伴同样需要搭建,可以购买华为云服务器搭建,目前服务器正在大促性价比非常高!
数据可视化
502浏览量
11533 -
云服务器
840浏览量
14747 -
华为云
3文章
2836浏览量
19372
森林消防智慧预警技术实现:火灾监测 Web GIS 可视化平台搭建
KubePi:开源Kubernetes可视化管理面板,让集群管理如此简单
DRAM 暴涨 171%! 171% 下的企业突围:华为云 Flexus X 云服务器成 IT 成本管控利器
工业物联网可视化平台是什么?有什么功能?
工业可视化平台是什么
香港服务器支持Docker和Kubernetes吗?
华纳云服务器Linux系统日志集中化管理平台搭建
如何使用协议分析仪进行数据分析与可视化
恒讯科技分析:云储存服务器搭建教程
组态可视化平台如何监控欧姆龙PLC的数据变量
