1.1、单次定时任务实现
boost 的asio库里有几个定时器,老的有 deadline_timer , 还有三个可配合 C++11 的 chrono 使用的 high_resolution_timer 、 steady_timer 和 system_timer 。deadline_timer是asio早期版本提供的定时器,使用boost.date_time库提供时间支持,deadline_timer会被逐渐淘汰。
仅仅固定时间后去执行某任务,可以使用boost中的asio库提供了steady_timer定时器,定时器的用法也是比较简单的,基本上分三步。创建 io_service , 创建timer 并设置等待时间, 调用wait 或async_wait 等待.
其中wait是同步等待,async_wait是异步等待,需要给一个回调给它。
具体实现如下:
#include
#include
#include
void executeMission()
std::cout<<"excute mission"<}
int main()
boost::asio::io_context io_ctx;
boost::asio::steady_timer asio_steady_timer{io_ctx,
std::chrono::seconds{3}};
asio_steady_timer.async_wait([](const boost::system::error_code &ec)
{std::cout<<"excute mission"< //asio_steady_timer.async_wait(&executeMission);
std::cout<<"start io_service"<
io_ctx.run();
return 0;
1.2、执行固定次数的定时任务
为了实现重复定时,需要在回调函数里修改steady_timer的过期时间,因此要把steady_timer传给回调函数:
#include
#include
#include
int count = 0;
void executeMission(const boost::system::error_code& e, boost::asio::steady_timer *t)
std::cout << "execute mission" << std::endl;
if(count < 10) {
++count;
t->expires_at(t->expiry() + boost::asio::chrono::seconds(1));
t->async_wait(boost::bind(executeMission, boost::asio::placeholders::error, t));
int main()
boost::asio::steady_timer t(io_ctx, boost::asio::chrono::seconds(1));
t.async_wait(boost::bind(executeMission, boost::asio::placeholders::error, &t));
io_ctx.run();
std::cout << "time: " << count << std::endl;
return 0;
用类封装下:
#include
#include
#include
#include
#include
#include
class printer {
private:
boost::asio::io_context io_;
boost::asio::steady_timer timer_;
int count_;
void print() {
if (count_ < 500) {
std::cout << count_ << "n";
++count_;
timer_.expires_from_now(std::chrono::milliseconds (50));
timer_.async_wait(std::bind(&printer::print, this));
else
std::cout << "Final count is " << count_ << "n";
delete this;
void run() {
io_.run();
printer()
: timer_(io_),
count_(0) {
~printer() {
public:
static printer* Create(){
return new printer;
void start() {
std::thread t;
t = std::thread(std::mem_fn(&printer::run), this);
t.detach();
void foo()
printer *p = printer::Create();
p->start();
int main() {
foo();
std::cin.get();
return 0;
输出:
490
491
492
493
494
495
496
497
498
499
Final count is 500
1.3、在多线程程序中处理定时回调(多线程处理多个定时任务)
由一个线程来调用io_context::run()导致了回调函数不能够并发的运行。为了避免这个限制,一个直接的方法就是用线程池来调用io_context::run()。然而,为了能够并发的处理回调,还需要一种方法来同步回调对共享的非线程安全的资源的访问。
同一个 io_context 可以同时给多个 timer使下
实例1:
#include
#include
#include
#include
#include
#include
#include
class printer2 {
private:
int count_;
void print() {
if (count_ < 10) {
++count_;
timer_.expires_from_now(std::chrono::milliseconds (500));
timer_.async_wait(std::bind(&printer2::print, this));
else
delete this;
printer2(boost::asio::io_context &io)
: timer_(io,std::chrono::milliseconds (500)),
count_(0) {
~printer2() {
public:
static printer2* Create(boost::asio::io_context &io){
return new printer2(io);
int main() {
boost::asio::io_context io;
printer2::Create(io);
io.run();
//boost::thread t1(boost::bind(&boost::asio::io_context::run, &io));
std::cin.get();
return 0;
输出;
7
7
7
7
8
8
8
8
9
9
9
9
Final count is 10
Final count is 10
Final count is 10
Final count is 10
实例2:
#include
#include
#include
#include
#include
#include
#include
class Timer
public:
Timer(boost::asio::io_context& io_ctx, boost::asio::io_context::strand& strand_1, unsigned int timeout_, unsigned int id_): id(id_), count(0), timeout(timeout_), t(io_ctx, boost::asio::chrono::milliseconds(timeout_)), strand_(strand_1)
t.async_wait(boost::asio::bind_executor(strand_, boost::bind(&Timer::OnTimerCallBack, this)));
private:
void OnTimerCallBack()
if(count < 10) {
++count;
std::cout << " Id:" << id << " Count:" << count << std::endl;
t.expires_at(t.expiry() + boost::asio::chrono::milliseconds(timeout));
private:
unsigned int id;
unsigned int count;
unsigned int timeout;
boost::asio::steady_timer t;
boost::asio::io_context::strand& strand_;
int main()
boost::asio::io_context::strand strand_(io_ctx);
Timer timer1(io_ctx, strand_, 1000, 1);
Timer timer2(io_ctx, strand_, 1000, 2);
Timer timer3(io_ctx, strand_, 1000, 3);
boost::thread t1(boost::bind(&boost::asio::io_context::run, &io_ctx));
boost::thread t2(boost::bind(&boost::asio::io_context::run, &io_ctx));
t1.join();
t2.join();
return 0;
1.4、循环执行定时任务
#include
#include
//使用boost.chrono代替std.chrono,
#define BOOST_ASIO_DISABLE_STD_CHRONO
#include
#include
#include
#include
class Timer
public:
Timer() :work_(io_), timer_(io_){}
public:
boost::thread_group thgp_;
boost::asio::io_context::work work_;
public:
void init()
boost::system::error_code errCode;
thgp_.create_thread(boost::bind(&boost::asio::io_service::run, boost::ref(io_), errCode));
timer_.expires_from_now(boost::chrono::milliseconds(1000)); //设置过期时间长度
timer_.async_wait(boost::bind(&Timer::excuteMission, this, boost::asio::placeholders::error));//异步等待
std::cout << "initialize:" << localTime() << std::endl;
//由Console可知, 函数立即返回了, 定时器的expires_from_now是由完成端口处理的
void stop()
timer_.cancel(); // 取消所有handler
work_.~work();
thgp_.join_all();
std::cout << "Stop:" << localTime() << std::endl;
static std::string localTime()
return boost::posix_time::to_simple_string(boost::posix_time::microsec_clock::local_time());
void excuteMission(const boost::system::error_code& ec)
std::cout<<"mission to print time:"< timer_.expires_from_now(boost::chrono::milliseconds(1000));
timer_.async_wait(boost::bind(&Timer::excuteMission, boost::ref(*this), _1));
#if 0
timer_.async_wait(boost::bind(&Timer::excuteMission, this, _1));
#endif
int main(int argc, char** argv)
Timer t;
t.init();
while(true)
std::cout<<"execute other mission"< boost::this_thread::sleep_for(boost::chrono::milliseconds(1000));
t.stop();
std::cout << "press ENTER to exit..." << std::endl;
// std::cin.sync();
return 0;
().c_str()<<">
2、实现一个定时器执行定时任务
定时器一般支持单线程就够了,一般使用方法见下面代码。如果需要多线程怎么办,笔者一般用一个简单的办法:多线程的业务线程中不包含定时器管理器,单独启一个线程用来管理所有定时器,当时间触发时,向业务线程投递定时器消息即可。
2.1.最小堆实现
头文件min_heap.h
#ifndef TIMERMANAGER_H
#define TIMERMANAGER_H
#include
#include
namespace MinHeap {
class TimerManager;
class Timer
public:
enum TimerType { ONCE, CIRCLE };
Timer(TimerManager& manager);
~Timer();
template
void Start(Fun fun, unsigned interval, TimerType timeType = CIRCLE);
void Stop();
private:
void OnTimer(unsigned long long now);
private:
friend class TimerManager;
TimerManager& manager_;
TimerType timerType_;
boost::function timerFun_;
unsigned interval_;
unsigned long long expires_;
size_t heapIndex_;
class TimerManager
public:
static unsigned long long GetCurrentMillisecs();
void DetectTimers();
private:
friend class Timer;
void AddTimer(Timer* timer);
void RemoveTimer(Timer* timer);
void UpHeap(size_t index);
void DownHeap(size_t index);
void SwapHeap(size_t, size_t index2);
private:
struct HeapEntry
unsigned long long time;
Timer* timer;
std::vector heap_;
template
void Timer::Start(Fun fun, unsigned interval, TimerType timeType)
Stop();
interval_ = interval;
timerFun_ = fun;
timerType_ = timeType;
expires_ = interval_ + TimerManager::GetCurrentMillisecs();
manager_.AddTimer(this);
#endif // TIMERMANAGER_H(void)>
源文件min_heap.cpp
#define _CRT_SECURE_NO_WARNINGS
# include
namespace MinHeap {
Timer::Timer(TimerManager& manager)
: manager_(manager)
, heapIndex_(-1)
Timer::~Timer()
Stop();
void Timer::Stop()
if (heapIndex_ != -1)
manager_.RemoveTimer(this);
heapIndex_ = -1;
void Timer::OnTimer(unsigned long long now)
if (timerType_ == Timer::CIRCLE)
expires_ = interval_ + now;
else
heapIndex_ = -1;
timerFun_();
// TimerManager
void TimerManager::AddTimer(Timer* timer)
timer->heapIndex_ = heap_.size();
HeapEntry entry = { timer->expires_, timer };
heap_.push_back(entry);
UpHeap(heap_.size() - 1);
void TimerManager::RemoveTimer(Timer* timer)
size_t index = timer->heapIndex_;
if (!heap_.empty() && index < heap_.size())
if (index == heap_.size() - 1)
heap_.pop_back();
else
SwapHeap(index, heap_.size() - 1);
heap_.pop_back();
size_t parent = (index - 1) / 2;
if (index > 0 && heap_[index].time < heap_[parent].time)
UpHeap(index);
else
DownHeap(index);
void TimerManager::DetectTimers()
unsigned long long now = GetCurrentMillisecs();
while (!heap_.empty() && heap_[0].time <= now)
Timer* timer = heap_[0].timer;
RemoveTimer(timer);
timer->OnTimer(now);
void TimerManager::UpHeap(size_t index)
while (index > 0 && heap_[index].time < heap_[parent].time)
SwapHeap(index, parent);
index = parent;
void TimerManager::DownHeap(size_t index)
size_t child = index * 2 + 1;
while (child < heap_.size())
size_t minChild = (child + 1 == heap_.size() || heap_[child].time < heap_[child + 1].time)
? child : child + 1;
if (heap_[index].time < heap_[minChild].time)
break;
SwapHeap(index, minChild);
index = minChild;
void TimerManager::SwapHeap(size_t index1, size_t index2)
HeapEntry tmp = heap_[index1];
heap_[index1] = heap_[index2];
heap_[index2] = tmp;
heap_[index1].timer->heapIndex_ = index1;
heap_[index2].timer->heapIndex_ = index2;
unsigned long long TimerManager::GetCurrentMillisecs()
#ifdef _MSC_VER
_timeb timebuffer;
_ftime(&timebuffer);
unsigned long long ret = timebuffer.time;
ret = ret * 1000 + timebuffer.millitm;
return ret;
#else
timeval tv;
::gettimeofday(&tv, 0);
unsigned long long ret = tv.tv_sec;
return ret * 1000 + tv.tv_usec / 1000;
#endif
2.2、时间轮实现
头文件timer_wheel.h
#define TIMERWHEEL_H
#pragma once
#include
#include
#include
namespace TimerWheel{
class TimerManager;
class Timer
public:
enum TimerType {ONCE, CIRCLE};
~Timer();
template
void Stop();
private:
private:
unsigned interval_;
int vecIndex_;
std::list::iterator itr_;
class TimerManager
public:
TimerManager();
private:
friend class Timer;
int Cascade(int offset, int index);
private:
typedef std::list TimeList;
std::vector tvec_;
unsigned long long checkTime_;
template
inline void Timer::Start(Fun fun, unsigned interval, TimerType timeType)
Stop();
timerFun_ = fun;
#endif // TIMERWHEEL_H*>*>(void)>
源文件timer_wheel.cpp
# include
#define TVN_BITS 6
#define TVR_BITS 8
#define TVN_SIZE (1 << TVN_BITS)
#define TVR_SIZE (1 << TVR_BITS)
#define TVN_MASK (TVN_SIZE - 1)
#define TVR_MASK (TVR_SIZE - 1)
#define OFFSET(N) (TVR_SIZE + (N) *TVN_SIZE)
#define INDEX(V, N) ((V >> (TVR_BITS + (N) *TVN_BITS)) & TVN_MASK)
: manager_(manager)
, vecIndex_(-1)
Timer::~Timer()
Stop();
void Timer::Stop()
if (vecIndex_ != -1)
vecIndex_ = -1;
else
vecIndex_ = -1;
timerFun_();
// TimerManager
TimerManager::TimerManager()
tvec_.resize(TVR_SIZE + 4 * TVN_SIZE);
checkTime_ = GetCurrentMillisecs();
unsigned long long expires = timer->expires_;
unsigned long long idx = expires - checkTime_;
if (idx < TVR_SIZE)
timer->vecIndex_ = expires & TVR_MASK;
else if (idx < 1 << (TVR_BITS + TVN_BITS))
timer->vecIndex_ = OFFSET(0) + INDEX(expires, 0);
else if (idx < 1 << (TVR_BITS + 2 * TVN_BITS))
timer->vecIndex_ = OFFSET(1) + INDEX(expires, 1);
else if (idx < 1 << (TVR_BITS + 3 * TVN_BITS))
timer->vecIndex_ = OFFSET(2) + INDEX(expires, 2);
else if ((long long) idx < 0)
timer->vecIndex_ = checkTime_ & TVR_MASK;
else
if (idx > 0xffffffffUL)
idx = 0xffffffffUL;
expires = idx + checkTime_;
timer->vecIndex_ = OFFSET(3) + INDEX(expires, 3);
TimeList& tlist = tvec_[timer->vecIndex_];
tlist.push_back(timer);
timer->itr_ = tlist.end();
--timer->itr_;
tlist.erase(timer->itr_);
while (checkTime_ <= now)
int index = checkTime_ & TVR_MASK;
if (!index &&
!Cascade(OFFSET(0), INDEX(checkTime_, 0)) &&
!Cascade(OFFSET(1), INDEX(checkTime_, 1)) &&
!Cascade(OFFSET(2), INDEX(checkTime_, 2)))
Cascade(OFFSET(3), INDEX(checkTime_, 3));
++checkTime_;
TimeList& tlist = tvec_[index];
TimeList temp;
temp.splice(temp.end(), tlist);
for (TimeList::iterator itr = temp.begin(); itr != temp.end(); ++itr)
(*itr)->OnTimer(now);
int TimerManager::Cascade(int offset, int index)
TimeList& tlist = tvec_[offset + index];
TimeList temp;
AddTimer(*itr);
return index;
#ifdef _MSC_VER
_timeb timebuffer;
return ret;
#else
timeval tv;
#endif
2.3 定时器应用
main.cpp
#include
#include
#include "timer_wheel.h"
#include "min_heap.h"
#include
void TimerHandler()
std::chrono::steady_clock::duration d =
std::chrono::steady_clock::now().time_since_epoch();
std::chrono::microseconds mic = std::chrono::duration_cast(d);
std::cout << "Timer:"<}
typedef void (*Function)();
int main()
// MinHeap::TimerManager tm;
// MinHeap::Timer t(tm);
TimerWheel::TimerManager tm;
TimerWheel::Timer t(tm);
t.Start(&TimerHandler, 1000);
while (true)
tm.DetectTimers();
std::this_thread::sleep_for(std::chrono::milliseconds(1000));
std::cin.get();
return 0;
输出:
Timer:6675739056
Timer:6676739783
Timer:6677740959
Timer:6678746422
Timer:6679749721
Timer:6680751169
Timer:6681754799
Timer:6682754395
Timer:6683762516
^CPress to close this window...
定时器
23文章
3373浏览量
124554 -
Boost
5文章
390浏览量
51298 -
函数
3文章
4422浏览量
67851 -
C++
22文章
2130浏览量
77378
SpringBoot如何实现动态增删启停定时任务
Python定时任务的实现方式
解析Golang定时任务库gron设计和原理
求一种SpringBoot定时任务动态管理通用解决方案
SpringBoot如何实现定时任务(上)
Spring Boot中整合两种定时任务的方法
定时器如何实现定时任务
