Intel 6th & 7th Gen Core i3/i5/i7 CPU (LGA1151) with H110, 6*COM, 12*USB, 1*LAN, 1*Mini-PCIe
规格
| General | |
| CPU | Intel® Pentium®/ Celeron®/ 6th and 7thGeneration CoreTM i3/i5/i7 CPU, LGA1151 |
| Chipset | Intel® H110 Chipset, TDP 6W |
| Memory | Up to 16 GB DDR4 2133/1866 MHz, 1*DIMM |
| Storage | 2*SATA 3.0, 1*mSATA |
| Expansion Interface | 1*Mini-PCIe (mSATA or Wifi/3G/4G Supported) |
| BIOS | AMI UEFI BIOS |
| System | Windows7/8/10, Linux |
| I/O Interface | |
| Serial Port | 6*RS232 |
| USB | 2*USB 3.0, 10*USB 2.0 (4*on rear I/O, 8*header) |
| Ethernet | 1*Realtek® PCI-E LAN for 1000Mbps |
| Audio | Realtek® ALC662 5.1 channel HDA Codec, supports MIC/Line-out Ports |
| PS/2 | 2*PS/2 (Keyboard and Mouse Supported) |
| Parallel Port | 1*LPT |
| GPIO | 8 programmable GPIO |
| Feature Interface | Null |
| Display | |
| Display Interface |
1*VGA: max resolution up to 1920*1200@60Hz |
| Multiple Display | Dual |
| Mechanical & Environment | |
| Dimension | Mini-ITX, 170*170mm |
| Power Input | ATX PSU |
| Temperature | Operation: 0℃~60℃, Storage: -25℃~75℃ |
| Relative Humidity | Operation: 10%~90%, Storage: 5%~95%, non-condensing |
举报投诉
WINDOWS
4文章
3706浏览量
94330 -
嵌入式主板
7文章
6107浏览量
37164 -
信步科技
7文章
264浏览量
7969
热点推荐
信步科技SV1a-34516P特征英文版
Input
Intel Apollo Lake Celeron N3450 CPU
6*COM, 10*USB, 1*1000 Mbps LAN
Supports triple display
信步科技SV1a-H1116P规格英文版
Intel 6th & 7th Gen Core i3/i5/i7 CPU (LGA1151) with H110, 6*COM, 10*USB, 1*LAN, 2*Mini-PCIe
信步科技SV1-H2726C规格英文版
H270 chipset
Double-layer Rear I/O which can expand to 18*COM and 18*USB (use SV-M5 I/O Extension
信步科技SV1-H1126C规格英文版
Intel 6th & 7th Gen Core i3/i5/i7 CPU (LGA1151) with H110, Double-layer Rear I/O which can expand
信步科技SV1-H611A-B主板规格英文版
Intel® 2nd & 3rd Core i3/i5/i7 Gen CPU (LGA1155) with H61, 10*COM, 1*LAN, 1*PCI-E, 1*Mini-PC
信步科技SV1-H6116主板规格英文版
Intel 2nd & 3rd Core i3/i5/i7 Gen CPU (LGA1155) with H61, 6*COM, 1*LAN, 1*PCI-E 16X, 1*Mini-
信步科技SV1-H812C主板规格英文版
Intel 4th Gen Core i3/i5/i7 CPU (LGA1150) with H81, 12*COM, 10*USB, 2*LAN, 1*PCI-E 16X, 1*Mini-PCIe
信步科技SV1-H812C-A1主板规格英文版
Intel® 4th Gen Core i3/i5/i7 CPU (LGA1150) with H81, 12*COM, 2*LAN, 1*PCI-E 16X, 1*Mini-PCIe
信步科技SV1-H811A主板规格英文版
Intel® 4th Gen Core i3/i5/i7 CPU (LGA1150) with H81, 10*COM, 1*LAN, 1*PCI-E 16X, 1*Mini-PCIe
信步科技SV1-H8116主板规格英文版
Intel 4th Gen Core i3/i5/i7 CPU (LGA1150) with H81, 6*COM, 1*LAN, 1*PCI-E 16X, 1*Mini-PCIe
信步科技SV1a-H8112P-A1主板规格英文版
Intel 4th Gen Core i3/i5/i7 CPU (LGA1150) with H81, 1*VGA, 1*HDMI, Supports OPS, 4K UHD, DC 19V Input
信步科技SV4-H8134主板规格英文版
Intel LGA1150 CPU with H81, 3*PCI-E, 4*PCI, 1*Mini-PCIe, 1*DVI, 6*COM, 2*LAN, ATX (305*220mm)
信步科技SV1-H1116特征英文版
