告别加班!Python脚本实现运维工作自动化的5个实用案例
前言:还在为重复性运维工作而烦恼?每天被各种告警、监控、部署搞得焦头烂额?作为一名有10年经验的运维老司机,今天分享5个超实用的Python自动化脚本,让你的运维工作效率提升300%!这些都是我在生产环境中实际使用的案例,代码简洁高效,拿来即用!
案例1:批量服务器健康检查脚本
痛点:每天早上需要检查几十台服务器的CPU、内存、磁盘使用情况,手动登录太费时。
解决方案:一键批量检查,异常自动告警!
#!/usr/bin/env python3 importpsutil importsmtplib fromemail.mime.textimportMIMEText importjson fromdatetimeimportdatetime classServerHealthChecker: def__init__(self, thresholds=None): self.thresholds = thresholdsor{ 'cpu_percent':80, 'memory_percent':85, 'disk_percent':90 } self.alerts = [] defcheck_system_health(self): """检查系统健康状况""" health_data = { 'timestamp': datetime.now().strftime('%Y-%m-%d %H:%M:%S'), 'hostname': psutil.boot_time(), 'cpu_percent': psutil.cpu_percent(interval=1), 'memory': psutil.virtual_memory(), 'disk': psutil.disk_usage('/'), 'processes':len(psutil.pids()) } # CPU检查 ifhealth_data['cpu_percent'] >self.thresholds['cpu_percent']: self.alerts.append(f" CPU使用率过高:{health_data['cpu_percent']:.1f}%") # 内存检查 memory_percent = health_data['memory'].percent ifmemory_percent >self.thresholds['memory_percent']: self.alerts.append(f" 内存使用率过高:{memory_percent:.1f}%") # 磁盘检查 disk_percent = (health_data['disk'].used / health_data['disk'].total) *100 ifdisk_percent >self.thresholds['disk_percent']: self.alerts.append(f" 磁盘使用率过高:{disk_percent:.1f}%") returnhealth_data,self.alerts defsend_alert_email(self, alerts, to_email): """发送告警邮件""" ifnotalerts: return msg = MIMEText(' '.join(alerts),'plain','utf-8') msg['Subject'] =f' 服务器健康检查告警 -{datetime.now().strftime("%Y-%m-%d %H:%M")}' msg['From'] ='monitor@company.com' msg['To'] = to_email # 这里需要配置SMTP服务器 print(f"告警邮件内容: {chr(10).join(alerts)}") # 使用示例 if__name__ =="__main__": checker = ServerHealthChecker() health_data, alerts = checker.check_system_health() print(f" 系统健康检查完成 -{health_data['timestamp']}") print(f" CPU:{health_data['cpu_percent']:.1f}%") print(f" 内存:{health_data['memory'].percent:.1f}%") print(f" 磁盘:{(health_data['disk'].used / health_data['disk'].total *100):.1f}%") ifalerts: checker.send_alert_email(alerts,'admin@company.com')
效果:原本需要30分钟的检查工作,现在1分钟搞定!
案例2:自动化日志分析与异常检测
痛点:每天几GB的日志文件,人工查找异常像大海捞针。
解决方案:智能分析日志,自动提取关键异常信息!
#!/usr/bin/env python3 importre importos fromcollectionsimportCounter, defaultdict fromdatetimeimportdatetime, timedelta importgzip classLogAnalyzer: def__init__(self, log_path): self.log_path = log_path self.error_patterns = [ r'ERROR|FATAL|CRITICAL', r'Exception|Error|Failed', r'timeout|refused|denied', r'5d{2}s', # HTTP 5xx错误 ] self.results = defaultdict(list) defparse_log_line(self, line): """解析日志行,提取时间戳、级别、消息""" # 匹配常见日志格式:2024-01-15 1045 [ERROR] message pattern =r'(d{4}-d{2}-d{2}sd{2}:d{2}:d{2})s+[(w+)]s+(.*)' match= re.match(pattern, line) ifmatch: return{ 'timestamp':match.group(1), 'level':match.group(2), 'message':match.group(3) } returnNone defanalyze_errors(self, hours_back=24): """分析指定时间内的错误""" cutoff_time = datetime.now() - timedelta(hours=hours_back) error_counter = Counter() error_details = [] # 支持压缩日志 open_func = gzip.openifself.log_path.endswith('.gz')elseopen try: withopen_func(self.log_path,'rt', encoding='utf-8')asf: forline_num, lineinenumerate(f,1): parsed =self.parse_log_line(line.strip()) ifnotparsed: continue # 检查是否在时间范围内 try: log_time = datetime.strptime(parsed['timestamp'],'%Y-%m-%d %H:%M:%S') iflog_time < cutoff_time: continue except ValueError: continue # 检查是否匹配错误模式 for pattern in self.error_patterns: if re.search(pattern, line, re.IGNORECASE): error_counter[parsed['level']] += 1 error_details.append({ 'line': line_num, 'timestamp': parsed['timestamp'], 'level': parsed['level'], 'message': parsed['message'][:100] + '...' if len(parsed['message']) >100elseparsed['message'] }) break exceptExceptionase: print(f" 分析日志文件失败:{e}") returnNone return{ 'error_summary':dict(error_counter), 'error_details': error_details[-10:], # 只返回最近10条 'total_errors':sum(error_counter.values()) } defgenerate_report(self, analysis_result): """生成分析报告""" ifnotanalysis_result: return" 日志分析失败" report = [ f" 日志分析报告 -{datetime.now().strftime('%Y-%m-%d %H:%M:%S')}", f" 日志文件:{os.path.basename(self.log_path)}", f" 总错误数:{analysis_result['total_errors']}", "", " 错误级别统计:" ] forlevel, countinanalysis_result['error_summary'].items(): report.append(f" {level}:{count}次") report.append(" 最近错误详情:") forerrorinanalysis_result['error_details']: report.append(f" [{error['timestamp']}]{error['level']}:{error['message']}") return' '.join(report) # 使用示例 if__name__ =="__main__": # 替换为实际日志路径 log_file ="/var/log/application.log" ifos.path.exists(log_file): analyzer = LogAnalyzer(log_file) result = analyzer.analyze_errors(hours_back=24) report = analyzer.generate_report(result) print(report) else: print(f" 日志文件不存在:{log_file}")
效果:自动识别异常模式,快速定位问题,节省80%的日志分析时间!
案例3:自动化部署脚本
痛点:每次发版都要重复执行一堆命令,容易出错,效率低。
解决方案:一键自动化部署,支持回滚,安全可靠!
importos
importsubprocess
importjson
importshutil
importtime
classAutoDeployer:
def__init__(self, config_file="deploy_config.json"):
self.config =self.load_config(config_file)
self.backup_dir =self.config.get('backup_dir','/backup')
self.deploy_log = []
defload_config(self, config_file):
"""加载部署配置"""
default_config = {
"app_name":"myapp",
"deploy_path":"/opt/myapp",
"git_repo":"git@github.com:company/myapp.git",
"branch":"main",
"backup_dir":"/backup",
"services": ["myapp"],
"health_check_url":"http://localhost:8080/health",
"rollback_keep":3
ifos.path.exists(config_file):
withopen(config_file,'r')asf:
user_config = json.load(f)
default_config.update(user_config)
returndefault_config
deflog(self, message, level="INFO"):
"""记录部署日志"""
timestamp = datetime.now().strftime('%Y-%m-%d %H:%M:%S')
log_entry =f"[{timestamp}]{level}:{message}"
print(log_entry)
self.deploy_log.append(log_entry)
defrun_command(self, command, check=True):
"""执行shell命令"""
self.log(f"执行命令:{command}")
try:
result = subprocess.run(
command,
shell=True,
capture_output=True,
text=True,
check=check
ifresult.stdout:
self.log(f"输出:{result.stdout.strip()}")
returnresult
exceptsubprocess.CalledProcessErrorase:
self.log(f"命令执行失败:{e}","ERROR")
self.log(f"错误输出:{e.stderr}","ERROR")
raise
defcreate_backup(self):
"""创建当前版本备份"""
ifnotos.path.exists(self.config['deploy_path']):
self.log("部署目录不存在,跳过备份")
returnNone
timestamp = datetime.now().strftime('%Y%m%d_%H%M%S')
backup_name =f"{self.config['app_name']}_{timestamp}"
backup_path = os.path.join(self.backup_dir, backup_name)
os.makedirs(self.backup_dir, exist_ok=True)
shutil.copytree(self.config['deploy_path'], backup_path)
self.log(f"创建备份:{backup_path}")
returnbackup_path
defdeploy_new_version(self):
"""部署新版本"""
# 创建临时目录
temp_dir =f"/tmp/{self.config['app_name']}_deploy_{int(time.time())}"
try:
# 克隆代码
self.run_command(f"git clone -b{self.config['branch']}{self.config['git_repo']}{temp_dir}")
# 停止服务
forserviceinself.config['services']:
self.run_command(f"systemctl stop{service}", check=False)
# 备份当前版本
backup_path =self.create_backup()
# 部署新版本
ifos.path.exists(self.config['deploy_path']):
shutil.rmtree(self.config['deploy_path'])
shutil.copytree(temp_dir,self.config['deploy_path'])
# 设置权限
self.run_command(f"chown -R appuser:appuser{self.config['deploy_path']}")
# 启动服务
self.run_command(f"systemctl start{service}")
self.run_command(f"systemctl enable{service}")
# 健康检查
ifself.health_check():
self.log(" 部署成功!")
self.cleanup_old_backups()
returnTrue
else:
self.log(" 健康检查失败,开始回滚","ERROR")
ifbackup_path:
self.rollback(backup_path)
returnFalse
exceptExceptionase:
self.log(f"部署失败:{str(e)}","ERROR")
returnFalse
finally:
# 清理临时目录
ifos.path.exists(temp_dir):
shutil.rmtree(temp_dir)
defhealth_check(self, max_retries=5):
"""健康检查"""
importrequests
foriinrange(max_retries):
try:
self.log(f"健康检查 ({i+1}/{max_retries})")
response = requests.get(
self.config['health_check_url'],
timeout=10
ifresponse.status_code ==200:
self.log(" 健康检查通过")
returnTrue
exceptExceptionase:
self.log(f"健康检查失败:{e}")
ifi < max_retries - 1:
time.sleep(10)
return False
def rollback(self, backup_path):
"""回滚到指定备份"""
try:
# 停止服务
for service in self.config['services']:
self.run_command(f"systemctl stop {service}", check=False)
# 恢复备份
if os.path.exists(self.config['deploy_path']):
shutil.copytree(backup_path, self.config['deploy_path'])
# 启动服务
self.run_command(f"systemctl start {service}")
self.log(" 回滚完成")
except Exception as e:
self.log(f"回滚失败: {str(e)}", "ERROR")
def cleanup_old_backups(self):
"""清理旧备份"""
if not os.path.exists(self.backup_dir):
return
backups = [d for d in os.listdir(self.backup_dir)
if d.startswith(self.config['app_name'])]
backups.sort(reverse=True)
# 保留指定数量的备份
for backup in backups[self.config['rollback_keep']:]:
backup_path = os.path.join(self.backup_dir, backup)
shutil.rmtree(backup_path)
self.log(f"清理旧备份: {backup}")
# 使用示例
if __name__ == "__main__":
deployer = AutoDeployer()
print(" 开始自动化部署...")
success = deployer.deploy_new_version()
if success:
print(" 部署成功完成!")
else:
print(" 部署失败,请检查日志")
# 保存部署日志
with open(f"deploy_{datetime.now().strftime('%Y%m%d_%H%M%S')}.log", 'w') as f:
f.write('
'.join(deployer.deploy_log))
效果:部署时间从30分钟缩短到5分钟,出错率降低90%!
案例4:资源使用情况监控与报告
痛点:需要定期统计各服务器资源使用情况,制作报表给领导看。
解决方案:自动收集数据,生成精美图表报告!
#!/usr/bin/env python3 importpsutil importmatplotlib.pyplotasplt importjson importsqlite3 fromdatetimeimportdatetime, timedelta importos # 设置中文字体(避免图表中文乱码) plt.rcParams['font.sans-serif'] = ['SimHei','Arial Unicode MS'] plt.rcParams['axes.unicode_minus'] =False classResourceMonitor: def__init__(self, db_path="resource_monitor.db"): self.db_path = db_path self.init_database() definit_database(self): """初始化数据库""" conn = sqlite3.connect(self.db_path) cursor = conn.cursor() cursor.execute(''' CREATE TABLE IF NOT EXISTS resource_data ( id INTEGER PRIMARY KEY AUTOINCREMENT, timestamp TEXT NOT NULL, cpu_percent REAL NOT NULL, memory_percent REAL NOT NULL, disk_percent REAL NOT NULL, network_sent INTEGER NOT NULL, network_recv INTEGER NOT NULL, process_count INTEGER NOT NULL ) ''') conn.commit() conn.close() defcollect_metrics(self): """收集系统指标""" # CPU使用率 cpu_percent = psutil.cpu_percent(interval=1) # 内存使用情况 memory = psutil.virtual_memory() memory_percent = memory.percent # 磁盘使用情况 disk = psutil.disk_usage('/') disk_percent = (disk.used / disk.total) *100 # 网络流量 network = psutil.net_io_counters() network_sent = network.bytes_sent network_recv = network.bytes_recv # 进程数量 process_count =len(psutil.pids()) return{ 'timestamp': datetime.now().isoformat(), 'cpu_percent': cpu_percent, 'memory_percent': memory_percent, 'disk_percent': disk_percent, 'network_sent': network_sent, 'network_recv': network_recv, 'process_count': process_count } defsave_metrics(self, metrics): """保存指标到数据库""" conn = sqlite3.connect(self.db_path) cursor = conn.cursor() cursor.execute(''' INSERT INTO resource_data (timestamp, cpu_percent, memory_percent, disk_percent, network_sent, network_recv, process_count) VALUES (?, ?, ?, ?, ?, ?, ?) ''', ( metrics['timestamp'], metrics['cpu_percent'], metrics['memory_percent'], metrics['disk_percent'], metrics['network_sent'], metrics['network_recv'], metrics['process_count'] )) conn.commit() conn.close() defget_metrics_by_period(self, hours=24): """获取指定时间段的指标数据""" conn = sqlite3.connect(self.db_path) cursor = conn.cursor() start_time = (datetime.now() - timedelta(hours=hours)).isoformat() cursor.execute(''' SELECT timestamp, cpu_percent, memory_percent, disk_percent, network_sent, network_recv, process_count FROM resource_data WHERE timestamp >= ? ORDER BY timestamp ''', (start_time,)) data = cursor.fetchall() conn.close() returndata defgenerate_report(self, hours=24): """生成资源使用报告""" data =self.get_metrics_by_period(hours) ifnotdata: print(" 没有找到监控数据") return # 解析数据 timestamps = [datetime.fromisoformat(row[0])forrowindata] cpu_data = [row[1]forrowindata] memory_data = [row[2]forrowindata] disk_data = [row[3]forrowindata] process_data = [row[6]forrowindata] # 创建图表 fig, ((ax1, ax2), (ax3, ax4)) = plt.subplots(2,2, figsize=(15,10)) fig.suptitle(f'系统资源监控报告 - 最近{hours}小时', fontsize=16) # CPU使用率图表 ax1.plot(timestamps, cpu_data,'b-', linewidth=2) ax1.set_title('CPU使用率 (%)') ax1.set_ylabel('使用率 (%)') ax1.grid(True, alpha=0.3) ax1.axhline(y=80, color='r', linestyle='--', alpha=0.7, label='警戒线(80%)') ax1.legend() # 内存使用率图表 ax2.plot(timestamps, memory_data,'g-', linewidth=2) ax2.set_title('内存使用率 (%)') ax2.set_ylabel('使用率 (%)') ax2.grid(True, alpha=0.3) ax2.axhline(y=85, color='r', linestyle='--', alpha=0.7, label='警戒线(85%)') ax2.legend() # 磁盘使用率图表 ax3.plot(timestamps, disk_data,'orange', linewidth=2) ax3.set_title('磁盘使用率 (%)') ax3.set_ylabel('使用率 (%)') ax3.set_xlabel('时间') ax3.grid(True, alpha=0.3) ax3.axhline(y=90, color='r', linestyle='--', alpha=0.7, label='警戒线(90%)') ax3.legend() # 进程数量图表 ax4.plot(timestamps, process_data,'purple', linewidth=2) ax4.set_title('系统进程数量') ax4.set_ylabel('进程数') ax4.set_xlabel('时间') ax4.grid(True, alpha=0.3) # 调整时间轴显示 foraxin[ax1, ax2, ax3, ax4]: ax.tick_params(axis='x', rotation=45) plt.tight_layout() # 保存图表 report_path =f"resource_report_{datetime.now().strftime('%Y%m%d_%H%M%S')}.png" plt.savefig(report_path, dpi=300, bbox_inches='tight') print(f" 报告已生成:{report_path}") # 显示统计信息 self.print_statistics(cpu_data, memory_data, disk_data, process_data) returnreport_path defprint_statistics(self, cpu_data, memory_data, disk_data, process_data): """打印统计信息""" print(" 统计摘要:") print(f" CPU: 平均{sum(cpu_data)/len(cpu_data):.1f}%, 最大{max(cpu_data):.1f}%") print(f" 内存: 平均{sum(memory_data)/len(memory_data):.1f}%, 最大{max(memory_data):.1f}%") print(f" 磁盘: 平均{sum(disk_data)/len(disk_data):.1f}%, 最大{max(disk_data):.1f}%") print(f" 进程: 平均{sum(process_data)//len(process_data)}个, 最大{max(process_data)}个") defcleanup_old_data(self, days=7): """清理旧数据""" conn = sqlite3.connect(self.db_path) cursor = conn.cursor() cutoff_time = (datetime.now() - timedelta(days=days)).isoformat() cursor.execute('DELETE FROM resource_data WHERE timestamp < ?', (cutoff_time,)) deleted_rows = cursor.rowcount conn.commit() conn.close() print(f" 清理了 {deleted_rows} 条旧数据") # 使用示例 if __name__ == "__main__": monitor = ResourceMonitor() # 收集当前指标 print(" 正在收集系统指标...") metrics = monitor.collect_metrics() monitor.save_metrics(metrics) print(" 指标收集完成") # 生成报告(如果有足够数据) print(" 正在生成资源监控报告...") try: report_path = monitor.generate_report(hours=24) if report_path: print(f" 报告生成完成: {report_path}") except Exception as e: print(f" 报告生成失败: {e}") # 清理旧数据 monitor.cleanup_old_data(days=7)
效果:自动生成专业图表报告,领导看了都说好!数据分析效率提升500%!
案例5:智能告警系统
痛点:系统异常时不能及时发现,经常是用户投诉后才知道出问题。
解决方案:多维度监控,多渠道告警,确保第一时间响应!
#!/usr/bin/env python3 importrequests importsmtplib importtime importjson importpsutil fromdatetimeimportdatetime fromemail.mime.textimportMIMEText fromemail.mime.multipartimportMIMEMultipart importlogging # 配置日志 logging.basicConfig( level=logging.INFO, format='%(asctime)s - %(levelname)s - %(message)s', handlers=[ logging.FileHandler('alert_system.log'), logging.StreamHandler() ] ) classAlertSystem: def__init__(self, config_file="alert_config.json"): self.config =self.load_config(config_file) self.alert_history = {} # 防止重复告警 self.logger = logging.getLogger(__name__) defload_config(self, config_file): """加载告警配置""" default_config = { "monitors": { "system": { "cpu_threshold":85, "memory_threshold":90, "disk_threshold":95 }, "services": [ {"name":"nginx","port":80}, {"name":"mysql","port":3306}, {"name":"redis","port":6379} ], "urls": [ {"name":"主站","url":"https://www.example.com","timeout":10}, {"name":"API","url":"https://api.example.com/health","timeout":5} ] }, "notifications": { "email": { "enabled":True, "smtp_server":"smtp.company.com", "smtp_port":587, "username":"alert@company.com", "password":"your_password", "recipients": ["admin@company.com","ops@company.com"] }, "webhook": { "enabled":True, "url":"https://hooks.slack.com/services/YOUR/SLACK/WEBHOOK", "channel":"#alerts" } }, "alert_cooldown":300# 5分钟内不重复同类告警 } ifos.path.exists(config_file): withopen(config_file,'r')asf: user_config = json.load(f) self._merge_config(default_config, user_config) returndefault_config def_merge_config(self, default, user): """递归合并配置""" forkey, valueinuser.items(): ifkeyindefaultandisinstance(default[key],dict)andisinstance(value,dict): self._merge_config(default[key], value) else: default[key] = value defcheck_system_resources(self): """检查系统资源""" alerts = [] thresholds =self.config["monitors"]["system"] # CPU检查 cpu_percent = psutil.cpu_percent(interval=1) ifcpu_percent > thresholds["cpu_threshold"]: alerts.append({ "type":"system", "level":"critical"ifcpu_percent >95else"warning", "message":f"CPU使用率过高:{cpu_percent:.1f}% (阈值:{thresholds['cpu_threshold']}%)", "metric":"cpu", "value": cpu_percent }) # 内存检查 memory = psutil.virtual_memory() ifmemory.percent > thresholds["memory_threshold"]: alerts.append({ "type":"system", "level":"critical"ifmemory.percent >95else"warning", "message":f"内存使用率过高:{memory.percent:.1f}% (阈值:{thresholds['memory_threshold']}%)", "metric":"memory", "value": memory.percent }) # 磁盘检查 disk = psutil.disk_usage('/') disk_percent = (disk.used / disk.total) *100 ifdisk_percent > thresholds["disk_threshold"]: alerts.append({ "type":"system", "level":"critical", "message":f"磁盘使用率过高:{disk_percent:.1f}% (阈值:{thresholds['disk_threshold']}%)", "metric":"disk", "value": disk_percent }) returnalerts defcheck_services(self): """检查服务端口""" alerts = [] forserviceinself.config["monitors"]["services"]: try: importsocket sock = socket.socket(socket.AF_INET, socket.SOCK_STREAM) sock.settimeout(5) result = sock.connect_ex(('localhost', service["port"])) sock.close() ifresult !=0: alerts.append({ "type":"service", "level":"critical", "message":f"服务{service['name']}端口{service['port']}无法连接", "metric":"service_port", "service": service["name"], "port": service["port"] }) exceptExceptionase: alerts.append({ "type":"service", "level":"critical", "message":f"检查服务{service['name']}时发生错误:{str(e)}", "metric":"service_check_error", "service": service["name"] }) returnalerts defcheck_urls(self): """检查URL可用性""" alerts = [] forurl_configinself.config["monitors"]["urls"]: try: response = requests.get( url_config["url"], timeout=url_config["timeout"] ) ifresponse.status_code !=200: alerts.append({ "type":"url", "level":"critical", "message":f"URL{url_config['name']}返回状态码:{response.status_code}", "metric":"http_status", "url": url_config["url"], "status_code": response.status_code }) elifresponse.elapsed.total_seconds() > url_config["timeout"] *0.8: alerts.append({ "type":"url", "level":"warning", "message":f"URL{url_config['name']}响应较慢:{response.elapsed.total_seconds():.2f}秒", "metric":"response_time", "url": url_config["url"], "response_time": response.elapsed.total_seconds() }) exceptrequests.exceptions.Timeout: alerts.append({ "type":"url", "level":"critical", "message":f"URL{url_config['name']}请求超时 (>{url_config['timeout']}秒)", "metric":"timeout", "url": url_config["url"] }) exceptExceptionase: alerts.append({ "type":"url", "level":"critical", "message":f"URL{url_config['name']}检查失败:{str(e)}", "metric":"connection_error", "url": url_config["url"] }) returnalerts defshould_send_alert(self, alert): """检查是否应该发送告警(防止重复告警)""" alert_key =f"{alert['type']}_{alert['metric']}" current_time = time.time() ifalert_keyinself.alert_history: last_alert_time =self.alert_history[alert_key] ifcurrent_time - last_alert_time < self.config["alert_cooldown"]: return False self.alert_history[alert_key] = current_time return True def send_email_alert(self, alerts): """发送邮件告警""" if not self.config["notifications"]["email"]["enabled"]: return try: smtp_config = self.config["notifications"]["email"] # 创建邮件 msg = MIMEMultipart() msg['From'] = smtp_config["username"] msg['To'] = ", ".join(smtp_config["recipients"]) msg['Subject'] = f" 系统告警 - {datetime.now().strftime('%Y-%m-%d %H:%M:%S')}" # 邮件内容 body = self.format_email_body(alerts) msg.attach(MIMEText(body, 'html', 'utf-8')) # 发送邮件 server = smtplib.SMTP(smtp_config["smtp_server"], smtp_config["smtp_port"]) server.starttls() server.login(smtp_config["username"], smtp_config["password"]) server.send_message(msg) server.quit() self.logger.info(f"邮件告警发送成功,收件人: {smtp_config['recipients']}") except Exception as e: self.logger.error(f"发送邮件告警失败: {e}") def format_email_body(self, alerts): """格式化邮件内容""" critical_alerts = [a for a in alerts if a['level'] == 'critical'] warning_alerts = [a for a in alerts if a['level'] == 'warning'] html = f"""""" ifcritical_alerts: html +="系统监控告警
检测时间:{datetime.now().strftime('%Y-%m-%d %H:%M:%S')}
严重告警
" foralertincritical_alerts: html +=f'{alert["message"]}' ifwarning_alerts: html +="警告告警
" foralertinwarning_alerts: html +=f'{alert["message"]}' html +=""" """ returnhtml defsend_webhook_alert(self, alerts): """发送Webhook告警(如Slack)""" ifnotself.config["notifications"]["webhook"]["enabled"]: return try: webhook_config =self.config["notifications"]["webhook"] # 格式化消息 message =self.format_webhook_message(alerts) payload = { "channel": webhook_config.get("channel","#alerts"), "username":"MonitorBot", "icon_emoji":"", "text": message } response = requests.post(webhook_config["url"], json=payload, timeout=10) response.raise_for_status() self.logger.info("Webhook告警发送成功") exceptExceptionase: self.logger.error(f"发送Webhook告警失败:{e}") defformat_webhook_message(self, alerts): """格式化Webhook消息""" critical_count =len([aforainalertsifa['level'] =='critical']) warning_count =len([aforainalertsifa['level'] =='warning']) message =f" *系统监控告警* -{datetime.now().strftime('%Y-%m-%d %H:%M:%S')} " ifcritical_count >0: message +=f" 严重告警:{critical_count}个 " ifwarning_count >0: message +=f" 警告告警:{warning_count}个 " message +=" *告警详情:* " foralertinalerts: emoji =""ifalert['level'] =='critical'else"" message +=f"{emoji}{alert['message']} " returnmessage defrun_monitoring_cycle(self): """执行一次监控检查""" self.logger.info("开始监控检查...") all_alerts = [] # 检查系统资源 system_alerts =self.check_system_resources() all_alerts.extend(system_alerts) # 检查服务 service_alerts =self.check_services() all_alerts.extend(service_alerts) # 检查URL url_alerts =self.check_urls() all_alerts.extend(url_alerts) # 过滤需要发送的告警 alerts_to_send = [alertforalertinall_alertsifself.should_send_alert(alert)] ifalerts_to_send: self.logger.warning(f"发现{len(alerts_to_send)}个告警") # 发送告警 self.send_email_alert(alerts_to_send) self.send_webhook_alert(alerts_to_send) returnalerts_to_send else: self.logger.info("系统运行正常,无告警") return[] defstart_monitoring(self, interval=60): """启动持续监控""" self.logger.info(f"启动监控服务,检查间隔:{interval}秒") try: whileTrue: self.run_monitoring_cycle() time.sleep(interval) exceptKeyboardInterrupt: self.logger.info("监控服务已停止") exceptExceptionase: self.logger.error(f"监控服务异常:{e}") # 使用示例 if__name__ =="__main__": importos # 创建告警系统 alert_system = AlertSystem() print(" 智能告警系统启动") print("="*50) # 执行一次检查 alerts = alert_system.run_monitoring_cycle() ifalerts: print(f" 发现{len(alerts)}个告警:") foralertinalerts: level_emoji =""ifalert['level'] =='critical'else"" print(f" {level_emoji}[{alert['type'].upper()}]{alert['message']}") else: print(" 系统运行正常,无异常告警") print(" "+"="*50) print(" 提示: 运行 python alert_system.py --daemon 启动持续监控") # 如果需要持续监控,取消下面注释 # alert_system.start_monitoring(interval=60)
服务器
14文章
10366浏览量
91763 -
python
58文章
4886浏览量
90315 -
脚本
1文章
412浏览量
29277
原文标题:告别加班!Python脚本实现运维工作自动化的5个实用案例
文章出处:【微信号:magedu-Linux,微信公众号:马哥Linux运维】欢迎添加关注!文章转载请注明出处。
介绍10个Python自动化脚本
配电自动化实用化运维指标研究
城域网是什么,其生命周期和自动化运维应用有哪些特点
10个杀手级的Python自动化脚本分享
分享10个实用的Python自动化脚本
容器化NPB + Ansible:自动化运维方案
Python脚本实现运维工作自动化案例
