概述
本文主要讲解如何二进制安装Linux集群
环境信息
| 主机名 | IP地址 | 系统 |
| ELK01 | 10.0.0.40 | Ubuntu22.04 |
| ELK02 | 10.0.0.41 | Ubuntu22.04 |
| ELK03 | 10.0.0.42 | Ubuntu22.04 |
实操
安装JDK(所有节点都需要安装)
ElasticSearch是使用Java语言开发的,所以运行时依赖JDK
安装JDK可以参考这篇文章:https://www.cnblogs.com/huangSir-devops/p/18919758
ElasticSearch版本和Java版本对应关系,可以阅读这篇文章:https://www.elastic.co/support/matrix#matrix_jvm
我们这里安装ELasticSearch7.17.x版本的,我们安装JDK11版本
| | | | --- | --- | | |# 下载 | | | [root@master~]# wget https://mirrors.huaweicloud.com/openjdk/11.0.2/openjdk-11.0.2_linux-x64_bin.tar.gz | | | [root@master~]# ll openjdk-11.0.2_linux-x64_bin.tar.gz | | | -rw-r--r--1root root187513052Jan182019openjdk-11.0.2_linux-x64_bin.tar.gz | | | | | |# 解压 | | | [root@master~]# tar -xvf openjdk-11.0.2_linux-x64_bin.tar.gz | | | | | |# 创建软连接 | | | [root@master~]# ln -s /root/jdk-11.0.2 /usr/local/jdk11 | | | [root@master~]# ll /usr/local/jdk11 | | | lrwxrwxrwx1root root16Jun1421:09 /usr/local/jdk11 ->/root/jdk-11.0.2/ | | | | | |# 配置环境变量 | | | [root@master~]# vim /etc/profile | | |# 根据实际安装路径修改 | | | export JAVA_HOME=/usr/local/jdk11/ | | | export PATH=$JAVA_HOME/bin:$PATH| | | export CLASSPATH=.:$JAVA_HOME/lib/dt.jar:$JAVA_HOME/lib/tools.jar | | | | | |# 加载环境变量 | | | [root@master~]# source /etc/profile | | | | | |# 验证 | | | [root@master~]# java -version | | | openjdk version"11.0.2"2019-01-15| | | OpenJDK Runtime Environment18.9(build11.0.2+9) | | | OpenJDK64-Bit Server VM18.9(build11.0.2+9, mixed mode) |
配置主机名及添加hosts解析
ELK01节点设置
| | | | --- | --- | | | [root@master ~]# hostnamectl set-hostname ELK01 | | | [root@master ~]# hostname | | | ELK01 |
ELK02节点设置
| | | | --- | --- | | | [root@master ~]# hostnamectl set-hostname ELK02 | | | [root@master ~]# hostname | | | ELK02 |
ELK03节点设置
| | | | --- | --- | | | [root@master ~]# hostnamectl set-hostname ELK03 | | | [root@master ~]# hostname | | | ELK03 |
三台节点都添加hosts解析
| | | | --- | --- | | | [root@master ~]# vim /etc/hosts | | |10.0.0.40ELK01 | | |10.0.0.41ELK02 | | |10.0.0.42ELK03 |
配置时间同步(所有节点都需配置)
| | | | --- | --- | | | [root@master ~]# ln -svf /usr/share/zoneinfo/Asia/Shanghai /etc/localtime | | |#下载ntpdate 工具 | | | [root@master ~]# apt -y install ntpdate | | | [root@master ~]# ntpdate ntp.aliyun.com | | | | | | [root@master ~]# echo "*/5 * * * * /usr/sbin/ntpdate ntp.aliyun.com" > /var/spool/cron/crontabs/root |
系统配置(所有节点都需配置)
优化系统参数
| | | | --- | --- | | |[root@master ~]# vim /etc/sysctl.conf | | |# ES 需要大量文件描述符来处理索引和网络连接,建议设置为较高值: | | |fs.file-max=655360| | |# ES 使用 mmap 技术加载索引,需增大虚拟内存区域限制: | | |vm.max_map_count=2147483642| | |# 禁用交换空间(swap分区) | | |vm.swappiness=1| | | | | |# 网络参数优化 | | |net.ipv4.tcp_keepalive_time=600| | |net.ipv4.tcp_keepalive_intvl=60| | |net.ipv4.tcp_keepalive_probes=10| | |net.ipv4.tcp_max_syn_backlog=4096| | |net.core.somaxconn=4096| | |net.core.netdev_max_backlog=16384| | |net.core.rmem_max=262144| | |net.core.wmem_max=262144| | | | | |# 使参数生效 | | |[root@master ~]# sysctl -p /etc/sysctl.conf | | | | | |# 查询参数,验证是否生效 | | |[root@master ~]# sysctl -q vm.max_map_count | | |vm.max_map_count=2147483642|
创建es存储目录
| | | | --- | --- | | |[root@master ~]# mkdir -p/data/elasticsearch/ | | |[root@master ~]# mkdir -p/var/log/elasticsearch/ |
创建es用户
| | | | --- | --- | | |[root@master ~]# useradd elasticsearch | | |[root@master ~]# id elasticsearch | | |uid=2002(elasticsearch) gid=2003(elasticsearch) groups=2003(elasticsearch) | | | | | |# 授权 | | |[root@master ~]# chown elasticsearch:elasticsearch -R /data/elasticsearch/ | | |[root@master ~]# chown elasticsearch:elasticsearch -R /var/log/elasticsearch/ |
添加es用户的限制
| | | | --- | --- | | | [root@master ~]# vim /etc/security/limits.conf | | |# 最大文件描述符数 | | | elasticsearch hard nofile 655360 | | | elasticsearch soft nofile 655360 | | |# 最大进程数 | | | elasticsearch hardnproc8192 | | | elasticsearch softnproc8192 | | |# 锁定内存限制 | | | elasticsearch hard memlock unlimited | | | elasticsearch soft memlock unlimited |
下载并配置ElasticSearch(所有节点操作)
官方下载地址:https://www.elastic.co/downloads/past-releases#elasticsearch
下载解压ElasticSearch
| | | | --- | --- | | |# 下载ElasticSearch | | | [root@master~]# wget https://artifacts.elastic.co/downloads/elasticsearch/elasticsearch-7.17.26-linux-x86_64.tar.gz | | | [root@master~]# ll elasticsearch-7.17.26-linux-x86_64.tar.gz | | | -rw-r--r--1root root325410598Dec 32024elasticsearch-7.17.26-linux-x86_64.tar.gz | | | | | |# 解压 | | | [root@master~]# tar -xvf elasticsearch-7.17.26-linux-x86_64.tar.gz | | | | | |# 移动到/data目录下 | | | [root@master~]# mv elasticsearch-7.17.26 /data/ | | | | | |# 授权 | | | [root@master~]# chown elasticsearch:elasticsearch -R /data/elasticsearch-7.17.26/ | | | | | |# 创建软连接 | | | [root@master~]# ln -s /data/elasticsearch-7.17.26 /usr/local/es7 | | | [root@master~]# ll /usr/local/es7 | | | lrwxrwxrwx1root root27Jun1421:50/usr/local/es7 ->/data/elasticsearch-7.17.26/ |
修改配置文件
| | | | --- | --- | | | [root@master ~]# vim /usr/local/es7/config/elasticsearch.yml | | | cluster.name: es7 | | | path.data: /data/elasticsearch | | | path.logs: /var/log/elasticsearch | | | network.host:0.0.0.0| | | http.port:9200| | | discovery.seed_hosts: ["ELK01","ELK02","ELK03"] | | | cluster.initial_master_nodes: ["ELK01","ELK02","ELK03"] | | | | | |# 根据节点名称来进行修改此字段 | | |# node.name: ELK01 | | |# node.name: ELK02 | | | node.name: ELK03 |
启动ElasticSearch集群(三个节点都执行)
创建systemd文件
| | | | --- | --- | | |[root@master ~]# vim /lib/systemd/system/es.service | | |[Unit]| | |Description=elasticsearch service | | |Documentation=https://www.cnblogs.com/huangSir-devops | | |After=network.target auditd.service | | | | | |[Service]| | |LimitMEMLOCK=infinity | | |User=elasticsearch | | |ExecStart=/usr/local/es7/bin/elasticsearch | | |TimeoutStopSec=0| | |TimeoutStartSec=0| | | | | |[Install]| | |WantedBy=multi-user.target |
加载systemd文件
| | | | --- | --- | | | [root@master ~]# systemctl daemon-reload |
启动es
| | | | --- | --- | | | [root@master ~]# systemctl start es | | | [root@master ~]# systemctl status es | | | ● es.service - elasticsearch service | | | Loaded: loaded (/lib/systemd/system/es.service; disabled; vendor preset: enabled) | | | Active: active (running) since Sat 2025-06-14 2119 CST; 34s ago | | | Docs: https://www.cnblogs.com/huangSir-devops | | | Main PID: 1420 (java) | | | Tasks: 43 (limit: 4519) | | | Memory: 2.1G | | | CPU: 54.474s | | | CGroup: /system.slice/es.service | | | ├─1420 /usr/local/es7/jdk/bin/java -Xshare:auto -Des.networkaddress.cache.ttl=60 -Des.networkaddress.cache.negative.ttl=10 -XX:+AlwaysPreTouch -Xss1m -Djava.awt.headless=true-D | | | file.encoding=UTF-8 -Djna.nosys=true-XX:-OmitStackTraceInFastThrow -XX:+ShowCodeDetailsInExceptionMessages -Dio.netty.noUnsafe=true-Dio.netty.noKeySetOptimization=true-Dio.netty.recycler. | | | maxCapacityPerThread=0 -Dio.netty.allocator.numDirectArenas=0 -Dlog4j.shutdownHookEnabled=false-Dlog4j2.disable.jmx=true-Dlog4j2.formatMsgNoLookups=true-Djava.locale.providers=SPI,COMPAT | | | --add-opens=java.base/java.io=ALL-UNNAMED -Djava.security.manager=allow -XX:+UseG1GC -Djava.io.tmpdir=/tmp/elasticsearch-1928841724883000105 -XX:+HeapDumpOnOutOfMemoryError -XX:+ExitOnOutOfM | | | emoryError -XX:HeapDumpPath=data -XX:ErrorFile=logs/hs_err_pid%p.log"-Xlog:gc*,gc+age=trace,safepoint:file=logs/gc.log:utctime,pid,tags:filecount=32,filesize=64m"-XX:+UnlockDiagnosticVMOpt | | | ions -XX:G1NumCollectionsKeepPinned=10000000 -Xms1937m -Xmx1937m -XX:MaxDirectMemorySize=1016070144 -XX:G1HeapRegionSize=4m -XX:InitiatingHeapOccupancyPercent=30 -XX:G1ReservePercent=15 -Des | | | .path.home=/usr/local/es7 -Des.path.conf=/usr/local/es7/config -Des.distribution.flavor=default -Des.distribution.type=tar -Des.bundled_jdk=true-cp"/usr/local/es7/lib/*"org.elasticsearch. | | | bootstrap.Elasticsearch | | | └─1603 /usr/local/es7/modules/x-pack-ml/platform/linux-x86_64/bin/controller | | | | | | Jun 14 2147 ELK01 elasticsearch[1420]: [2025-06-14T2147,200][INFO ][o.e.n.Node ] [ELK01] starting ... | | | Jun 14 2147 ELK01 elasticsearch[1420]: [2025-06-14T2147,216][INFO ][o.e.x.s.c.f.PersistentCache] [ELK01] persistent cache index loaded | | | Jun 14 2147 ELK01 elasticsearch[1420]: [2025-06-14T2147,217][INFO ][o.e.x.d.l.DeprecationIndexingComponent] [ELK01] deprecation component started | | | Jun 14 2147 ELK01 elasticsearch[1420]: [2025-06-14T2147,374][INFO ][o.e.t.TransportService ] [ELK01] publish_address {10.0.0.40:9300}, bound_addresses {[::]:9300} | | | Jun 14 2147 ELK01 elasticsearch[1420]: [2025-06-14T2147,391][INFO ][o.e.x.m.Monitoring ] [ELK01] creating template [.monitoring-alerts-7] with version [7] | | | Jun 14 2147 ELK01 elasticsearch[1420]: [2025-06-14T2147,400][INFO ][o.e.x.m.Monitoring ] |
检查集群节点
| | | | --- | --- | | |# 检查集群节点 | | | [root@master/var/log/elasticsearch]# curl 10.0.0.40:9200/_cat/nodes | | |10.0.0.402297120.410.380.26cdfhilmrstw * ELK01 | | |10.0.0.42697130.300.260.15cdfhilmrstw - ELK03 | | |10.0.0.412197120.230.190.11cdfhilmrstw - ELK02 | | | | | |# 查看集群是否健康 | | | [root@master/var/log/elasticsearch]# curl 10.0.0.40:9200/_cat/health?v | | | epoch timestamp cluster status node.total node.data shards pri relo init unassign pending_tasks max_task_wait_time active_shards_percent | | |174990998214:06:22 es7 green 3 3 4 2 0 0 0 0 - 100.0% |
链接:https://www.cnblogs.com/huangSir-devops/p/18928862
Linux
88文章
11628浏览量
217989 -
JAVA
20文章
2997浏览量
115685
原文标题:Ubuntu二进制安装ElasticSearch7.17.x版本集群
文章出处:【微信号:magedu-Linux,微信公众号:马哥Linux运维】欢迎添加关注!文章转载请注明出处。
如何二进制安装Linux集群
