展示全屏截图和屏幕局部截图。通过[screenshot]模块实现屏幕截图 ,通过[window]模块实现隐私窗口切换,通过[display]模块查询当前隐私窗口。
效果预览
使用说明:
- 点击右上角图标打开弹窗,选择截屏,展示全屏截图;选择局部截屏,选择截屏区域,点击右下角完成,展示局部截屏;
- 点击滑块切换窗口隐私模式,隐私模式下截屏会弹出提示,拒绝截屏。
具体实现
本示例通过screenshot接口实现屏幕截图 ,通过window接口实现隐私窗口切换,通过display接口查询当前隐私窗口。
- 源码链接:[Screenshot.ets]
* Copyright (c) 2022 Huawei Device Co., Ltd.
* Licensed under the Apache License, Version 2.0 (the "License");
* you may not use this file except in compliance with the License.
* You may obtain a copy of the License at
* http://www.apache.org/licenses/LICENSE-2.0
* Unless required by applicable law or agreed to in writing, software
* distributed under the License is distributed on an "AS IS" BASIS,
* WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
* See the License for the specific language governing permissions and
* limitations under the License.
import screenshot from '@ohos.screenshot'
import { Logger } from './Logger'
import { getCurrentWindow } from './WindowPrivacy'
// 屏幕截图 默认参数screenshotOptions为空时 截全屏
export function getScreenshot(screenshotOption = {}) {
return screenshot.save(screenshotOption)
// 设置全屏展示 isFullScreen: boolean
export function setFullScreen(context: Context, isFullScreen: boolean) {
getCurrentWindow(context)
.then(res = > {
res.setFullScreen(isFullScreen, (err) = > {
if (err.code) {
Logger.error('failed set full-screen mode cause: ' + JSON.stringify(err))
return
Logger.info('success set full-screen mode')
- [WindowPrivacy.ets]
import window from '@ohos.window'
import display from '@ohos.display'
import { ResponseData } from '../models/ResponseData'
// 获取当前窗口
export function getCurrentWindow(context: Context) {
return window.getTopWindow(context)
// 判断隐私窗口
export function hasPrivate(): ResponseData {
let currentDisplay = null
try {
currentDisplay = display.getDefaultDisplaySync()
} catch (exception) {
return { status: 'failed', errorMessage: JSON.stringify(exception) }
if (currentDisplay === null) {
return { status: 'failed', errorMessage: 'get current display failed' }
let ret = undefined
try {
ret = display.hasPrivateWindow(currentDisplay.id)
if (ret === undefined) {
return { status: 'failed', errorMessage: 'ret is undefined' }
return ret ? { status: 'success', errorMessage: '', result: true } :
{ status: 'success', errorMessage: '', result: false }
// 设置隐私窗口
export function setWindowPrivacyMode(context: Context, windowPrivacyMode: boolean) {
let currentWindow = null
.then(res = > {
currentWindow = res
try {
currentWindow.setWindowPrivacyMode(windowPrivacyMode, (err) = > {
if (err.code) {
Logger.error('set window privacy mode failed cause: ' + JSON.stringify(err))
return
Logger.info(`set window privacy mode success ${windowPrivacyMode}`)
Logger.info('set window mode failed cause: ' + JSON.stringify(exception))
举报投诉
鸿蒙
60文章
3060浏览量
46268
热点推荐
2024款鸿蒙OS 最新HarmonyOS Next_HarmonyOS4.0系列教程分享
实战,还包含了HarmonyOS 仿小米App实战。详情参考大纲或者目录介绍。
根据华为鸿蒙生态推广部门介绍,HarmonyOS4和未来的HarmonyOS5(HarmonyOS Next
发表于 02-28 10:29
鸿蒙实战项目开发:【短信服务】
、OpenHarmony 多媒体技术、Napi组件、OpenHarmony内核、Harmony南向开发、鸿蒙项目实战等等)鸿蒙(Harmony NE
发表于 03-03 21:29
名单公布!【书籍评测活动NO.47】HarmonyOS NEXT启程:零基础构建纯血鸿蒙应用
要在2000万 。这一呼吁引起了全球开发者的关注,也意味着市场对HarmonyOS开发人才的需求将快速增长。
什么是纯血鸿蒙
HarmonyOS NEXT,也被称为纯血
发表于 10-14 14:36
鸿蒙Flutter实战:07混合开发
# 鸿蒙Flutter实战:混合开发
鸿蒙Flutter混合开发主要有两种形式。
## 1.基于har
将flutter module
发表于 10-23 16:00
名单公布!【书籍评测活动NO.56】极速探索HarmonyOS NEXT:纯血鸿蒙应用开发实践
的各个关键领域。另外,书中还提供了基于HarmonyOS NEXT 的完整实战项目和3个特色案例,并附带了全套的源代码。
本书适合鸿蒙应用开发工程师、移动应用
发表于 01-20 16:53
淘宝与华为合作将基于HarmonyOS NEXT启动鸿蒙原生应用开发
1月25日,淘宝与华为举办鸿蒙合作签约仪式,宣布将基于HarmonyOS NEXT启动鸿蒙原生应用开发。
华为宣布HarmonyOS NEXT鸿蒙星河版开发者预览面向开发者开放申请
华为宣布HarmonyOS NEXT鸿蒙星河版开发者预览面向开发者开放申请,这意味着鸿蒙生态进入第二阶段,将加速千行百业的应用
鸿蒙NEXT实战开发:【截屏】
