原始镜像:即raw image,完整的ext4分区镜像,包含很多全零的无效填充区 稀疏镜像:即sparse image,将raw ext4进行稀疏描述,因此尺寸比较小,制作目录有多少文件就计算多少,没有全零填充
case WRITE_SPARSE:{std::make_unique(partitionName));return std::move(writer);}.aseupdateupdaterservicesapplypatch
aw_writer.htypedef struct sparse_header { uint32_t magic; /* 0xed26ff3a */ uint16_t major_version; /* (0x1) - reject images with higher major versions */ uint16_t minor_version; /* (0x0) - allow images with higer minor versions */ uint16_t file_hdr_sz; /* 28 bytes for first revision of the file format */ uint16_t chunk_hdr_sz; /* 12 bytes for first revision of the file format */ uint32_t blk_sz; /* block size in bytes, must be a multiple of 4 (4096) */ uint32_t total_blks; /* total blocks in the non-sparse output image */ uint32_t total_chunks; /* total chunks in the sparse input image */ uint32_t image_checksum; /* CRC32 checksum of the original data, counting "don't care" *//* as 0. Standard 802.3 polynomial, use a Public Domain *//* table implementation */} sparse_header_t;#define SPARSE_HEADER_MAGIC 0xed26ff3a#define CHUNK_TYPE_RAW 0xCAC1#define CHUNK_TYPE_FILL 0xCAC2#define CHUNK_TYPE_DONT_CARE 0xCAC3#define CHUNK_TYPE_CRC32 0xCAC4typedef struct chunk_header { uint16_t chunk_type; /* 0xCAC1 -> raw; 0xCAC2 -> fill; 0xCAC3 -> don't care */ uint16_t reserved1; uint32_t chunk_sz; /* in blocks in output image */ uint32_t total_sz; /* in bytes of chunk input file including chunk header and data */} chunk_header_t;class SparseWriter : public DataWriter {public: virtual bool Write(const uint8_t *addr, size_t len, WriteMode mode, const std::string &partitionName); explicit SparseWriter(const std::string partitionName) : offset_(0), fd_(-1), partitionName_(partitionName) {} virtual ~SparseWriter() { offset_ = 0;if (fd_ > 0) { fsync(fd_);close(fd_); } fd_ = -1; }private:int WriteInternal(int fd, const uint8_t *data, size_t len, const std::string &partitionName); SparseWriter(const SparseWriter&) = delete;const SparseWriter& operator=(const SparseWriter&) = delete; off64_t offset_;int fd_; std::string partitionName_;};.aseupdateupdaterservicesapplypatch
aw_writer.cppbool SparseWriter::Write(const uint8_t *addr, size_t len, WriteMode mode, const std::string &partitionName)
if (addr == nullptr) {
LOG(ERROR) << "SparseWriter: invalid address.";
return false;
if (len == 0) {
LOG(INFO) << "SparseWriter: write length is 0, skip.";
return false;
if (fd_ < 0) {
fd_ = OpenPartition(partitionName_);
if (fd_ < 0) {
return false;
UPDATER_CHECK_ONLY_RETURN(WriteInternal(fd_, addr, len, partitionName_) >= 0, return false);
return true;
int SparseWriter::WriteInternal(int fd, const uint8_t *data, size_t len, const std::string &partitionName)
uint32_t written = 0;
sparse_header_t *sparse_header;
chunk_header_t *chunk_header;
unsigned int chunk;
void *membuf = NULL;
uint32_t *fill_buf = NULL;
uint32_t fill_val;
uint32_t bytes_written = 0;
uint32_t total_bytes = 0;
uint32_t blk = 0;
uint32_t chunk_data_sz = 0;
uint32_t blkcnt = 0;
uint32_t blks = 0;
uint32_t total_blocks = 0;
uint32_t addr_offset = 0;
uint32_t fill_buf_num_blks = 0;
uint32_t block_size = 4096;
uint32_t block_count = 524288;
uint32_t i;
uint32_t j;
int ret = lseek64(fd, offset_, SEEK_SET);
UPDATER_FILE_CHECK(ret != -1, "RawWriter: failed to seek file to " << offset_, return -1);
fill_buf_num_blks = CONFIG_FASTBOOT_FLASH_FILLBUF_SIZE / block_size;
LOG(INFO) << "WriteInternal offset_ " << offset_;
/* Read and skip over sparse image header */
sparse_header = (sparse_header_t *)data;
data += sparse_header->file_hdr_sz;
if (sparse_header->file_hdr_sz > sizeof(sparse_header_t)) {
* Skip the remaining bytes in a header that is longer than
* we expected.
data += (sparse_header->file_hdr_sz - sizeof(sparse_header_t));
LOG(INFO) << "=== Sparse Image Header ===";
LOG(INFO) << "magic: " << sparse_header->magic;
LOG(INFO) << "major_version: " << sparse_header->major_version;
LOG(INFO) << "minor_version: " << sparse_header->minor_version;
LOG(INFO) << "file_hdr_sz: " << sparse_header->file_hdr_sz;
LOG(INFO) << "chunk_hdr_sz: " << sparse_header->chunk_hdr_sz;
LOG(INFO) << "blk_sz: " << sparse_header->blk_sz;
LOG(INFO) << "total_blks: " << sparse_header->total_blks;
LOG(INFO) << "total_chunks: " << sparse_header->total_chunks;
LOG(INFO) << "Flashing Sparse Image";
blk = 0;
for (chunk = 0; chunk < sparse_header->total_chunks; chunk++) {
/* Read and skip over chunk header */
chunk_header = (chunk_header_t *)data;
data += sizeof(chunk_header_t);
if (chunk_header->chunk_type != CHUNK_TYPE_RAW)
LOG(INFO) << "=== Chunk Header ===";
LOG(INFO) << "chunk_type: " << chunk_header->chunk_type;
LOG(INFO) << "chunk_sz: " << chunk_header->chunk_sz;
LOG(INFO) << "total_sz: " << chunk_header->total_sz;
if (sparse_header->chunk_hdr_sz > sizeof(chunk_header_t)) {
* than we expected.
data += (sparse_header->chunk_hdr_sz -
sizeof(chunk_header_t));
chunk_data_sz = sparse_header->blk_sz * chunk_header->chunk_sz;
blkcnt = chunk_data_sz / block_size;
switch (chunk_header->chunk_type) {
case CHUNK_TYPE_RAW:
if (chunk_header->total_sz !=
(sparse_header->chunk_hdr_sz + chunk_data_sz)) {
LOG(ERROR) << "Bogus chunk size for chunk type Raw";
return -1;
if (blk + blkcnt > 0 + block_count) {
LOG(ERROR) << "Request would exceed partition size!";
return -1;
addr_offset = blk * block_size;
ret = lseek64(fd, offset_ + addr_offset, SEEK_SET);
if (ret < 0) {
LOG(ERROR) << "failed to seek file to " << addr_offset << " error=" << strerror(errno);
return -1;
written = write(fd, data, blkcnt * block_size);
if (written < 0) {
LOG(ERROR) << "SparseWriter: failed to write data of len ";
return -1;
total_bytes = total_bytes + blkcnt * block_size;
blks = written / block_size;
blk += blks;
bytes_written += blkcnt * block_size;
total_blocks += chunk_header->chunk_sz;
data += chunk_data_sz;
break;
case CHUNK_TYPE_FILL:
(sparse_header->chunk_hdr_sz + sizeof(uint32_t))) {
LOG(ERROR) << "Bogus chunk size for chunk type FILL total_sz err " << chunk_header->total_sz << "
return -1;
ret = posix_memalign (&membuf, 64,
ROUNDUP(
block_size * fill_buf_num_blks,
64));
if (ret) {
LOG(ERROR) << "posix_memalign:" << strerror (errno);
return -1;
fill_buf = (uint32_t *)membuf;
if (!fill_buf) {
LOG(ERROR) << "Malloc failed for: CHUNK_TYPE_FILL";
return -1;
fill_val = *(uint32_t *)data;
data = data + sizeof(uint32_t);
for (i = 0;
i < (block_size * fill_buf_num_blks /
sizeof(fill_val));
i++)
fill_buf[i] = fill_val;
return -1;
for (i = 0; i < blkcnt;) {
j = blkcnt - i;
if (j > fill_buf_num_blks)
j = fill_buf_num_blks;
if (ret < 0) {
LOG(ERROR) << "failed to lseek file to " << addr_offset << " error=" << strerror(errno);
return -1;
written = write(fd, fill_buf, j * block_size);
if (written < 0) {
return -1;
total_bytes = total_bytes + j * block_size;
if (blks < j) {
LOG(ERROR) << "Write failed, block";
free(fill_buf);
return -1;
blk += blks;
i += j;
total_blocks += chunk_data_sz / sparse_header->blk_sz;
free(fill_buf);
break;
case CHUNK_TYPE_DONT_CARE:
blk += blkcnt;
break;
case CHUNK_TYPE_CRC32:
sparse_header->chunk_hdr_sz) {
LOG(ERROR) << "Bogus chunk size for chunk type CRC32 total_sz err " << chunk_header->total_sz;
return -1;
break;
default:
LOG(INFO) << __func__ << ": Unknown chunk type: " << chunk_header->chunk_type;
return -1;
LOG(INFO) << "Wrote "<< chunk <<"blocks, expected to write " << sparse_header->total_blks << "blocks
LOG(INFO) << "........ wrote "<< bytes_written <<"bytes to " << partitionName << "
LOG(INFO) << "total_bytes=" << total_bytes;
return 0;
}DevEco Studio新特性分享-跨语言调试,让调试更便捷高效 基于 OpenHarmony 的智联北斗海防系统 玩转OpenHarmony智能家居:如何实现树莓派“碰一碰”设备控制 玩转OpenHarmony社交场景:即时通讯平台 HarmonyOS多媒体框架介绍
提示:本文由电子发烧友社区发布,转载请注明以上来源。如需社区合作及入群交流,请添加微信EEFans0806,或者发邮箱liuyong@huaqiu.com。
原文标题:稀疏镜像在 OpenHarmony 上的探索
文章出处:【微信公众号:电子发烧友开源社区】欢迎添加关注!文章转载请注明出处。
举报投诉
电子发烧友
34文章
593浏览量
34438 -
开源社区
1文章
96浏览量
828
文章出处:【微信号:HarmonyOS_Community,微信公众号:电子发烧友开源社区】欢迎添加关注!文章转载请注明出处。
热点推荐
使用Dockerfile构建镜像的详细步骤
Dockerfile写得好不好,直接影响三件事:镜像大小、构建速度、运行安全性。我见过太多团队的Dockerfile是"能跑就行"的水平——基础镜像用ubuntu:latest
【原创】OpenHarmony系统投屏工具软件 - OpenHarmony_OHScrcpy使用推荐
Android平台的scrcpy投屏工具。它能够将OpenHarmony设备的屏幕实时镜像到计算机,并提供设备控制功能。
实现原理框图
计算机侧(客户端) :基于Python跨平台实现
OpenHarmony设备
发表于 01-22 18:34
如何在Zynq UltraScale+ MPSoC平台上通过JTAG启动嵌入式Linux镜像
在之前文章中,我们介绍了如何使用 XSCT 工具通过 JTAG 在 Zynq SoC 上启动嵌入式 Linux 镜像(从 JTAG 启动 Zynq-7000 嵌入式 Linux:使用 XSCT 全
炎核开源开放平台上架推出OpenSparseBlas高性能稀疏计算库
在科学计算与工程仿真领域,高效处理大规模稀疏矩阵运算是提升整体计算效能的关键。为此,我们在炎核开源开放平台上架推出 OpenSparseBlas——一个专为稀疏矩阵/向量计算而打造的高性能稀疏计算库
自动驾驶中如何将稀疏地图与视觉SLAM相结合?
[首发于智驾最前沿微信公众号]在自动驾驶场景中,稀疏地图通常是由一系列关键帧和若干三维稀疏特征点构成的地图,每个特征点包含三维坐标和描述外观的描述子;而视觉SLAM是运行在车辆上的实时算法,它一边
请问各位dayu200是不是不支持烧录64位的OpenHarmony
我自己编译了OpenHarmony5.0.2的镜像,发现如果使用arm64参数编译为64位版本,烧录后卡在开机动画无法开机,如果编译为32位就可以正常。请问dayu200不支持64位系统吗?
发表于 08-16 17:39
【Milk-V Duo S 开发板免费体验】镜像烧录与开箱上电
的,不可以同时使用。默认固件配置的是 Type C 口的 USB 网口(USB-NCM)功能。注:DuoS 的大核可以选择使用 RISC-V 或者 ARM,可以通过主板上的切换开关来设置
下载镜像
发表于 06-30 19:19
四川大学OpenHarmony技术俱乐部正式揭牌成立
成立大会暨鸿蒙公开课”在四川大学望江校区成功举办。 嘉宾合影 四川大学副校长游劲松出席大会并致辞。他表示,四川大学始终关注科技发展的前沿动态,并积极投身相关领域的研究与探索。此次四川大学OpenHarmony技术俱乐部的成立标志着四川大学与
