GD32F310开发板串口的数据接收与数字自动转换
冬至配饺子 来源:兆易创新GD32 MCU 作者:卡文迪许怪 2022-09-22 16:43 次阅读
加入交流群
微信小助手二维码
扫码添加小助手
加入工程师交流群
串口的功能网上有很多,但是处理串口的数据需要一些小手段,但是str的函数有点才长,不适用长的数据接收,所以给310搞一个接收数据的轻量级API的小玩意。
开发环境
Keil-MDK 5.34
Windows10
固件库-GD32F3x0_Firmware_Library_V2.2.0
新建工程就不赘述,看这个
启动串口
void uart_init(void)
    //使能时钟
    rcu_periph_clock_enable(RCU_GPIOA);
    rcu_periph_clock_enable(RCU_USART0);
    //Tx PA9 复用推挽输出
    gpio_mode_set(GPIOA,GPIO_MODE_AF,GPIO_PUPD_PULLUP,GPIO_PIN_9);
    gpio_output_options_set(GPIOA, GPIO_OTYPE_PP, GPIO_OSPEED_50MHZ, GPIO_PIN_9);
    //Rx    PA10
    gpio_mode_set(GPIOA,GPIO_MODE_AF,GPIO_PUPD_PULLUP,GPIO_PIN_10);
    gpio_output_options_set(GPIOA, GPIO_OTYPE_PP,GPIO_OSPEED_50MHZ, GPIO_PIN_10);
    nvic_irq_enable(USART0_IRQn,0,0);
    gpio_af_set(GPIOA,GPIO_AF_1,GPIO_PIN_9|GPIO_PIN_10);
    /*USART 设置*/
    usart_deinit(USART0);
    usart_baudrate_set(USART0,115200);
    usart_word_length_set(USART0,USART_WL_8BIT);
    usart_stop_bit_set(USART0,USART_STB_1BIT);
    usart_parity_config(USART0,USART_PM_NONE);
    usart_hardware_flow_rts_config(USART0,USART_RTS_DISABLE);
    usart_hardware_flow_cts_config(USART0,USART_CTS_DISABLE);
    usart_receive_config(USART0,USART_RECEIVE_ENABLE);
    usart_transmit_config(USART0,USART_TRANSMIT_ENABLE);
    usart_enable(USART0);
    usart_interrupt_enable(USART0,USART_INT_RBNE);
    usart_interrupt_enable(USART0, USART_INT_IDLE);         /* 使能USART0空闲中断 */
//串口中断配置
uint16_t t=0;
void USART0_IRQHandler(void)
    if(RESET!=usart_interrupt_flag_get(USART0,USART_INT_FLAG_RBNE))
        gd_led_toggle();
        t=usart_data_receive(USART0);//接收数据
        usart_data_transmit(USART0,USART_RX[t]);
        usart_interrupt_disable(USART0,USART_INT_RBNE);
        usart_data_transmit(USART0,t);
    }else if(RESET!=usart_interrupt_flag_get(USART0,USART_INT_FLAG_IDLE))
        usart_interrupt_disable(USART0,USART_INT_IDLE);
数据处理API
struct _Chang_Num
    char *Source;
    char Sign[8];
    float NUM[8];
    char flag;
char Data_Chang_NUM (struct _Chang_Num *Item)
    char Data_Array[12] = {0};                  //数字的str数
    char str[36];                               //装source数据到这个缓存区,这个缓存区是要变的
    char Data;
    char n,m = 0;
    char i,flag = 1;                            //i是当前找的是 第几个 Sign
    char Find_Time = strlen(Item->Sign);        //要找多少个
    char Length = strlen(Item->Source);         //源的长度
    strcpy(str,Item->Source);
    if(Length > 36)
        Length = 36;
    for (i = 0; i < Find_Time; i++)
        flag = 0;
        for(n = 0;n < Length;n++)
            Data = str[n];
            if(str[n] == Item->Sign[i])           //找到标志
                str[n] = 0;
                flag = 1;                       //开始识别str
                m = 0;
            if(flag)
                if((str[n] <= '9' && str[n] >= '0') || str[n] == '.' || str[n] == '-')
                    Data_Array[m] = str[n];               //把数字相关str的装起来
                    m++;                                //m是数字在str的长度
                else
                    if(m > 0)                            //数字部分结束
                        if(Data_Array[m-1] == '.' || Data_Array[m-1] == '-')    //不让最后一位为 '.' and '-'
                            Data_Array[m-1] = '\0';
                        else
                            Data_Array[m] = '\0';
                        break;
        Item->NUM[i] = atof(Data_Array);
        // Data_Replace ("123",Data_Array,0,sizeof(Data_Array));
    return Item->flag;
配置好你想要的参数在结构体中,然后将串口的缓冲区放入这个函数即可。
将printf函数映射到串口,看这里
struct _Chang_Num Item_n = {
    .Source = "a:3.14......,b:3322..,c:-9.0..-",
    .Sign = {':',':',':'},
int main (void)
    printf("sign :%s",Item_n.Sign);
    Data_Chang_NUM (&Item_n);
    for (char i = 0; i < 3; i++)
        printf("num %d :%.2f \n",i,Item_n.NUM[i]);
    while(1);
API效果
审核编辑:刘清
  • API
    API
  • 数据接收
  • GD32F3
加入交流群
微信小助手二维码
扫码添加小助手
加入工程师交流群
    热点推荐
    GD32330C-START开发板试用体验:+ 串口USART收发数据
    1.使用串口首先我们得根据GD32F330C8T6芯片的datasheet找到对应的引脚。在GD32330C-START开发板原理图中,查看该引脚有没有引出来。 (1)在
    发表于 11-08 11:28 5842次阅读
    <b class='flag-5'>GD</b>32330C-START<b class='flag-5'>开发板</b>试用体验:+ <b class='flag-5'>串口</b>USART收发<b class='flag-5'>数据</b>
    GD32F310开发板试用--基于RTT Nano的RTT软件包使用
    微控制器。GD32F310系列MCU最高主频可达72MHz并支持DSP指令运算。配备了64KB的内置Flash及48KB的SRAM,内核访问闪存高速零等待。采用LQFP32封装。 在评测期间,我移植
    的头像 发表于 08-09 11:17 2617次阅读
    GD32F310K-START开发板上实现ucois-II的移植的设计
    1、ucos-II在GD32F310开发板上的移植介绍μC/OS-II由Micrium公司提供,是一个可移植、可固化的、可裁剪的、占先式多任务实时内核,它适用于多种微处理器,微控制器和数字处理芯片
    发表于 08-22 16:26
    GD32F310开发板实现四线OLED显示的设计
    1、在GD32F310开发板实现四线OLED显示的设计  本次采用四线OLED与开发板实现通信,使用模拟IIC方式,在自己平时的应用中OLED屏幕还是用的比较多的,本文目标是实现OLED显示功能
    发表于 08-31 15:25
    GD32F310开发板试用之硬件SPI驱动0.96寸LCD
    1、GD32F310开发板试用之硬件SPI驱动0.96寸LCD  SPI 简介及特点  具有全双工、半双工和单工模式的主从操作。  16位宽度,独立的发送和接收缓冲区。  8位或16位数据
    发表于 09-22 15:31
    GD32F310开发板串口的一些特殊功能介绍
    串口主要用于通信和调试信息输出,今天仔细观察GDF310数据手册发现一些特殊功能:1、自动波特率检测;2、数据发送/接受,高位在前/后;3
    发表于 09-22 15:40
    基于GD32F310开发板完成超频及ADC极限采样率实验
    主力的型号,供货情况更加稳定一些,且价格上比较有优势。所以当在公众号中看到有GD32F310开发板试用的时候,就申请了来。趁着周末的时间来试用一下同时评估一下用来替换现在使用的GD32F330的可能性
    发表于 09-29 15:35
    GD32F310上对浮点DSP运算及Modbus移植进行测评
    低成本平台也需要一款性能强,价格优的芯片,GD32F310即可作为考虑。基于此,测评一方面考虑其运算性能,另一方面考虑其工控通信功能。2、浮点DSP运算测评从数据手册可以看到,该款芯片支持FPU,集成
    发表于 09-30 11:09
    基于GD32F310开发板的CMSIS-DAP烧录与定时器采集脉宽问题
    1、CMSIS-DAP上电只能烧录一次问题解决&定时器脉宽采集  GD32F310拥有TSSOP20、QFN28、QFN32、LQFP32以及LQFP48共5种封装类型,采用Arm
    发表于 09-30 12:04
    基于GD32F310开发板的AD多通道交流采样计算
    1、基于GD32F310开发板的AD多通道交流采样计算  很幸运能够有机会试用兆易公司的GD32F310开发板。本次使用中,我将使用开发板
    发表于 09-30 14:29
    基于GD32F310开发板的RT-Thread Shell移植及调试心得
      GD32F310系列采用Arm Cortex-M4内核,主频达到72MHz,配备了16KB到64KB的嵌入式闪存及4KB到8KB的SRAM。片上集成了多达5个16位通用定时器、1个16位基本定时器和1
    发表于 09-30 14:47
    基于GD32F310开发板移植FreeRTOS的步骤详解
    1、GD32F310移植FreeRTOS  开发板信息  我们在来看看关于这款开发板:  GD32F310K-START 评估使用
    发表于 10-10 18:07
    基于GD32F310开发板在rt-thread上添加finsh及其shell功能
    1、GD32F310开发板试用+finsh/shell添加与进程STACK优化  上一次只是移植了rt-thread nano的内核,但rt-thread的finsh/shell,是一大很有特点
    发表于 11-08 16:05
    GD32F310开发板上移植FreeRTOS的步骤相关资料分享
    的FreeRTOS版本为:v202112.00  开发板信息  我们在来看看关于这款开发板:  GD32F310K-START 评估使用 GD32
    发表于 11-08 16:58
    如何利用GD32F310读取HDC1080环境温湿度
    本次试用目的是利用GD32F310的I2C0实现对HDC1080的初始化及读取环境温湿度,并利用UART口在电脑上显示出来。
    的头像 发表于 04-15 15:23 4007次阅读
    如何利用<b class='flag-5'>GD32F310</b>读取HDC1080环境温湿度
