OPA2846在单个封装中提供两个极低噪声,高增益带宽的电压反馈运算放大器。在低12.6mA /通道静态电流下工作,每个通道提供1.2nV / Hz 输入电压噪声,带有1.65GHz增益带宽积。最小稳定增益指定为+ 7V /V,同时在+ 10V /V增益下确保出色的平坦度。
低噪声,高压摆率(600V /μs)和宽带宽的组合可以实现要实现的高SFDR差分接收器。此外,失代偿,低噪声,电压反馈运算放大器是宽带跨阻要求的理想选择。双通道OPA2846为高速跨阻要求提供匹配的通道。在增益为20dB时具有超过200MHz的带宽,IF频率为匹配的I和Q通道放大器提供了出色的增益和相位匹配。
所有商标均为其各自所有者的财产。
Architecture |
Number of Channels (#) |
Total Supply Voltage (Min) (+5V=5, +/-5V=10) |
Total Supply Voltage (Max) (+5V=5, +/-5V=10) |
BW @ Acl (MHz) |
Acl, min spec gain (V/V) |
Slew Rate (Typ) (V/us) |
Vn at Flatband (Typ) (nV/rtHz) |
Vn at 1kHz (Typ) (nV/rtHz) |
Iq per channel (Typ) (mA) |
Vos (Offset Voltage @ 25C) (Max) (mV) |
Rail-to-Rail |
Features |
Rating |
Operating Temperature Range (C) |
Package Group |
Package Size: mm2:W x L (PKG) |
CMRR (Typ) (dB) |
Input Bias Current (Max) (pA) |
Offset Drift (Typ) (uV/C) |
GBW (Typ) (MHz) |
Output Current (Typ) (mA) |
2nd Harmonic (dBc) |
3rd Harmonic (dBc) |
@ MHz |
OPA2846 |
Bipolar Voltage FB |
2 |
10 |
12 |
500 |
7 |
625 |
1.2 |
1.2 |
12.6 |
0.65 |
No |
Decompensated |
Catalog |
-40 to 85 |
SOIC |
8SOIC: 29 mm2: 6 x 4.9(SOIC) |
110 |
20000000 |
1.6 |
1750 |
80 |
76 |
109 |
5 |
