企业号介绍
全部
  • 全部
  • 产品
  • 方案
  • 文章
  • 资料
  • 企业
上海屹持光电技术有限公司
红外观察仪、飞秒激光器、太赫兹相机、太赫兹光谱仪
618 内容数 10w+ 浏览量 27 粉丝
用于深紫外成像的元件 Components for DUV-photolithography
型号: Components for DUV-photolithog
--- 产品详情 ---
资料下载:Download Components for DUV-photolithography Datasheet (PDF, 388 KB)
One of the essential requirements of modern optoelectronics consists in miniaturization of equipment and devices as well as the components they include. It dictates the necessity of utilization of DUV lasers as the key tools of advanced photolithographic technology. This type of lasers have shortest (among others laser sources) wavelength of powerful monochromatic radiation. It allows generating nano-scale structures and thus creating systems characterized by the maximal spatial resolution as well as by packing density.
Modern projection steppers and scanners on the base of KrF excimer lasers (248 nm) are currently used to produce lines in the 110 nm range. Lines as thin as 65 nm are being resolved by systems utilizing ArF excimer lasers emitting light with a wavelength of 193 nm. Further resolution enhancement and improvement of the systems became possible using immersion lithography. In this case laser radiation is focused not on dry substrate but on the one moistened by special immersion liquid. This liquid is typically ultra-pure, deionized water continually circulated to eliminate thermally-induced distortions. Such approach has allowed increasing the numerical aperture by more than 30% and as a result it enables the economical volume production of microchips featuring 45 nm structures.
Utilization of synthetic crystal quartz for the purposes DUV-photolithography is caused by its excellent transmission in UV range, high crystallographic perfection and optical homogeneity, chemical resistance and stability to intensive laser radiation.
For production of optical components described in this chapter Tydex uses synthetic crystal quartz of precision optical grade (class A1, category “extra”).
Main parameters of the used material are as follow:
Parameter
Value
Twinnings, striaes, microbubbles including their conglomerates; inclusions and cracks
not allowed
Polarization uniformity
no visible variations during inspection between crossed polarizers
Homogeneity of refractive index
Δ n < 3 x 10-6  (TWD <= λ /10 per inch of crystal length)
Etch channels, cm-2
<= 30, typically
Absorption coefficient, cm-1 (λ=193 nm)
<= 0.025
Birefringence, nm/cm
<= 10
Concentration of main impurities, ppm
<= 10
High level of growth technology which is currently used to produce synthetic crystal quartz does ensure that these parameters will be obtained. But high-involved responsibility induced by application dictates a mandatory requirement to check material quality additionally. Moreover any small piece of used material must be tested without exceptions and with double attention to any details. For this purpose prior to passing an ingot to production we cut and prepare a sample of required overall dimensions and then get it polished. After that we accurately test it under UV excitation using ArF excimer laser. Each ingot (i.e. the sample) even being grown at the same growth run must pass this test successfully. A dose and duration of the excitation simulate the further working conditions of finished optical components and are specially selected to make an attempt to discover material imperfections, mainly the impurities. Only the material withstanding the applied exposure and that is the most important thing – do not get UV-induced degradation of transmission, is passed to production. Otherwise or in case if any single parameter does not meet the above mentioned value, the material is unambiguously rejected and it is ensured that it will be never used for the purposes of discussed application.
For DUV-photolithography Tydex supplies the following components:
  • circular plano-plano thin plates (wafers);
  • sector-shape plano-plano plates (sectors);
  • wedge plates of complex design (depolarizers).
Severe application' conditions where the components are used dictate the exclusive requirements to parameters of their treatment. Typical specification is as follows:
Parameter
Value
Orientation tolerance, arc. min.
+/- 10
Surface quality, scr/dig
High-quality polishing, better than 20/10
Surface roughness at any square of 350 μm  x  260 μm (RMS), nm
< 0.6
TWD ( λ= 633  nm), λ
< 1
Thickness of an element, mm:
- wafer
- sector
- depolarizer (thin edge)
0.55575
1.9456
0.9
Tolerance zone for overall dimensions (excluding thickness), mm
+/-0.05
Tolerance zone for thickness (typical value), μm
+0.5/-2
(+/-0.5 – state-of-the-art)
Non-parallelism of opposite surfaces (for plano-plano elements), arc. sec.
< 2
Tolerance zone for wedge (for wedged elements), arc. min.
+/- 25
Together with each component we supply a certificate of conformance as well as an individual interferometer graph demonstrating surface errors.
The examples of ZYGO interferograms (TWD) are shown at figures 1-3.
Typical ZYGO interferograms (TWD) of D100 mm wafer
Fig. 1 Typical ZYGO interferograms (TWD) of D100 mm wafer.
Typical ZYGO interferograms (TWD) of sector
Fig. 2 Typical ZYGO interferograms (TWD) of sector.
Typical ZYGO interferograms (TWD) of depolarizer
Fig. 3 Typical ZYGO interferograms (TWD) of depolarizer.
Besides the components mentioned above and upon your specification & design we will be glad to produce other custom-made components.
为你推荐
  • SSFS飞秒激光孤子自频移波长调谐技术2024-07-02 09:17
    SSFS孤子自频移飞秒激光波长调谐模块利用SSFS孤子自频移现象(Soliton self-frequency shift ),允许用户在近红外范围内对飞秒激光进行波长调谐。通常,来自固定波长掺铒飞秒光源的孤子可以从1550 nm范围调谐到2100 nm波长。通过改变输入光功率,可以很容易地调谐输出波长。波长偏移输出信号保持相干性和线性极化。模块完全即插即用
    2166浏览量
  • 1.5μ超紧凑型单次自相关仪正式上市2024-06-17 16:08
    µ-ROC紧凑型单次自相关仪现已推出 1.5 µm新版本,光谱范围覆盖1300-1700nm,专用于掺铒飞秒激光器。至此µ-ROC已经可以覆盖传统800nm、1um、1.5um波段,用户可以根据自身需求灵活选择。µ-ROC同样配备STAR Software专用软件,用户终身可以通过自动更新轻松免费地访问最新软件版本。
    1567浏览量
  • 近距离了解中红外可调谐光纤飞秒激光器 Femtum Ultratune 3400性能2024-06-17 14:26
    中红外可调谐光纤飞秒激光器UltraTune 3400是一款商业中红外超快激光器,其结构紧凑、免维护和可调谐激光系统是科学研究的理想工具。
    2324浏览量
  • 可输出不同偏振太赫兹波的光电导天线2024-05-14 11:21
    屹持光电推出的大面积光电导天线辐射源,具有不同的极化类型,并且具有激发面积大,转换效率高的优点。该系列太赫兹光电导天线最显著的特点是:除了通常的线性极化外,还可以产生径向或者方位偏振的太赫兹辐射。径向极化辐射特别适合比如使用线波导进行传输的应用。用飞秒激光脉冲激发的光电导发射器是广泛使用的单周期太赫兹(THz)辐射脉冲源。通过应用交叉电极几何形状,可以显著提
    2107浏览量
