Intel 4th Gen Core i3/i5/i7 CPU (LGA1150) with H81, 6*COM, 1*LAN, 1*PCI-E 16X, 1*Mini-PCIe
规格
General | |
CPU | Intel® Pentium®/ Celeron®/ 4th Generation CoreTM i3/i5/i7 CPU, LGA1150 |
Chipset | Intel® H81 Chipset, TDP 4.1W |
Memory | Up to 8 GB DDR3 1600/1333 MHz, 1*DIMM |
Storage | 2*SATA 3.0, 2*SATA 2.0 |
Expansion Interface | 1*PCI-E 16X, 1*Mini-PCIe (Wifi Supported) |
BIOS | AMI UEFI BIOS |
System | Windows 7/8/10, Linux |
I/O Interface | |
Serial Port | 6*RS232 (COM2 RS485 optional) |
USB | 2*USB 3.0, 8*USB 2.0 (4*on rear I/O, 6*header) |
Ethernet | 1*Realtek® PCI-E LAN for 100Mbps |
Audio | Realtek® ALC662 5.1 channel HDA Codec, supports MIC/Line-out Ports |
PS/2 | 2*PS/2 (Keyboard and Mouse Supported) |
Parallel Port | 1*LPT |
GPIO | 8 programmable GPIO |
Feature Interface | Null |
Display | |
Display Interface |
1*VGA: max resolution up to 1920*1200@60Hz |
Multiple Display | Dual |
Mechanical & Environment | |
Dimension | Mini-ITX, 170*170mm |
Power Input | ATX PSU |
Temperature | Operation: 0℃~60℃, Storage: -25℃~75℃ |
Relative Humidity | Operation: 10%~90%, Storage: 5%~95%, non-condensing |
举报投诉
WINDOWS
3文章
3449浏览量
87209 -
嵌入式主板
7文章
6065浏览量
34650 -
信步科技
5文章
263浏览量
7024
信步科技SV1a-H1116P规格英文版
Mbps LAN
With SVIO support SV-M6 I/O Module to extend COM/USB/PCI
Supports dual display of VGA
信步科技SV1-H2726C规格英文版
H270 chipset
Double-layer Rear I/O which can expand to 18*COM and 18*USB (use SV-M5 I/O Extension
信步科技SV1-H1126C规格英文版
chipset
Double-layer Rear I/O which can expand to 18*COM and 18*USB (use SV-M5 I/O Extension Modules
