MOMAX摩米士“X-Level”高容电池多图详解
手机
2010-02-25 09:00:501002 乐视超级汽车(中国)副总裁的倪凯认为,提高乐视汽车在自动驾驶领域的技术积累、解决自动驾驶量产化与可靠性的协调问题,是自己的首要工作之一。乐视更倾向于在自动驾驶的“ Level 3及Level 4”阶段发力,在选择具体项目时也比较倾向于 2-3年的中期项目和相对时间线更长的长期项目。
2016-04-26 14:15:47837 本帖最后由 ORCAD__PCB 于 2012-8-9 14:38 编辑
(Delmar) Digital Signal Processing
2012-08-09 14:34:16
(LNA+VCAT+PGA) and Digital Processing (ADC+Digital Demodulator) that brings a high level of system
2018-11-08 14:21:49
Digital Image Processing
2016-06-24 14:08:55
Digital video technologiesContents What is digital video?Why has digital video become a mainstream
2008-08-04 15:35:24
2008-08-04 15:49:28
《Signals and Systems》by Rernd Girod;Rudolf Rabenstein;Alexander StengerProduct Details: ISBN
2011-08-19 11:06:15
level shifter can also be used in other bus systems or point to point connections for level shifting
2009-05-12 08:54:11
do so much more than just simple digital pin control. It can produce PWM signals, so you can dim
2016-01-29 13:08:50
sources. It digitizes and decodes NTSC/PAL/COMET/AHD1.0/AHD2.0 video signal into digital video signal
2019-01-19 15:46:03
and achieves a full load efficiency of 93%. Level shifting in the feedback is necessary to maintain regulation.
2018-07-13 02:44:47
PS仿真时出现错误: Digital Simulator Option not present和Digital simulator not present。我在网上下载的6N137元器件模型,其中
2019-01-20 10:53:36
Real Analog Solutions for Digital Designers
2017-01-08 14:58:51
The digital Video Standard according to ITU-R BT. 601/656Leveldiagram at the input of an A/D converter for theanalogue component signals Y , CB , CR
2009-06-13 00:00:15
Preface xiPart 1. Getting StartedChapter 1. Digital Communications and LabVIEW 31.1 Conventional
2011-12-23 16:34:21
LabVIEW Digital Signal Processing and Digital Communications很不错。{:12:}
2014-09-03 08:32:41
Testing basic digital signals, such as triggers, clock signals, and logic control, doesn't always require the performance of a dedicated pulse generator.
2019-11-01 11:11:54
These two-/three-channeldevices can accept low level input signals directly from a transducerand produce a serial digital output. They
2008-04-06 00:41:563 AN10441Level shifting techniques in I2C-bus designRev. 01 — 18 June 2007 Application
2008-07-14 18:00:4423 The MAX13046E/MAX13047E ±15kV ESD-protected bidirectional level translators provide level shifting
2008-08-20 12:21:4131 The PCA9517 is a CMOS integrated circuit that provides level shifting between lowvoltage (down
2008-10-09 15:43:2621 The MSM7652 is a digital NTSC/PAL encoder. By inputting digital image data conforming to ITU Rec.
2008-10-29 12:39:2515 The MAX3000E/MAX3001E/MAX3002–MAX3012 8-channel level translators provide the level shifting
2008-11-27 16:38:0529 The MAX3000E/MAX3001E/MAX3002–MAX30128-channel level translators provide the level shifting
2008-11-27 16:45:4211 The EL5001 is a 6-channel level shifting driver designedprimarily for use as a clock driver in LTPS
2009-01-16 08:34:3612 Digital Signal Processing System-Level Design Using LabVIEW
For many years, I have been teaching
2009-02-17 10:27:310 This text contains a comprehensive discussion on continuous and discrete time signals and systems
2009-02-17 10:31:272 The effects on digital signals of slotted ground
2009-03-24 14:13:000 to capture temperature,pressure, and other environmental information producelow level signals. These signals can easily be masked by the
2009-06-06 09:59:5534 2-bit dual supply transceiver with configurable voltage-level shifting and 3-state outputs
2022-12-14 14:35:11
The MAX13055E–MAX13058E 8-channel, bidirectionallevel translators provide the level shifting
2009-08-26 11:42:2717 (primary ADC only)allowing direct measurement of low-level signals. The ADCsinclude on-chip digital filtering and programmable outp
2009-09-05 08:41:2823 These 2-/3-channel devicescan accept low level input signals directly from a transducer andproduce serial digital output. The devices
2009-09-09 14:08:4628 accepts low level signalsdirectly from a transducer or high level signals (4 VREF) andoutputs a serial digital word. It employs
2009-09-10 15:10:198 The PCA9517 is a CMOS integrated circuit that provides level shifting between lowvoltage (down
2009-11-11 13:51:0216 Spectra of EMI Signals:•Spectra of impulse-like signals•Spectra of periodic
2009-11-29 17:25:3427 We generally think of signals propagating through ourcircuits in one of three modes, single-ended
2010-01-15 10:15:010 sources and convert these signals into digital form for analysis or transmission by end devices such as digital computers, recorders, or communica
2010-06-01 14:27:1114 to capture tempera- ture, pressure, and other environmental information produce low level signals. These signals can easily be masked by the ambien
2010-06-01 17:56:4822 the LinEPIC™ 1-um CMOS process. The TLC5602x converts digital signals to analog signals at a sampling rate of dc to 20 MHz. Because
2010-06-07 15:02:5972 the output-enable (OE) input is high. A diode to VCC is integrated on the chip to allow for level shifting from 5-V signals at the device
2010-08-17 18:09:2310 the output-enable (OE) input is high. A diode to VCC is integrated on the chip to allow for level shifting from 5-V signals at the device
2010-08-17 18:10:589 ; Integrated Level-Shifting Buffers for HSYNC andVSYNC Channels• Operating Voltage– VDD = 3.3 V ±10%–
2010-08-18 20:04:5513 CD40109B contains four low-to-high-voltage level-shifting circuits. Each circuit will shift
2010-08-22 00:25:0620 CD40109B contains four low-to-high-voltage level-shifting circuits. Each circuit will shift
2010-08-22 00:30:1217 CD4504B hex voltage level-shifter consists of six circuits which shift input signals from the VCC
2010-08-22 00:32:2133 CD4504B hex voltage level-shifter consists of six circuits which shift input signals from the VCC
2010-08-22 00:33:5730 ) output. The TMDS output has a built in level translator supporting Digital Video Interface (DVI) 1.0 and High Definition Multimedia Int
2010-08-23 19:30:5233 This device integrates ESD protection for all signals, level shifting for the DDC signals and buffering for the SYNC signals.
Three indivi
2010-08-25 15:49:0326 performance and a high level of system integration. The TAS5028 is designed to interface seamlessly with most audio digital signal processor
2010-09-10 23:12:2020 performance and a high level of system integration. The TAS5028A is designed to interface seamlessly with most audio digital signal process
2010-09-10 23:17:095 performance and a high level of system integration. The TAS5086 is designed to interface seamlessly with most audio digital signal processors a
2010-09-10 23:21:3419 performance and a high level of system integration. The TAS5504 is designed to interface seamlessly with most audio digital signal processors.
2010-09-10 23:31:2511 performance and a high level of system integration. The TAS5504A is designed to interface seamlessly with most audio digital signal processor
2010-09-10 23:33:1124 performance and a high level of system integration. The TAS5508B is designed to interface seamlessly with most audio digital signal processors.
2010-09-10 23:35:1520 The TAS5518 is an eight channel digital pulse width a modulator (PWM) that provides superior
2010-09-10 23:36:3318 sink-current (100 mA) output, and two strobe inputs. This device detects low-level analog or digital signals and can drive digital logic or
2010-09-23 18:50:3530 format LCD display applications such as TVs and monitors. The device converts the logic-level signals generated by the Timing Co
2010-11-03 22:38:0815 and monitors. The device converts the logic-level signals generated by the Timing Controller (T-CON) to the high-level signals used by th
2010-11-03 22:59:3247 Video Display Signals and the MAX9406 DP-HDMI/DVI Level Shifter—Part II
Abstract: This application
2008-12-08 12:39:252026
The MAX17108 is a 10-channel, level-shifting scan driver with an integrated operational amplifier for gate-in-panel (GIP) LCD TVs and
2009-02-02 16:05:311243
Switching VGA Signals in a Notebook
Abstract: This application shows how the MAX4885
2009-03-31 10:43:34793 Abstract: Analog switches can be used to enable the transmission of digital signals and power over
2009-04-24 15:48:52383 yields a single-channel, isolated digital-signal coupler. Optocouplers are the usual choice for coupling digital signals be
2009-04-29 09:25:46657 Abstract: Simple level shifting circuit using a precision op amp tracks small DC voltage changes.
2009-05-07 09:14:381002 Abstract: Despite the popularity of digital devices, real world signals are typically represented
2009-05-08 09:26:55881
Level Shifting Digital Signals
By: Budge Ing
2009-08-21 07:49:531176 Logic-Level Signals Dim -48V LED Driver
Abstract: A 65V hysteretically controlled LED driver
2009-10-15 09:06:101200 声级计电路 Sound Level Meter
This nifty sound level meter is a perfect one chip replacement for the standard analog meters. It is completely soli
2009-12-25 11:10:432396 什么是CHILL (CCITT High Level Language)
英文缩写: CHILL (CCITT High Level Language)
中文译名: CHILL高级语言
2010-02-22 10:47:15570 什么是Digital Certificate,also,digital signature
英文缩写: Digital Certificate,also,digital signature
中文译名: 数字证书(也称数
2010-02-22 17:35:581185 highsink-current (100 mA) output, and two strobe nputs. This device detects low-level analog or dgital signals and can drive digital logic or lamps and r
2011-06-07 17:22:0541 The MAX1840/MAX1841 subscriber identity module (SIM)/smart card level translators provide level
2011-08-06 21:21:1430 高通公司旗下联网和连接技术子公司高通创锐讯(Qualcomm Atheros)今日宣布,针对娱乐应用的消费电子产品推出Skifta™ Media Shifting平台。
2012-01-16 09:41:36390 helpful for any digital designer initiating designs. Here, we address different problems rangingfrom RTL-Gate Level simulation mismatch to race
2012-01-17 11:26:570 The MAX14591 is a dual-channel, bidirectional logicleveltranslator with the level shifting
2012-01-31 10:23:3533 高通公司旗下联网和连接技术子公司高通创锐讯(Qualcomm Atheros)日前宣布,针对娱乐应用的消费电子产品推出Skifta™ Media Shifting平台。
2012-02-01 09:22:09609 , whose monolithicdesign provides a compact and low-cost transferof digital signals between circuits with different powerdomains. The technology en
2012-03-28 16:12:5931 The MAX14842 translates digital signals between twodomains that have different ground references
2012-03-30 10:54:1413 The MAX14611 is a quad bidirectional logic-level translatorthat provides the level shifting
2012-04-24 11:28:2433 (Oppenheim)Signals and Systems Solutions(2nd edition)习题答
2015-12-24 15:04:340 Spirit Level,好东西,喜欢的朋友可以下载来学习。
2016-02-18 16:08:360 Micro SMD Wafer Level Chip Scale Package
2017-03-24 14:58:380 This 3-channel device can accept either low level input signals directly from a transducer or high level (±10 V) signals and produce a serial digital output.
2017-09-30 14:30:0713 accepts low level signals directly from a strain gage or transducer and outputs a serial digital word.
2017-09-30 14:39:1211 accepts low level signals directly from a transducer and outputs a serial digital word.
2017-09-30 14:41:5814 level (±4 : VREF) signals, and outputs a serial digital word.
2017-09-30 14:44:295 accepts low level signals directly from a transducer or high level signals (4 : VREF) and outputs a serial digital word.
2017-09-30 14:46:493 accepts low level signals directly from a transducer and outputs a serial digital word.
2017-09-30 15:11:377 accept low level input signals directly from a transducer and outputs a serial digital word.
2017-09-30 15:16:0421 近日,专注于智能家居创新的公司Level Home,发布了一款“隐形”的智能门锁产品Level Lock。之所以将其形容为“隐形”,最大的原因便在于Level Lock能够将任何标准的门锁转变为智能门锁,且改装时间不会超过十分钟。
2019-10-17 14:42:584599 ADI Signals+ Smart Industry
2021-01-29 09:52:100 ADI Signals+ Electrification
2021-01-29 09:55:100 ADI Signals+ Digital Health
2021-01-29 09:56:100 ADI Signals+ Connectivity
2021-01-29 09:58:101 AD7746 Level Demo Software
2021-03-11 11:08:195 generation of analog signals. Sometimes an integrated or stand-alone digital-to-analog converter(DAC) is used
2021-09-17 12:02:3218 上图就是SMMU Level 1 Stream Table Descriptor的数据格式,简称Level1 STD。
2023-05-06 14:44:44479
查看更多
