企业号介绍
全部
  • 全部
  • 产品
  • 方案
  • 文章
  • 资料
  • 企业
上海屹持光电技术有限公司
红外观察仪、飞秒激光器、太赫兹相机、太赫兹光谱仪
618 内容数 10w+ 浏览量 27 粉丝
大口径镜片 Large Optics
型号: Large Optics
--- 产品详情 ---
Large Optics
资料下载:Download Large Optics Datasheet (PDF, 50 KB)
One of Tydex main lines of business is the production of large optic components intended to solve various research, engineering, and production problems. These components measure from 100 mm to 1300 mm and include windows, lenses, mirrors, prisms, and various nonstandard elements with unique specifications. The Company's capabilities to produce one component or another depend on many factors, including material, geometry, accuracy, and field of application. Despite the wide range of products offered by Tydex, here are some specifications to gain an idea of our production potentialities in this field.
General specifications for Tydex large optics:
Types of products
·  Transmission optics
-  Windows (plane-parallel, wedge-shaped);
-  Lenses (meniscus, biconvex, biconcave, plano-convex, plano-concave);
-  Special transmitted-light elements.
·   Reflection optics
-  Plane mirrors (rectangular, circular, diagonal);
-  Spherical mirrors (concave and convex);
-  Aspherical mirrors:
    -  Axis (parabolic and hyperbolic);
    -  Off-axis (parabolic);
-  Special reflected-light elements.
·  Mixed-type optics
-  Beam splitters (on plane-parallel and wedge-shaped substrates);
-  Special elements with partially reflecting (transmitting) coatings of effective surfaces;
-  Special elements with reflecting and transmitting coatings of irregular shape on one surface;
-  Prisms with some surfaces transmitting light and other surfaces reflecting it.
Fields of application
The main field of application of Tydex's large optics is astronomy and relevant applications. Moreover, many optical components are produced to complete various illumination, scanning, and lidar systems, laser systems, and testing systems having applied importance and intended to solve research and engineering problems. These fields of application determine the stringent surface quality and accuracy, QA, and data-processing requirements to be met by Tydex's optics.
Materials
Large optical components are made of various materials which are selected considering their availability, fields of application, operating conditions for the product, and specifications. For example, materials for transmission optics have high transmission factors in wavelength ranges specified by the Customer. Such components are manufactured from Russian, German (Schott), and Japan (Ohara) optical glasses and fused silica. Reflecting and mixed-type optics can be made of the same materials, depending on their cost and field of application. Moreover, special materials can be used to make mirrors. For example, astronomical mirrors are made from Sitall CO-115M (Astrositall, an analogue of Zerodur) with an extremely low coefficient of thermal expansion. This material was specially developed for high-precision reflecting optics.
Since the optics involved is large-sized, it should be remembered that the choice of such materials is restricted by the maximum possible size, which may limit their use for solving certain problems in the field.
Surface accuracy
The best possible accuracy that can be ensured depends on a variety of factors of which most important are the type of material and the linear dimensions of the product. However, the experience of our opticians and the available instruments and special equipment allow our company to produce optics with a wavefront accuracy of L/10 at 633 nm which is equal to a surface accuracy of L/20.
Surface quality
All our products fully comply with the internationally recognized MIL-0-13830A standard. The surface quality of the mirrors produced by the company depends on their dimensions:
  • 60/40 scratch/dig for linear dimensions up to 400 mm;
  • 80/50 scratch/dig for linear dimensions up to 800 mm;
  • 120/80 scratch/dig for linear dimensions more than 800 mm.
This parameter depends on the type of material and the surface accuracy of the product.
Coatings
Protected aluminum is our most popular coating for reflecting optics. Transmitting components are coated with antireflection films optimized to fit the wavelength range required. Upon the Customer's request, we can apply coatings of other types, if the Company's capabilities allow. These coatings together with maximum diameters are listed in the table below:
No
Type of coating
Maximum diameter
1
Antireflection coatings
400 mm
2
High reflection dielectric mirror coatings
280 mm
3
Partial reflection dielectric coatings
280 mm
4
Wavelength separating/combining coatings
280 mm
5
Hot/Cold mirror coatings
280 mm
6
Protected Aluminum coating
1500 mm
7
Protected Silver coating
400 mm
8
Protected Gold and bare Gold coatings
400 mm
9
Enhanced metal (Al, Ag, Au) coatings
300 mm
10
DLC
300 х 400 mm
Should the operational need arise, we can undertake to apply coatings to components of other types or larger dimensions than those specified in the table. Well-established links to many specialized subcontracting companies (including foreign ones) allow us to extend our capabilities considerably. Therefore, please contact us to inquire about our production potentialities even in "exotic" cases.
Dimensions and standard specifications
·  Flat mirrors of round shape
-  Linear dimensions: from 100 mm to 1000 mm;
-  Wavefront accuracy: up to L/8 at 633 nm (or surface accuracy L/16)
·  Diagonal plane mirrors
-  Minor axis dimension: from 30 mm to 250 mm;
·  Spherical mirrors
-  Diameters: from 100 mm to 1300 mm;
-  Wavefront accuracy: up to L/8 at 633 nm (or surface accuracy L/16);
-  Standard numerical apertures: F/3-F/10
·  Axis parabolic and hyperbolic mirrors
-  Diameters: from 200 mm to 1300 mm;
·  Off-axis parabolic mirrors
-  Diameters: from 70 mm to 650 mm;
-  Wavefront accuracy: up to L/5 at 633 nm (or surface accuracy L/10);
-  Standard numerical apertures: F/3-F/10;
-  Standard off-axis angles: 10°-30°
·  Optical windows
-  Maximum linear dimension: 1000 mm;
·  Optical lenses
- Diameters: from 80 to 400 mm;
- Surface accuracy: L/2 at 633 nm
·   Standard astronomical systems
-  Diameters of primary mirrors: from 400 mm to 1300 mm;
-  Wavefront accuracy (of a ready-assembled system): L/8 at 633 nm (or surface accuracy L/16);
-  Standard numerical apertures of primary mirrors: F/3-F/10;
-  Standard numerical apertures of systems: F/7-F/20
Quality assurance
While manufactured, each large optical component is subjected to multistage quality control. The optics manufactured is inspected by two independent quality control departments and carefully tested. The results of testing are documented in a test certificate where all specified and measured parameter values are indicated. Products of each type are subjected to an individual QA procedure, which ensures unambiguous interpretation of the results obtained. For example, the accompanying documentation for each astronomical system includes two test certificates for the primary mirror and the entire system, interferograms (including negatives) for the primary mirror and the entire system, and the results from a numerical analysis of the interferograms.
The above types of products and their specifications are standard and do not exhaust all the range of products that can be offered.
为你推荐
  • SSFS飞秒激光孤子自频移波长调谐技术2024-07-02 09:17
    SSFS孤子自频移飞秒激光波长调谐模块利用SSFS孤子自频移现象(Soliton self-frequency shift ),允许用户在近红外范围内对飞秒激光进行波长调谐。通常,来自固定波长掺铒飞秒光源的孤子可以从1550 nm范围调谐到2100 nm波长。通过改变输入光功率,可以很容易地调谐输出波长。波长偏移输出信号保持相干性和线性极化。模块完全即插即用
    2166浏览量
  • 1.5μ超紧凑型单次自相关仪正式上市2024-06-17 16:08
    µ-ROC紧凑型单次自相关仪现已推出 1.5 µm新版本,光谱范围覆盖1300-1700nm,专用于掺铒飞秒激光器。至此µ-ROC已经可以覆盖传统800nm、1um、1.5um波段,用户可以根据自身需求灵活选择。µ-ROC同样配备STAR Software专用软件,用户终身可以通过自动更新轻松免费地访问最新软件版本。
    1567浏览量
  • 近距离了解中红外可调谐光纤飞秒激光器 Femtum Ultratune 3400性能2024-06-17 14:26
    中红外可调谐光纤飞秒激光器UltraTune 3400是一款商业中红外超快激光器,其结构紧凑、免维护和可调谐激光系统是科学研究的理想工具。
    2324浏览量
  • 可输出不同偏振太赫兹波的光电导天线2024-05-14 11:21
    屹持光电推出的大面积光电导天线辐射源,具有不同的极化类型,并且具有激发面积大,转换效率高的优点。该系列太赫兹光电导天线最显著的特点是:除了通常的线性极化外,还可以产生径向或者方位偏振的太赫兹辐射。径向极化辐射特别适合比如使用线波导进行传输的应用。用飞秒激光脉冲激发的光电导发射器是广泛使用的单周期太赫兹(THz)辐射脉冲源。通过应用交叉电极几何形状,可以显著提
    2107浏览量
