企业号介绍
全部
  • 全部
  • 产品
  • 方案
  • 文章
  • 资料
  • 企业
上海屹持光电技术有限公司
红外观察仪、飞秒激光器、太赫兹相机、太赫兹光谱仪
618 内容数 10w+ 浏览量 27 粉丝
传感、探测器用镜片 Optics for Sensors and Detectors
型号: Optics for Sensors and Detecto
--- 产品详情 ---
资料下载:Download Components for Optics for Sensors and Detectors Datasheet (PDF, 190 KB)
Sensors as well as varios systems on their base are widly used and discover new and new areas for applciations on almost all aspects of human activity. Optical IR-sensors and detectors belong to a special niche since are allowed to control and manage the processes which take place at room and much low temperatures. Majority of the devices here are remote-acting and non-contact.
Application of Wien's law to human body emission results in a peak wavelength of
For this reason, thermal imaging devices for human subjects are most sensitive in the 7‑14um range.
For monitoring and temperature measurements of higher heated environments the wavelength range 3-5um is used.
Practically all organic and inorganic compounds have the unique feature that they more or less good absorb at the diapason of  2‑15um. This cause the wide products line of IR-sensors and IR-detectors.
Tydex introduces various passive optics for the discussed topic.
Hereunder are some examples of the optical elements demonstrating the range of our products. Additional information is available in the following chapter - Frontal optics for ultimate applications.
1) Silicon meniscus lenses for 3-5 um IR detectors (pyrometers)
Application: production of concrete, steel, glasses, etc.
Specification:
Material
Si
Type
meniscus lens, plano-convex lens
Diameter, mm
29 (+0/-0.2)
Central thickness, mm
4 (+/-0.2)
EFL tolerance, %
+/-2
Surface quality, scr/dig
60/40
Surface figure, fringes
N<=5, deltaN<=1 @633nm
AR coating (BBAR/BBAR type),
R @3-5 um, %
<1 (see the curve below)
Transmission spectra of Si meniscus lens
2) Germanium windows for 8-12 um IR imager
Application: to be installed at helicopter for long-distanse monitoring of forest fire
Specification:
Material
Ge
Type
plano-plano window
Diameter, mm
120 (+0/-0.2)
Thickness, mm
4 (+/-0.2)
60/40
N<=5, delta N<=1 @633nm
AR coating (DLC/BBAR type),
R @8-12um, %
<5 (see the curve below)
Transmission spectra of Germanium windows for 8-12 um IR imager
3) Germanium meniscus lenses for 8-10 um IR imager
Application: sea-based system of 360 deg.-panoramic view
Specification:
Material
Ge
Type
meniscus lens
Diameter, mm
105 (+0/-0.2)
8 (+/-0.2)
EFL tolerance, %
+/-2
60/40
R @8-10 um, %
Transmission spectra of Germanium meniscus lenses for 8-10 um IR imager
4) Protective domes for pyranometers
Application: meteorology, climatology, environmental monitoring at green-houses and open fields
Specification:
Material
Glass, quarts
Type
dome
Diameter, mm
32 (+0/-0.2)
3.7 (+/-0.2)
80/50
5) Filter for pyrgeometers
Application: measuring an effective atmospheric IR radiation spectrum over wide spectral range (4.5-45 um)
Specification:
Material
FZ-Si
Type
plano-plano window, meniscus lens
Diameter, mm
31.8  (+0/-0.2)
Thickness, mm
1 (+/-0.1)
40/20
AR coating (DLC/solar blind type)
6) Sapphire window for under-water sensors
Application - to be installed at bathyscaphe to monitor continental shelf, ship's bottom, etc
Specification:
Material
Sapphire
Type
plano-plano window
Diameter, mm
77 (+0/-0.2)
Thickness, mm
6.0 (+/-0.2)
60/40
7) Si bullet-lens for 3-5 um IR immersion LED's and photodiodes
Application: to be used as lighter emitter
Specification:
Material
Si
Type
bullet-lens
Diameter, mm
3.5  (+0/-0.4)
3.21  (+/-0.05)
40/20
N<=5,
delta N<=1 @633nm
AR coating (one side BBAR @3-5 um)
Si bullet-lens
Transmission spectra of Si bullet-lens for 3-5 um IR immersion LED's and photodiodes
8) CaF2 bullet-lens for 3-5 um IR immersion LED's and photodiodes
Application: environmental monitoring
Specification:
Material
CaF2
Type
bi-convex lens
Diameter, mm
11 (+0/-0.1)
5.3 (+/-0.2)
EFL @4.25um, mm
12.5
80/50
N<=2, delta  N<=1 @633nm
CaF2 bullet-lens
9) ZnSe lens for 10.6 um laser
Application: laser industry, CO2- and CO-detectors, medicine
Specification:
Material
CVD-ZnSe
Type
plano-convex lens
Diameter, mm
12.7 (+0/-0.2)
2.0  (+/-0.2)
EFL tolerance, %
+/-2
40/20
N<=1,
delta N<=0.5 @633nm
AR coating (AR/AR type), R @10.6 um, %
<0.5 (see the curve below)
ZnSe lens
Transmission spectra of ZnSe lens for 10.6 um laser
10) ZnSe  beamsplitter
Application: monitoring of air quality, nitrogen fixation, fruit storage, mycology, medicine
Specification:
Material
CVD-ZnSe
Type
plano-plano window
Diameter, mm
25 (+0/-0.2)
Thickness, mm
4 (+/-0.2)
40/20
Coating
 -S1: AR @10.3 um
 -S2: R=90%+/-5% @10.3um
ZnSe lens beamsplitter
Transmission spectra of ZnSe lens beamsplitter
11) ZnSe window for IR detectors, etc.
Application: monitoring of air quality, nitrogen fixation, fruit storage, mycology, medicine.
Specification:
Material
CVD-ZnSe
Type
plano-plano window
Diameter, mm
12.7 (+0/-0.2)
Thickness, mm
3.0  (+/-0.2)
60/40
N<=1,
deltaN<=0.5 @633nm
AR coating (AR/AR type), R @ 4.5um, %
Transmission spectra of ZnSe window for IR detectors
12) Teflon IR polarizer
Application: methane leak detectors
Specification:
Material
Teflon
Diameter, mm
12.7 (+0/-0.2)
Transmission curve
See the chapter IR Polarizers
Teflon IR polarizer
We are pleased to emphasize that the list of similar components is permanently replenished and we are ready to considerate yuor new RFQ's.
为你推荐
  • SSFS飞秒激光孤子自频移波长调谐技术2024-07-02 09:17
    SSFS孤子自频移飞秒激光波长调谐模块利用SSFS孤子自频移现象(Soliton self-frequency shift ),允许用户在近红外范围内对飞秒激光进行波长调谐。通常,来自固定波长掺铒飞秒光源的孤子可以从1550 nm范围调谐到2100 nm波长。通过改变输入光功率,可以很容易地调谐输出波长。波长偏移输出信号保持相干性和线性极化。模块完全即插即用
    2166浏览量
  • 1.5μ超紧凑型单次自相关仪正式上市2024-06-17 16:08
    µ-ROC紧凑型单次自相关仪现已推出 1.5 µm新版本,光谱范围覆盖1300-1700nm,专用于掺铒飞秒激光器。至此µ-ROC已经可以覆盖传统800nm、1um、1.5um波段,用户可以根据自身需求灵活选择。µ-ROC同样配备STAR Software专用软件,用户终身可以通过自动更新轻松免费地访问最新软件版本。
    1567浏览量
  • 近距离了解中红外可调谐光纤飞秒激光器 Femtum Ultratune 3400性能2024-06-17 14:26
    中红外可调谐光纤飞秒激光器UltraTune 3400是一款商业中红外超快激光器,其结构紧凑、免维护和可调谐激光系统是科学研究的理想工具。
    2324浏览量
  • 可输出不同偏振太赫兹波的光电导天线2024-05-14 11:21
    屹持光电推出的大面积光电导天线辐射源,具有不同的极化类型,并且具有激发面积大,转换效率高的优点。该系列太赫兹光电导天线最显著的特点是:除了通常的线性极化外,还可以产生径向或者方位偏振的太赫兹辐射。径向极化辐射特别适合比如使用线波导进行传输的应用。用飞秒激光脉冲激发的光电导发射器是广泛使用的单周期太赫兹(THz)辐射脉冲源。通过应用交叉电极几何形状,可以显著提
    2107浏览量
