企业号介绍
全部
  • 全部
  • 产品
  • 方案
  • 文章
  • 资料
  • 企业
上海屹持光电技术有限公司
红外观察仪、飞秒激光器、太赫兹相机、太赫兹光谱仪
618 内容数 10w+ 浏览量 27 粉丝
用于Nd:YAG激光器的镜片 Optics for Nd:YAG Lasers
型号: Optics for Nd:YAG Lasers
--- 产品详情 ---
资料下载:Download OOptics for Nd:YAG Lasers Datasheet (PDF, 172 KB)
Tydex offers various optics for Nd:YAG lasers which in parallel with CO2-lasers has found high spreading. Unique properties of these lasers - wavelength tuning from UV to near IR range, possibility to achieve high energy in pulse, high power in CW mode, and others make them the key laser source for different applications - industry, medicine, and research.
Together with K8 glass (analogue of Schott's BK7) majority of optical components here are made from UV Fused Silica - Russian quartz glass KU-1. Synthetic origin of the material manufactured by flame hydrolysis of SiCI4 results in high perfection and homogeneity; it is practically free of inclusions, bubbles, and other internal defects. High purity of the material together with relatively low refractive index allow achieving high transmission in UV and VIS ranges. The edges of transmission interval are 160nm and 4350nm, in VUV and IR, respectively, with OH absorption band at wavelength diapason 2600-2800nm. Analogues of quartz glass KU-1 are Suprasil (Heraeus), Spectrosil (Saint-Gobain) and Corning 7940 (Corning).
It should be said especially that in handling with these materials Tydex capacity is enough good vertically integrated. We use high quality raw material produced in Russia on time-proved technology existing from Soviet times. Our polishing process, electron beam coating technology, testing instruments and metrology tools, all of this results in high marketability of Tydex's goods in this field.
For the components various coatings emphasizing both lasing (1064nm, 1319nm) and a triple of non-linear crystals created wavelengths (532nm, 355nm, 266nm) are available.
Depending on customer needs Tydex offers the following parts:
—— Lenses
—— Windows
—— Mirrors
—— Scanning mirrors
—— Beamsplitters
—— Prisms
为你推荐
  • SSFS飞秒激光孤子自频移波长调谐技术2024-07-02 09:17
    SSFS孤子自频移飞秒激光波长调谐模块利用SSFS孤子自频移现象(Soliton self-frequency shift ),允许用户在近红外范围内对飞秒激光进行波长调谐。通常,来自固定波长掺铒飞秒光源的孤子可以从1550 nm范围调谐到2100 nm波长。通过改变输入光功率,可以很容易地调谐输出波长。波长偏移输出信号保持相干性和线性极化。模块完全即插即用
    2166浏览量
  • 1.5μ超紧凑型单次自相关仪正式上市2024-06-17 16:08
    µ-ROC紧凑型单次自相关仪现已推出 1.5 µm新版本,光谱范围覆盖1300-1700nm,专用于掺铒飞秒激光器。至此µ-ROC已经可以覆盖传统800nm、1um、1.5um波段,用户可以根据自身需求灵活选择。µ-ROC同样配备STAR Software专用软件,用户终身可以通过自动更新轻松免费地访问最新软件版本。
    1567浏览量
  • 近距离了解中红外可调谐光纤飞秒激光器 Femtum Ultratune 3400性能2024-06-17 14:26
    中红外可调谐光纤飞秒激光器UltraTune 3400是一款商业中红外超快激光器,其结构紧凑、免维护和可调谐激光系统是科学研究的理想工具。
    2324浏览量
  • 可输出不同偏振太赫兹波的光电导天线2024-05-14 11:21
    屹持光电推出的大面积光电导天线辐射源,具有不同的极化类型,并且具有激发面积大,转换效率高的优点。该系列太赫兹光电导天线最显著的特点是:除了通常的线性极化外,还可以产生径向或者方位偏振的太赫兹辐射。径向极化辐射特别适合比如使用线波导进行传输的应用。用飞秒激光脉冲激发的光电导发射器是广泛使用的单周期太赫兹(THz)辐射脉冲源。通过应用交叉电极几何形状,可以显著提
    2107浏览量
