--- 产品详情 ---
Calcium fluoride is a superb optical material. It is often chosen by laser optics manufacturers for its wide transmission range, low absorption and low refraction. Compared to other fluorides, CaF2is much more resistant to moisture and to thermal shock. CaF2 optics are commonly used in imaging, thermal imaging, astronomy, microlithography and high-power lasers.
Basic properties |
Syngony
Cubic Symmetry class
M3m Lattice constants
A=5.462 c=a Cleavability
(111) Refractive index at Nd
1.4349 Refractive index at Nf -Nc
0.0043 Refractive index at N10.6
1.2996 Reflection loss
5.5 % Transmission range
0.15-9 μm Density
3.18 g/ cm3 Melting point
1360 ° С Thermal conductivity index
9.71 Вт/(м K) Thermal expansion index
18.5 x 10-6/К Knoop hardness
158.3 kg/mm2 (100) Specific heat
854 J/(kg K) Dielectric constant (f=1 MHz)
6.76 Young’s Modulus, E
75.8 GPa Shear modulus, G
33.77 GPa Modulus of volume elasticity, K
82.71 GPa Elastic strength
36.54 MPa Poissont ratio
0.26 Solubility
0.0017 g / 100 g of water at T= 20 °C Molecular weight
78.08 |
CaF2 Transmission![]() |
CaF2 Refractive Indices |
λ, μm
Refractive index 0.19
1.51 0.21
1.49 0.25
1.47 0.33
1.45 0.41
1.44 0.88
1.43 2.65
1.42 3.90
1.41 5.00
1.40 6.20
1.38 7.00
1.36 8.22
1.34 |
Products |
| CaF2 blanks and windows for IR applications |
Diameter/Width
12.7-101.6 +/-0.2 mm Thickness/length
2-12 +/-0.2 mm Surface quality
As-cut, 80/50, 60/40 per MIL-0-13830 Wedge
< 5’ Clear aperture
90% |
CaF2 optical prisms for IR applications |
Length/Width
7-25.4 +/-0.1 mm Thickness/length
7-25.4 +/-0.1 mm Surface quality
80/50, 60/40 per MIL-0-13830 Corner tolerance
+/-10’’ Total surface error
λ / 2 |
CaF2 optical wedges for IR applications |
Diameter/Width
2-10 +/-0.1 mm Surface quality
80/50, 60/40 per MIL-0-13830 Wedge tolerance
+/- 3’ Total surface error
λ / 2 Clear aperture
90% |
更多晶体相关产品
>> 碲化锌晶体 ZnTe晶体
>> 铌酸锂晶体 LiNbO3晶体
>> 硒化锌晶体 ZnSe晶体
>> 硒化镓晶体 GaSe晶体
>> 硫化锌晶体 ZnS晶体
>> 磷化镓晶体 GaP晶体
>> 有机晶体 DAST晶体
>> 有机晶体 DSTMS晶体
>> 有机晶体 OH1晶体
上海屹持光电技术有限公司
地址:上海市闵行区剑川路955号1108室
为你推荐
低噪声可调增益平衡探测器2026-11-06 16:58
产品型号:LZPD450C-DC、LZPD450A-DC -
200um InGaAs APD 前置放大器接收器2026-11-06 16:57
产品型号:LZ200-1550-70M -
高速 InGaAs PIN光电探测器2026-11-06 16:55
产品型号:LZPD-5G-P -
2um高速光电探测器2026-10-10 18:17
产品型号:2um高速光电探测器 -
激光光束指向稳定系统2026-09-18 11:51
产品型号:紧凑型 -
激光自动对焦自准直仪2026-09-17 13:37
产品型号:EAC-1012-19-FO-E-25 -
碘化铯X射线闪烁体CsI X-ray Scintillators2026-08-18 10:57
产品型号:CsI -
柔性X射线CsI碘化铯闪烁体2026-08-18 10:51
产品型号: CsI -
X射线闪烁体屏幕X光荧光屏2026-08-18 10:50
产品型号:Luminex -
傅里叶分束镜FTIR分束器/补偿器对2026-08-18 10:48
产品型号:FTIR Beam Splitter
SSFS飞秒激光孤子自频移波长调谐技术2024-07-02 09:17
1.5μ超紧凑型单次自相关仪正式上市2024-06-17 16:08
近距离了解中红外可调谐光纤飞秒激光器 Femtum Ultratune 3400性能2024-06-17 14:26
可输出不同偏振太赫兹波的光电导天线2024-05-14 11:21
