企业号介绍
全部
  • 全部
  • 产品
  • 方案
  • 文章
  • 资料
  • 企业
上海屹持光电技术有限公司
红外观察仪、飞秒激光器、太赫兹相机、太赫兹光谱仪
618 内容数 10w+ 浏览量 27 粉丝
SOC可饱和输出耦合器 saturable output coupler
型号: SOC
--- 产品详情 ---
产品介绍        >>可饱和输出耦合器SOC工作原理?
利用一个可饱和输出耦合器SOC,就可以简便建立一个自启动的被动锁模二极管泵浦固体激光器。可饱和输出耦合器是将可饱和吸收镜SAM和一个输出耦合器结合在一起。
规格参数
SOC - saturable output coupler λ = 1040 nm
Part No.DescriptionData
PDF
SOC-1040-2-3-1ps-x SOC: λ = 1040 nm, absorptance 2 %, , transmittance 3 %, relaxation time ~ 1 ps, Δ R = 1.2 %, relaxation time 1 ps
PDF Data
SOC-1040-3-0.4-1ps-x SOC: λ = 1040 nm, absorptance 3 %, transmittance 0.4 %, relaxation time ~ 1 ps, Δ R = 1.8 %, relaxation time 1 ps
PDF Data
SOC-1040-3-4-1ps-x SOC: λ = 1040 nm, absorptance 3 %, transmittance 4 %, relaxation time ~ 1 ps, Δ R = 1.8 %, relaxation time 1 ps
PDF Data
SOC-1040-5-5-1ps-x SOC: λ = 1040 nm, absorptance 5 %, transmittance 5 %, relaxation time ~ 1 ps, Δ R = 3 %, relaxation time 1 ps
PDF Data
SOC-1040-6-0.5-1ps-x SOC: λ = 1040 nm, absorptance 6 %, transmittance 0.5 %, relaxation time ~ 1 ps, Δ R = 3.5 %, relaxation time 1 ps
PDF Data
SOC-1040-6-2-1ps-x SOC: λ = 1040 nm, absorptance 6 %, transmittance 2 %, relaxation time ~ 1 ps, Δ R = 3.5 %, relaxation time 1 ps
PDF Data
SOC-1040-7-2-1ps-x SOC: λ = 1040 nm, absorptance 7 %, transmittance 2 %, relaxation time ~ 1 ps, Δ R = 4 %, relaxation time 1 ps
PDF Data
SOC-1040-8-0.6-1ps-x SOC: λ = 1040 nm, absorptance 8 %, transmittance 0.6 %, relaxation time ~ 1 ps, Δ R = 5 %, relaxation time 1 ps
PDF Data
SOC-1040-8-6-15ps-x SOC: λ = 1040 nm, absorptance 8 %, transmittance 6 %, relaxation time ~ 15 ps, Δ R = 4.5 %, relaxation time 15 ps
PDF Data
SOC-1040-9-9-1ps-x SOC: λ = 1040 nm, absorptance 9 %, transmittance 9 %, Δ R = 5 %, relaxation time 1 ps
PDF Data
SOC-1040-11-3-1ps-x SOC: λ = 1040 nm, absorptance 11 %, transmittance 3 %, Δ R = 6 %, relaxation time 1 ps
PDF Data
SOC-1040-14-10-15ps-x SOC: λ = 1040 nm, absorptance 14 %, transmittance 10 %, Δ R = 7.5 %, relaxation time 15 ps
PDF Data
SOC-1040-17-5-1ps-x SOC: λ = 1040 nm, absorptance 17 %, transmittance 5 %, Δ R = 10 %, relaxation time 1 ps
PDF Data
SOC-1040-24-19-15ps-x SOC: λ = 1040 nm, absorptance 24 %, transmittance 19 %, Δ R = 9.5 %, relaxation time 15 ps
PDF Data
saturable output coupler with short relaxation time ~ 1 ps
PDF
SOC-1064-1-1-5ps-x SOC: λ = 1064 nm, absorptance 1 %, transmittance 1 %, relaxation time ~ 5 ps, Δ R = 0.6 %,
PDF Data
SOC-1064-1.8-2.2-1ps-x SOC: λ = 1064 nm, absorptance 1.8 %, transmittance 2.2 %, relaxation time ~ 1 ps, Δ R = 1.1 %,
PDF Data
SOC-1064-2.0-0.3-1ps-x SOC: λ = 1064 nm, absorptance 2.0 %, transmittance 0.3 %, relaxation time ~ 1 ps , Δ R = 1.2 %
PDF Data
SOC-1064-2.7-3.2-1ps-x SOC: λ = 1064 nm, absorptance 2.7 %, transmittance 3.2 %, relaxation time ~ 1 ps , Δ R = 1.7 %
PDF Data
SOC-1064-4-0.5-1ps-x SOC: λ = 1064 nm, absorptance 4 %, transmittance 0.5 %, relaxation time ~ 1 ps, Δ R = 2.8 %
PDF Data
SOC-1064-7-0.7-1ps-x SOC: λ = 1064 nm, absorptance 7 %, transmittance 0.7 %, relaxation time ~ 1 ps, Δ R = 4 %
PDF Data
SOC-1064-8-6-1ps-x SOC: λ = 1064 nm, absorptance 8 %, transmittance 6 %, relaxation time ~ 1 ps, Δ R = 4 %
PDF Data
saturable output coupler with short relaxation time ~ 17 ps
Part No. DescriptionData
PDF
SOC-1064-8-8-15ps-x SOC: λ = 1064 nm, absorptance 8 %, transmittance 8 %, relaxation time 15 ps, Δ R = 4.5 %
PDF Data
SOC-1064-9-13-17ps-x SOC: λ = 1064 nm, absorptance 9 %, transmittance 13 %, relaxation time 17 ps, Δ R = 6 %
PDF Data
SOC-1064-13-12-15ps-x SOC: λ = 1064 nm, absorptance 13 %, transmittance 12 %, relaxation time 15 ps, Δ R = 6.5 %
PDF Data
SOC-1064-15-23-17ps-x SOC: λ = 1064 nm, absorptance 15 %, transmittance 23 %, relaxation time 17 ps, Δ R = 8 %
PDF Data
SOC-1064-22-19-15ps-x SOC: λ = 1064 nm, absorptance 22 %, transmittance 19 %, relaxation time 15 ps, Δ R = 9.5 %
PDF Data
SOC - saturable output coupler λ = 2000 nm
Saturable output coupler for free space applications. Chip thickness: 625 μm
PDF
SOC-2000-26-19-1ps-x SOC: λ = 2000 nm, absorptance 26 %, transmittance 19 %, relaxation time ~ 1 ps, Δ R = 15 %, reflectance 55 %, chip thickness: 625 μm
PDF Data
SOC-2000-40-28-1ps-x SOC: λ = 2000 nm, absorptance 40 %, transmittance 28 %, relaxation time ~ 1 ps, Δ R = 23 %, reflectance 32 %, chip thickness: 625 μm
PDF Data
Thin saturable output coupler for fiber butt coupling. Chip thickness: 140 μm
PDF
SOC-2000-26-24-1ps-x-thin SOC: λ = 2000 nm, absorptance 26 %, transmittance 24 %, relaxation time ~ 1 ps, Δ R = 15 %, reflectance 50 %, chip thickness: 140 μm
PDF Data
Part No. description
Part No. exampleDescriptionData PDF
 SOC-2000-26-1ps-xS aturable Output Coupler
 SOC-2000-26-1ps-xworking wavelength 2000 nm
 SOC-2000-26-1ps-xabsorptance 26 %
 SOC-2000-26-1ps-xrelaxation time 1 ps
 SOC-2000-26-1ps-0unmounted chip, area: 5 mm x 5 mm, chip thickness: 625 µm
PDF Data
 SOC-2000-26-1ps-0-thinunmounted chip, area: 1.0 mm x 1.0 mm or 1.3 mm x 1.3 mm, chip thickness: 140 µm, batch of 5 pieces
PDF Data
 SOC-2000-26-1ps-12.7 gmounted: glued on a copper heat sink with 12.7 mm Ø and 4 mm centre hole, chip thickness: 625 µm
PDF Data
 SOC-2000-26-1ps-25.4 gmounted: glued on a copper heat sink with 25.4 mm Ø and 4 mm centre hole, chip thickness: 625 µm
PDF Data
 SOC-2000-26-1ps-FC/PCmounted on a 1 m monomode fiber cable with FC/PC or other connector type, chip thickness: 140 µm
PDF Data
为你推荐
  • SSFS飞秒激光孤子自频移波长调谐技术2024-07-02 09:17
    SSFS孤子自频移飞秒激光波长调谐模块利用SSFS孤子自频移现象(Soliton self-frequency shift ),允许用户在近红外范围内对飞秒激光进行波长调谐。通常,来自固定波长掺铒飞秒光源的孤子可以从1550 nm范围调谐到2100 nm波长。通过改变输入光功率,可以很容易地调谐输出波长。波长偏移输出信号保持相干性和线性极化。模块完全即插即用
    2166浏览量
  • 1.5μ超紧凑型单次自相关仪正式上市2024-06-17 16:08
    µ-ROC紧凑型单次自相关仪现已推出 1.5 µm新版本,光谱范围覆盖1300-1700nm,专用于掺铒飞秒激光器。至此µ-ROC已经可以覆盖传统800nm、1um、1.5um波段,用户可以根据自身需求灵活选择。µ-ROC同样配备STAR Software专用软件,用户终身可以通过自动更新轻松免费地访问最新软件版本。
    1567浏览量
  • 近距离了解中红外可调谐光纤飞秒激光器 Femtum Ultratune 3400性能2024-06-17 14:26
    中红外可调谐光纤飞秒激光器UltraTune 3400是一款商业中红外超快激光器,其结构紧凑、免维护和可调谐激光系统是科学研究的理想工具。
    2324浏览量
  • 可输出不同偏振太赫兹波的光电导天线2024-05-14 11:21
    屹持光电推出的大面积光电导天线辐射源,具有不同的极化类型,并且具有激发面积大,转换效率高的优点。该系列太赫兹光电导天线最显著的特点是:除了通常的线性极化外,还可以产生径向或者方位偏振的太赫兹辐射。径向极化辐射特别适合比如使用线波导进行传输的应用。用飞秒激光脉冲激发的光电导发射器是广泛使用的单周期太赫兹(THz)辐射脉冲源。通过应用交叉电极几何形状,可以显著提
    2107浏览量
