--- 产品详情 ---
产品简介 >>共振可饱和吸收镜RSAM工作原理?
共振可饱和吸收镜RSAM类似于可饱和吸收镜SAM,但是有更大的饱和吸收率、更小的带宽以及更低的饱和通量。共振可饱和吸收镜被设计成Gires–Tournois干涉仪的结构,一块可饱和吸收体放置在共振腔内光学波腹处的位置,下图原理简介:
规格参数
RSAM™ - resonant saturable absorber mirror 980 nm
Part No. | Description | Data |
RSAM-980-1ps-x | RSAM: λ = 980 nm, modulation depth ΔR = 60 %, | ![]() |
RSAM-974-1ps-x | RSAM: λ = 974 nm, modulation depth ΔR = 60 %, | ![]()
RSAM™ - resonant saturable absorber mirror 1030 nm
RSAM-1030-9ps-x | RSAM: λ = 1030 nm, modulation depth ΔR = 60 %, | ![]() |
RSAM™ - resonant saturable absorber mirror 1064 nm
RSAM-1064-x | RSAM: λ = 1064 nm, modulation depth ΔR = 60 %, | ![]() |
RSAM-1060-x | RSAM: λ = 1060 nm, modulation depth ΔR = 55 %, | ![]()
RSAM™ - resonant saturable absorber mirror 1550 nm
RSAM-1550-10ps-4.0-x | RSAM: resonant saturable absorber mirror, λ = 1530 ... 1560 nm, resonant absorptance > 96 %, low intensity reflectance @ 1550 nm < 4 %, relaxation time ~ 10 ps | ![]() |
封装规格描述
| Part No. example | Description | Data PDF | ||
| RSAM-980-1ps-x | Resonant Saturable Absorber Mirror | |||
| RSAM-980-1ps-x | working wavelength 980 nm | |||
| RSAM-980-1ps-x | relaxation time 1 ps | |||
| unmounted RSAM, thickness: 450 µm | ||||
| RSAM-980-1ps-4.0-0 | chip area: 4.0 mm x 4.0 mm, unmounted | ![]() | ||
| RSAM-980-1ps-1.0b-0 | chip area: 1.0 mm x 1.0 mm, batch of 4 unmounted chips | ![]() | ||
| RSAM-980-1ps-1.3b-0 | chip area: 1.3 mm x 1.3 mm, batch of 4 unmounted chips | ![]() | ||
| FM-1.3 | Fiber Mount for 1.3 mm x 1.3 mm chips | ![]() | ||
| mounted RSAM , chip area 4mm x 4mm | ||||
| RSAM-980-1ps-4.0-12.7 g | glued on a copper heat sink with 12.7 mm diameter | ![]() | ||
| RSAM-980-1ps-4.025.0 g | glued on a copper heat sink with 25.0 mm diameter | ![]() | ||
| RSAM-980-1ps-4.0-25.4 g | glued on a copper heat sink with 25.4 mm diameter | ![]() | ||
| RSAM-980-1ps-4.0-12.7 s | soldered on a copper heat sink with 12.7 mm diameter | ![]() | ||
| RSAM-980-1ps-4.0-25.0 s | soldered on a copper heat sink with 25.0 mm diameter | ![]() | ||
| RSAM-980-1ps-4.0-25.4 s | soldered on a copper heat sink with 25.4 mm diameter | ![]() | ||
| RSAM-980-1ps-4.0-25.0 h | thin film soldered 4.0 mm x 4.0 mm chip on water cooled copper heat sink with25.0 mm diameter for high power applications | ![]() | ||
| mounting position of the RSAM chip |
![]() center mounted ![]() edge mounted | |||
| RSAM-980-1ps-4.0-12.7g-c | center position | |||
| RSAM-980-1ps-4.0-12.7g-e | edge position | |||
| fiber mounted RSAMs-x | ||||
| RSAM-980-1ps-FC/PC | mounted on a 1 m long single mode fiber with FC/PC or other connector type | ![]() | ||
| RSAM-980-1ps-FC/PC with TEC | mounted on a 1 m long single mode fiber with FC/PC or other connector type and TEC (thermoelectric cooler) for fine tuning of the resonance wavelength | ![]() | ||
更多可饱和吸收体产品
>> 半导体可饱和吸收镜 SESAM
>> 可饱和输出耦合器 SOC
>> 共振可饱和吸收镜 RSAM
>> 可饱和噪声抑制器 SANOS
>> 透射型可饱和吸收体 SA
为你推荐
低噪声可调增益平衡探测器2026-11-06 16:58
产品型号:LZPD450C-DC、LZPD450A-DC -
200um InGaAs APD 前置放大器接收器2026-11-06 16:57
产品型号:LZ200-1550-70M -
高速 InGaAs PIN光电探测器2026-11-06 16:55
产品型号:LZPD-5G-P -
2um高速光电探测器2026-10-10 18:17
产品型号:2um高速光电探测器 -
激光光束指向稳定系统2026-09-18 11:51
产品型号:紧凑型 -
激光自动对焦自准直仪2026-09-17 13:37
产品型号:EAC-1012-19-FO-E-25 -
碘化铯X射线闪烁体CsI X-ray Scintillators2026-08-18 10:57
产品型号:CsI -
柔性X射线CsI碘化铯闪烁体2026-08-18 10:51
产品型号: CsI -
X射线闪烁体屏幕X光荧光屏2026-08-18 10:50
产品型号:Luminex -
傅里叶分束镜FTIR分束器/补偿器对2026-08-18 10:48
产品型号:FTIR Beam Splitter
SSFS飞秒激光孤子自频移波长调谐技术2024-07-02 09:17
1.5μ超紧凑型单次自相关仪正式上市2024-06-17 16:08
近距离了解中红外可调谐光纤飞秒激光器 Femtum Ultratune 3400性能2024-06-17 14:26
可输出不同偏振太赫兹波的光电导天线2024-05-14 11:21
