电子发烧友App
硬声App
电子发烧友网>通信网络>通信设计应用>Interfacing the MAX5195 High-S
收藏
查看更多
1N5195
1N5195 - SI RECTIFIER - New Jersey Semi-Conductor Products, Inc.
2022-11-04 17:22:44
1N5195
1N5195 - SWITCHING DIODE - Microsemi Corporation
2022-11-04 17:22:44
1N5195UR
1N5195UR - SWITCHING DIODE - Microsemi Corporation
2022-11-04 17:22:44
2N5195
2N5195 - PNP SILICON POWER TRANSISTORS - Central Semiconductor Corp
2022-11-04 17:22:44
2N5195
2N5195 - Silicon PNP Power Transistors - Inchange Semiconductor Company Limited
2022-11-04 17:22:44
2N5195
2N5195 - Silicon PNP Power Transistors - Quanzhou Jinmei Electronic Co.,Ltd.
2022-11-04 17:22:44
2N5195
2N5195 - Silicon PNP Power Transistors - Savantic, Inc.
2022-11-04 17:22:44
2N5195_00
2N5195_00 - MEDIUM POWER PNP SILICON TRANSISTOR - STMicroelectronics
2022-11-04 17:22:44
Interfacing SDRAM Memory on High Performance Microcontrollers
additional memory for code and data when interfacing with High Speed LCD Panels.特性• Designed for (formerly
2015-04-08 10:33:35
AN5195K
AN5195K - Single chip IC for PAL/NTSC color TV (built-in I2C bus interface) - Panasonic Semiconductor
2022-11-04 17:22:44
AN5195K-C
AN5195K-C - Single chip IC for PAL/NTSC color TV (built-in I2C bus interface) - Panasonic Semiconductor
2022-11-04 17:22:44
CD5195
CD5195 - GENERAL PURPOSE SILICON DIODES - Microsemi Corporation
2022-11-04 17:22:44
EUS-704.01-5195
* (704-01-5195) LPB RND W/GREEN
2024-03-14 21:15:08
EUS-704.02-5195
* (704-02-5195) PB RND W/GREEN L
2024-03-14 21:14:58
HIP5061 HIGH EFFICIENCY, HIGH PERFORMANCE,HIGH POWER CONVERTER
IntroductionAs the complexity of sophisticated, modern day equipmentgrows, the need for high
2009-05-12 11:13:19
LPC55S6x high speed spi 求助
hi,all 最近在做芯片选型,需要寻找一款支持50MHz工作频率的SPI接口,观察到LPC55S6x 在high speed spi mode下宣称可以工作到50MHz,但看其timing数据
2020-03-06 17:26:09
PMP5195技术参数及设计
描述The PMP5195 reference design generates an isolated 5V at 60W. This design uses the UCC28610
2018-07-13 10:22:47
工业仪器ADC温度传感器MS5194/MS5195参数与替代
描述MS5194/MS5195分别是24位和16位的ADC,高精度测量应用的低功耗、低噪声、六通道差分输入的 24bit/16bit 模数转换器。其内部集成了低噪声输入缓冲器、低噪声仪表放大器、精密
2022-04-27 22:45:36
彩电微处理芯片AN5195B相关资料下载
概述:AN5195B是松下半导体出品的一款用作于CRT彩电中的中放,解码,行场扫描小信号处理芯片,支持I2C总线控制。它采用64引脚SDIP封装工艺。 一、引脚功能与实测电压(在创维4
2021-04-06 09:40:51
请高手指点TEK示波器测试波形电压时:High,Low,Max,Min的....
请高手指点TEK示波器测试波形电压时:High,Low,Max,Min的区别,主要是High和Low的意义???
2012-07-30 20:48:16
长虹CHD4311WCHD4011WCHD3851CHD3891JP5195HP5189HP5175背投电视原理图相关资料推荐
长虹CHD4311W/CHD4011W/CHD3851/CHD3891/JP5195/HP5189/HP5175背投电视原理图文件下载
2021-05-31 06:07:01
长虹HP4389HP4391KP5195KP4395JP7025JP6125背投电视原理图相关资料推荐
长虹HP4389/HP4391/KP5195/KP4395/JP7025/JP6125背投电视原理图文件下载
2021-05-31 07:11:44
长虹KP4395KP5195背投维修手册含原理图相关资料推荐
长虹KP4395/KP5195背投维修手册(含原理图)文件下载
2021-05-28 06:03:55
高度可靠的霍耳传感器接口集成方案
)VOUT (V)8.25-810.85-4-20+2+4+810.9The MAX9921's high-side current-sense topology makes the device
2008-10-06 14:33:47
MN152810 an5195应用电路图
2008-01-10 22:06:3229
MAX5195 pdf,MAX5195 datasheet
The MAX5195 is an advanced, 14-bit, 260Msps digitalto-analog converter (DAC) designed to meet
2008-09-11 21:59:3418
AN5195k/AN5195k-b/C pdf datash
The AN5195K-C is an IC in which all of thePAL/NTSC system color television signal
2008-09-24 23:58:1723
MAX6816, MAX6817, MAX6818 pdf
The MAX6816/MAX6817/MAX6818 are single, dual, and octal switch debouncers that provide clean
2008-10-01 23:30:1017
74HCT241 pdf datasheet (high-s
GENERAL DESCRIPTIONThe 74HC/HCT241 are high-speed Si-gate CMOS devicesand are pin compatible
2008-10-10 17:26:4212
MAX038 datasheet (High-Frequen
The MAX038 is a high-frequency, precision functiongenerator producing accurate, high
2008-10-24 10:28:5443
MAX13430E, MAX13431E, MAX13432
The MAX13430E–MAX13433E are full- and half-duplex RS-485 transceivers that feature an adjustable
2008-11-27 16:53:1126
MAX9610 pdf datasheet (high-si
The MAX9610 high-side current-sense amplifier offers precision accuracy specifications of VOS less
2008-12-02 23:11:0610
HA-5195 pdf datasheet (150MHz,
The HA-5195 is a operational amplifier featuring acombination of speed, precision, and bandwidth.
2009-01-07 14:47:4415
MAX1886 pdf datasheet (High-Cu
The MAX1886 is a high-current operational transconductanceamplifier. The MAX1886 is ideal
2009-01-11 11:04:235
MAX9360, MAX9361 pdf datasheet
designed for high-speed signal and clock driver applications.For interfacing to LVTTL/TTL/CMOS input signals,these devices operate over a 3.0V to
2009-01-22 14:45:2124
Interfacing 3V and 5V applicat
THE NEED FOR INTERFACING BETWEEN 3VAND 5V SYSTEMSMany reasons exist to introduce 3V1 systems
2009-03-30 00:17:329
Interfacing the DS18X20/DS1822
Interfacing the DS18X20/DS1822 1-Wire Temperature Sensor in a Microcontroller Environment
2009-05-08 11:37:5420
MAX13041,pdf datasheet (High-S
The MAX13041 ±80V fault-protected, high-speed controllerarea network (CAN) transceiver is ideal
2009-06-19 07:40:1096
MAX16803,pdf datasheet (High-B
to a total of350mA to one or more strings of high-brightness LEDs(HB LEDs). The output current of the MAX16803 isadjusted by usin
2009-09-18 08:42:2326
Interfacing to High Speed ADCs
Interfacing to High Speed ADCs via SPI:This application note describes how to use the SPI port
2009-09-30 19:43:3915
MAX4885AE,pdf datasheet (High-
The MAX4885AE integrates high-bandwidth analog switches, level-translating buffers
2009-11-16 18:20:0227
MAX3370, MAX3371,pdf datasheet
The MAX3370/MAX3371 logic-level translators are ideal for applications interfacing low-voltage
2009-11-18 18:42:3620
MAX15054,pdf datasheet (High-S
The MAX15054 is a high-side, n-channel MOSFET driver for high-voltage applications capable
2010-01-28 08:41:1832
Interfacing the TLC5510 Analog
This application report is a summary of the application note titled Interfacing the TLC5510Analog
2010-06-02 09:42:007
Interfacing the TLV2541 to the
This application report discusses the SPI interfacing implementation of a system featuringthe
2010-06-04 17:27:1110
MAX98500,pdf (high-efficiency
The MAX98500 is a high-efficiency Class D audio amplifier that features an integrated boost
2010-06-15 08:48:5241
MAX13450/MAX13450E/MAX13451E,p
The MAX13450E/MAX13451E are half-duplex and full-duplex RS-485/RS-422 transceivers. These devices
2010-06-16 09:47:04106
MAX16804,pdf (High-Voltage, 35
to 350mA toone or more strings of high-brightness LEDs (HB LEDs).The output current of the MAX16804 is set by using anexternal
2010-07-20 08:09:5131
MAX11209/MAX11211pdf (high-re
The MAX11209/MAX11211 are ultra-low-power (< 300µA active current) high-resolution serial-output
2010-08-22 10:13:2719
TLE2022AM,pdf(Excalibur High-S
The TLE202x, TLE202xA, and TLE202xB devices are precision, high-speed, low-power operational
2010-09-16 22:50:4913
INA138-Q1,INA168-Q1,pdf(High-S
The INA138 and INA168 are high-side, unipolar, current shunt monitors. Wide input common-mode
2010-09-24 22:20:4920
MAX17108 10-Channel High-Volta
MAX17108 10-Channel High-Voltage Scan Driver and VCOM Amplifier for TFT LCD Panels Description
2009-02-02 16:03:131116
MAX1709 4A, Low-Noise, High-Fr
MAX1709 4A, Low-Noise, High-Frequency, Step-Up DC-DC Converter MAX1709 Description The MAX
2009-02-08 19:12:271149
Interfacing 8051-based Microco
Interfacing 8051-based Microcontrollers Abstract: This application note describes how to configure
2009-03-31 22:19:50777
of the MAX5195 high-speed digital-to-analog converter (DAC) to design a reliab
2009-04-16 16:36:03742
Critical DAC Parameters for Mu
converter (DAC) MAX5195 with LVPECL digital inputs fits into GSM/EDGE-based transceiver designs. The article details the exact SFDR, IMD, SNR
2009-04-16 16:56:51687
Interfacing to the DS1631 Digi
Abstract: This application note introduces the user to software for interfacing a DS5000 (8051
2009-04-18 10:28:04678
Interfacing the DS2155 to the
processor to the DS2155 T1/E1/J1 Single Chip Transceiver (SCT). The application note covers interfacing both the address and data processor bus
2009-04-20 09:46:53575
DS2151, DS2153 Interfacing to
Abstract: Interfacing between the Hitachi HD64570 and the DS2151 for T1 lines or the DS2153 for E1 lines. MCSI-0 and MCS-1 are in Bit Synchronous
2009-04-20 10:38:06750
Interfacing an SPI RTC with a
Abstract: This application note provides an example of hardware and software for interfacing
2009-04-21 09:35:43854
Interfacing a DS3234 Extremely
2009-04-21 09:53:58958
2009-04-23 15:02:56896
Interfacing the MAX7651/MAX765
to interface the MAX7651 and MAX7652 12-bit data acquisition system to the 24C02 2-wire serial EEPROM. Detailed software code is provided. Since
2009-04-23 15:12:091302
采用高速单片机作为引导加载-Using the High-S
Abstract: This application note highlights the use of the Dallas Semiconductor High
2009-04-23 15:25:56791
高速微型存储器接口时序-High-Speed Micro M
Abstract: This application note addresses external memory interfacing with Maxim high
2009-04-23 15:35:10918
关键参数的数模转换器多载波GSM/EDGE的发射机
2009-04-25 09:40:04850
关键参数的数模转换器多载波GSM / EDGE的发射机-Cr
2009-05-01 11:05:48713
of the MAX5195 high-speed digital-to-analog converter (DAC) to design a reliable resistor network for interface this LVPECL-based high-speed DAC to
2009-05-01 11:06:44527
Interfacing the MAX195 ADC to
Abstract: Application note for interfacing the MAX195 and MAX194 analog-to-digital converters (ADCs
2009-05-08 09:16:101552
Interfacing the MAX187 to the
Abstract: This application note describes how to interface the MAX187 to the TMS320C3X DSP EV
2009-05-08 09:47:46728
2009-05-08 10:38:38971
2009-05-08 10:41:03701
MAX5965A, MAX5965B High-perfor
MAX5965A, MAX5965B High-performance, monolithic quad PSE controller enables IEEE 802.3at (PoE+) applications The MAX5965 meets IE
2009-08-11 11:56:411227
MAX16839 Linear High-Brightnes
MAX16839 Linear High-Brightness LED Driver with Open-LED Fault Detect The MAX16839 programmable
2009-08-26 11:29:541281
Reference Design for a High-In
Reference Design for a High-Input-Voltage, High-Output-Current Buck Controller Using the MAX
2009-11-08 17:43:051130
MAX16839 High-input-voltage, l
MAX16839 High-input-voltage, linear 100mA HB LED driver provides fault output and multichip interoperability for automotive lighting
2009-12-10 12:46:53730
MAX15054 New high-side FET dri
MAX15054 New high-side FET driver simplifies the design of buck and buck-boost HB LED drivers
2010-01-28 08:39:021324
MAX9643 (a high-speed 60V precision unidirectional)
The MAX9643 is a high-speed 60V precision unidirectionalcurrent-sense amplifier ideal for a wide
2011-09-26 11:58:5912
Interfacing with C: Programming
Interfacing with C: Programming Real-World Applications C接口:编程现实世界的应用,教你如何进行专业的C编程!
2015-11-10 17:39:540
DSP systems_ interfacing with th
DSP systems_ interfacing with the outside world
2016-05-06 15:13:287
2017-10-20 14:46:323
2N5195 4.0 A,80 V PNP双极功率晶体管
电子发烧友网为你提供()2N5195相关产品参数、数据手册,更有2N5195的引脚图、接线图、封装手册、中文资料、英文资料,2N5195真值表,2N5195管脚等资料,希望可以帮助到广大的电子工程师们。
2019-04-18 19:54:09
SPTECH硅NPN功率晶体管2N5193/5194/5195规格书.pdf
2021-12-28 11:18:258
MS5195模数转换器概述、特点及应用
瑞盟 MS5194T/MS5195T 为适合高精度测量应用的低功耗、低噪声、六通道差分输入的 24bit/16bit 模数转换器。完美替代AD7795。
2022-07-19 09:42:341670
多载波GSM/EDGE发射器的关键DAC参数
以下文章将深入探讨带LVPECL数字输入的260Msps、14位数模转换器(DAC)MAX5195如何适应基于GSM/EDGE的收发器设计。本文详细介绍了确切的SFDR、IMD、SNR和MTPR要求
2023-02-25 12:09:041256
用于高性能通信的数模转换器
,14位MAX5195为工作在高达260Msps采样速率的生产DAC提供最大的动态范围。两者都采用小型表面贴装封装。这些DAC还支持在UMTS、CDMA和GSM系统中生成多个载波。
2023-02-27 14:34:26416
瑞盟 MS5194T、MS5195T 概述替代AD7794、AD7795
2023-06-30 13:55:15526
MAX17525: High-Accuracy, Adjustable Power Limiter Data Sheet MAX17525: High-Accuracy, Adjustable Power Limiter Data Sheet
电子发烧友网为你提供ADI(ADI)MAX17525: High-Accuracy, Adjustable Power Limiter Data Sheet相关产品参数、数据手册,更有
2023-10-13 18:34:51
MAX30009: Low-Power, High-Performance Bioimpedance Analog Front-End Data Sheet MAX30009: Low-Power, High-Performance Bioimpedance Analog Fro
电子发烧友网为你提供ADI(ADI)MAX30009: Low-Power, High-Performance Bioimpedance Analog Front-End Data Sheet相关
2023-10-13 18:42:02
MAX16895-MAX16899: Ultra-Small, High Accuracy, Adjustable Sequencing/Supervisory Circuits Data Sheet MAX16895-MAX16899: Ultra-Small, High Ac
电子发烧友网为你提供ADI(ADI)MAX16895-MAX16899: Ultra-Small, High Accuracy, Adjustable Sequencing/Supervisory
2023-10-13 19:02:07
MAX17291B: High-Voltage Micropower Boost Converter Data Sheet MAX17291B: High-Voltage Micropower Boost Converter Data Sheet
电子发烧友网为你提供ADI(ADI)MAX17291B: High-Voltage Micropower Boost Converter Data Sheet相关产品参数、数据手册,更有
2023-10-13 19:16:05
MAX16191: Ultra-High, 0.35% Accuracy Supervisory Circuit Data Sheet MAX16191: Ultra-High, 0.35% Accuracy Supervisory Circuit Data Sheet
电子发烧友网为你提供ADI(ADI)MAX16191: Ultra-High, 0.35% Accuracy Supervisory Circuit Data Sheet相关产品参数、数据手册,更有
2023-10-16 18:50:34
MAX25608: Twelve Switch High Brightness LED Matrix Manager for Automotive Front Lights Data Sheet MAX25608: Twelve Switch High Brightness LE
电子发烧友网为你提供ADI(ADI)MAX25608: Twelve Switch High Brightness LED Matrix Manager for Automotive Front
2023-10-16 18:52:53
MAX49921: 0 to 70V, High-Precision Current-Sense Amplifier Data Sheet MAX49921: 0 to 70V, High-Precision Current-Sense Amplifier Data Sheet
电子发烧友网为你提供ADI(ADI)MAX49921: 0 to 70V, High-Precision Current-Sense Amplifier Data Sheet相关产品参数、数据手册
2023-10-16 18:57:04
MAX20459: Automotive High-Current Step-Down Converter with USB-C Dedicated Charging Port Data Sheet MAX20459: Automotive High-Current Step-D
电子发烧友网为你提供ADI(ADI)MAX20459: Automotive High-Current Step-Down Converter with USB-C Dedicated
2023-10-16 19:16:20
MAX16143-MAX16149: High-Voltage Supervisors with Manual Reset Input Data Sheet MAX16143-MAX16149: High-Voltage Supervisors with Manual Reset
电子发烧友网为你提供ADI(ADI)MAX16143-MAX16149: High-Voltage Supervisors with Manual Reset Input Data Sheet相关
2023-10-16 19:17:18
MAX22195: High-Speed, Octal, Industrial Digital Input with Parallel Output Data Sheet MAX22195: High-Speed, Octal, Industrial Digital Input
电子发烧友网为你提供ADI(ADI)MAX22195: High-Speed, Octal, Industrial Digital Input with Parallel Output Data
2023-10-17 19:15:17
MAX20429: Dual 6A High-Efficiency Low Voltage Buck Converter Data Sheet MAX20429: Dual 6A High-Efficiency Low Voltage Buck Converter Data Sh
电子发烧友网为你提供ADI(ADI)MAX20429: Dual 6A High-Efficiency Low Voltage Buck Converter Data Sheet相关产品参数、数据
2023-10-17 19:19:34
MS5194TMS5195T六通道差分输入ADC
MS5194T/MS5195T低功耗、低噪声、六通道差分输入24bit/16bit模数深圳市芯晶图电子技术有限公司杭州办潘瑞盟原厂一级代理MS5194T/MS5195T为适合高精度测量应用的低功耗
2022-05-16 15:42:552
已全部加载完成
