TMUX136器件是一款高性能6GHz 2通道2:1开关,同时支持差动和单端信号。该器件具有2.3V至4.8V的比较V CC 范围,支持断电保护功能,当V CC 引脚断电时,强制所有I /O引脚进入高阻抗模式.TMUX136的部分引脚支持1.8V控制电压,允许它们直接与低电压处理器的通用I /O(GPIO)相连。
TMUX136采用小型10引脚UQFN封装,尺寸仅为1.5mm×2mm ,非常适合PCB面积有限的情况。
< small>所有商标均为其各自所有者的财产。
Configuration |
Number of Channels (#) |
Power Supply Type |
Vss (Min) (V) |
Vss (Max) (V) |
Vdd (Min) (V) |
Vdd (Max) (V) |
Ron (Typ) (Ohms) |
Bandwidth (MHz) |
Rating |
Operating Temperature Range (C) |
Package Size: mm2:W x L (PKG) |
Package Group |
Supply Range (Max) |
Ron (Max) (Ohms) |
Supply Current (Typ) (uA) |
Supply Current (Max) (uA) |
Features |
OFF-state leakage current (Max) (µA) |
ON-state leakage current (Max) (µA) |
Input/Output ON-state Capacitance (Typ) (pF) |
Input/Output OFF-state Capacitance (Typ) (pF) |
ESD Charged Device Model (kV) |
ESD HBM (kV) |
VIL (Max) (V) |
VIH (Min) (V) |
TMUX136 | TMUX1072 | TMUX154E |
2:1 SPDT | 2:1 SPDT | 2:1 SPDT |
2 | 2 | 2 |
Single | Single | Single |
N/A | N/A | N/A |
N/A | N/A | N/A |
2.3 | 2.3 | 3 |
4.8 | 5.5 | 4.3 |
4.6 | 6 | 6 |
6100 | 1200 | 900 |
Catalog | Catalog | Catalog |
-40 to 85 | -40 to 125 | -40 to 85 |
10UQFN: 3 mm2: 2 x 1.5(UQFN) | 10VSSOP: 15 mm2: 4.9 x 3(VSSOP) | 10UQFN: 3 mm2: 1.4 x 1.8(UQFN) 10VSSOP: 15 mm2: 4.9 x 3(VSSOP) |
UQFN | VSSOP | UQFN VSSOP |
4.8 | 3.2 | 4.3 |
7.5 | 15 | 10 |
30 | 75 | 1 |
50 | 100 | |
Powered off protection 1.8-V Compatible Control Inputs | Powered off protection 1.8-V Compatible Control Inputs Overvoltage Protection | Powered off protection 1.8-V Compatible Control Inputs |
10 | 2 | |
2 | 1 | |
1.4 | 4.5 | 7.5 |
1.6 | 4.5 | 2 |
1 | 1 | 1 |
3.5 | 2 | 8 |
0.6 | 0.5 | 0.5 |
1.3 | 1.4 | 1.3 |
