基于TMS320F28379数控500W转换器参考设计TIDM-1001电路图
电子工程师 作者:工程师陈翠 2018-06-16 17:19 次阅读
加入交流群
微信小助手二维码
扫码添加小助手
加入工程师交流群
TI公司的TMS320F28379是功能强大的32位浮点微控制器(MCU),支持新双核C28x架构,大大提升了系统性能,每核信号处理性能200MHz,集成模拟和控制外设使高端系统的设计者合并控制体系结构,不需要多个处理器;器件还集成了512KB (256KW)或1MB (512KW)闪存(ECC保护),172KB (86KW)或204KB (102KW)RAM(ECC保护或奇偶校验位保护),支持第三方开发的双区安全以及唯一识别号码.满足汽车应用的AEC Q100规范,主要用在先进驾驶辅助系统(ADAS),建筑物自动化,POS终端,EV/HEV动力传动,工厂自动化,电网架构,工业传输,医疗,健康和健美设备,马达驱动,供电,通信设备,测试和测量.本文介绍了TMS320F28379主要特性,框图,以及采用C2000™微控制器的数控500W两相交叉LLC谐振转换器参考设计TIDM-1001主要特性和指标,电路图和材料清单.
The Delfino™ TMS320F2837xD is a powerful 32-bit floating-point microcontroller unit (MCU) designed foradvanced closed-loop control applications such as industrial drives and servo motor control; solarinverters and converters; digital power; transportation; and power line communications. Completedevelopment packages for digital power and industrial drives are available as part of the powerSUITE andDesignDRIVE initiatives. While the Delfino product line is not new to the TMS320C2000™ portfolio, theF2837xD supports a new dual-core C28x architecture that significantly boosts system performance. Theintegrated analog and control peripherals also let designers consolidate control architectures and eliminatemultiprocessor use in high-end systems.
The dual real-time control subsystems are based on TI’s 32-bit C28x floating-point CPUs, which provide200 MHz of signal processing performance in each core. The C28x CPUs are further boosted by the newTMU accelerator, which enables fast execution of algorithms with trigonometric operations common intransforms and torque loop calculations; and the VCU accelerator, which reduces the time for complexmath operations common in encoded applications.
The F2837xD microcontroller family features two CLA real-time control coprocessors. The CLA is anindependent 32-bit floating-point processor that runs at the same speed as the main CPU. The CLAresponds to peripheral triggers and executes code concurrently with the main C28x CPU. This parallelprocessing capability can effectively double the computational performance of a real-time control system.
By using the CLA to service time-critical functions, the main C28x CPU is free to perform other tasks, suchas communications and diagnostics. The dual C28x+CLA architecture enables intelligent partitioningbetween various system tasks. For example, one C28x+CLA core can be used to track speed andposition, while the other C28x+CLA core can be used to control torque and current loops.
The TMS320F2837xD supports up to 1MB (512KW) of onboard flash memory with error correction code(ECC) and up to 204KB (102KW) of SRAM. Two 128-bit secure zones are also available on each CPU forcode protection.
Performance analog and control peripherals are also integrated on the F2837xD MCU to further enablesystem consolidation. Four independent 16-bit ADCs provide precise and efficient management of multipleanalog signals, which ultimately boosts system throughput. The new sigma-delta filter module (SDFM)works in conjunction with the sigma-delta modulator to enable isolated current shunt measurements. TheComparator Subsystem (CMPSS) with windowed comparators allows for protection of power stages whencurrent limit conditions are exceeded or not met. Other analog and control peripherals include DACs,PWMs, eCAPs, eQEPs, and other peripherals.
Peripherals such as EMIFs, CAN modules (ISO 11898-1/CAN 2.0B-compliant), and a new uPP interfaceextend the connectivity of the F2837xD. The uPP interface is a new feature of the C2000™ MCUs andsupports high-speed parallel connection to FPGAs or otherprocessors with similar uPP interfaces. Lastly,a USB 2.0 port with MAC and PHY lets users easily add universal serial bus (USB) connectivity to theirapplication.
TMS320F28379主要特性:
• Dual-Core Architecture
Two TMS320C28x 32-Bit CPUs
200 MHz
IEEE 754 Single-Precision Floating-Point Unit(FPU)
Trigonometric Math Unit (TMU)
Viterbi/Complex Math Unit (VCU-II)
• Two Programmable Control Law Accelerators(CLAs)
200 MHz
IEEE 754 Single-Precision Floating-PointInstructions
Executes Code Independently of Main CPU
• On-Chip Memory
512KB (256KW) or 1MB (512KW) of Flash(ECC-Protected)
172KB (86KW) or 204KB (102KW) of RAM(ECC-Protected or Parity-Protected)
Dual-Zone Security Supporting Third-PartyDevelopment
Unique Identification Number
• Clock and System Control
Two Internal Zero-Pin 10-MHz Oscillators
On-Chip Crystal Oscillator
Windowed Watchdog Timer Module
Missing Clock Detection Circuitry
• 1.2-V Core, 3.3-V I/O Design
• System Peripherals
Two External Memory Interfaces (EMIFs) WithASRAM and SDRAM Support
Dual 6-Channel Direct Memory Access (DMA)Controllers
Up to 169 Individually Programmable,Multiplexed General-Purpose Input/Output(GPIO) Pins With Input Filtering
Expanded Peripheral Interrupt Controller (ePIE)
Multiple Low-Power Mode (LPM) Support WithExternal Wakeup
• Communications Peripherals
USB 2.0 (MAC + PHY)
Support for 12-Pin 3.3 V-Compatible UniversalParallel Port (uPP) Interface
Two Controller Area Network (CAN) Modules(Pin-Bootable)
Three High-Speed (up to 50-MHz) SPI Ports(Pin-Bootable)
Two Multichannel Buffered Serial Ports(McBSPs)
Four Serial Communications Interfaces(SCI/UART) (Pin-Bootable)
Two I2C Interfaces (Pin-Bootable)
• Analog Subsystem
Up to Four Analog-to-Digital Converters (ADCs)
16-Bit Mode
1.1 MSPS Each (up to 4.4-MSPS SystemThroughput)
Differential Inputs
Up to 12 External Channels
12-Bit Mode
3.5 MSPS Each (up to 14-MSPS SystemThroughput)
Single-Ended Inputs
Up to 24 External Channels
Single Sample-and-Hold (S/H) on Each ADC
Hardware-Integrated Post-Processing of ADCConversions
Saturating Offset Calibration
Error From Setpoint Calculation
High, Low, and Zero-Crossing Compare,With Interrupt Capability
Trigger-to-Sample Delay Capture
Eight Windowed Comparators With 12-BitDigital-to-Analog Converter (DAC) References
Three 12-Bit Buffered DAC Outputs
• Enhanced Control Peripherals
24 Pulse Width Modulator (PWM) ChannelsWith Enhanced Features
16 High-Resolution Pulse Width Modulator(HRPWM) Channels
High Resolution on Both A and B Channels of8 PWM Modules
Dead-Band Support (on Both Standard andHigh Resolution)
Six Enhanced Capture (eCAP) Modules
Three Enhanced Quadrature Encoder Pulse(eQEP) Modules
Eight Sigma-Delta Filter Module (SDFM) InputChannels, 2 Parallel Filters per Channel
Standard SDFM Data Filtering
Comparator Filter for Fast Action for Out ofRange
• Configurable Logic Block (CLB)
Augments Existing Peripheral Capability
Supports Position Manager Solutions
• Package Options:
Lead-Free, Green Packaging
337-Ball New Fine Pitch Ball Grid Array(nFBGA) [ZWT Suffix]
176-Pin PowerPAD™ Thermally Enhanced Low-Profile Quad Flatpack (HLQFP) [PTP Suffix]
100-Pin PowerPAD Thermally Enhanced ThinQuad Flatpack (HTQFP) [PZP Suffix]
• Temperature Options:
T: –40ºC to 105ºC Junction
S: –40ºC to 125ºC Junction
Q: –40ºC to 125ºC Free-Air
(AEC Q100 Qualification for AutomotiveApplications)
TMS320F28379应用:
• Advanced Driver Assistance Systems (ADAS)
• Building Automation
• Electronic Point of Sale
• Electric Vehicle/Hybrid Electric Vehicle (EV/HEV)Powertrain
• Factory Automation
• Grid Infrastructure
• Industrial Transport
• Medical, Healthcare, and Fitness
• Motor Drives
• Power Delivery
• Telecom Infrastructure
• Test and Measurement
图1.TMS320F28379功能框图
This TI Design implements a digitally-controlled, 500-W, two-phase interleaved LLC resonant converter. Thesystem is controlled by a single, C2000 microcontroller(MCU), MS320F28379, which also generates pulsewidth modulation (PWM) waveforms for all powerelectronic switching devices under all operatingmodes. This design implements an innovative current
sharing technique to accurately achieve currentbalancing between phases.
Resonant converters are popular DC-DC converters frequently used in server, telecom, automotive,industrial, and other power supply applications. The converters are a good choice for medium- to highpowerapplications because of their adherence to improving industry standards, ever-increasing powerdensitygoals, and high-performance (efficiency, power density, and so forth) standards,These are variable-frequency converters where the PWM-switching frequency of operation frequentlychanges during runtime. For reliable operation the changing frequencies must not produce any glitches orirregular PWM behavior. For applications with high-output currents that require input-output isolation, it is acommon practice to use synchronous rectification (SR) on the secondary of the isolation transformer. SRuses additional power electronic devices switching with changing frequencies. High-power applicationsmay require use of multiphase interleaved converters. These interleaved converters have even moredevices switching with variable frequencies and additionally require fixed-phase relationships betweenvarious phases under all operating frequencies. Guaranteeing correct PWM waveform generation withchanging frequencies under all operating conditions is a big challenge for the controller. Furthermore,interleaving multiple phases of resonant converters presents current sharing challenges between phases.
Inadequate or improperly implemented current sharing or incorrect PWM waveform generation can lead toconverter failure, significant system or component damage, and, in the worst case, significant propertydamage or resultant bodily injury or loss of life.
In server and telecom power supply applications, these converters are used to work as the isolated DCDCconverter stage in the rectifier system. These converters provide high fficiency and power densitythrough soft-switching, SR, and other techniques.
These converters are gaining popularity in automotive on-board charging applications. Additionally, thesedevices may be used as isolated, bi-directional converters in electric vehicles (EVs) and hybrid electricvehicle (HEVs).
This design implements a 500-W, two-phase, interleaved half-bridge (HB) LLC resonant converter with SRon the secondary. The system is controlled by a single C2000 MCU, TMS320F28379, which alsogenerates correct PWM waveforms for all power electronic switching devices (MOSFETs) using the latestfeatures on C2000 MCUs. An innovative current sharing technique is implemented by the C2000 MCU toaccurately achieve current and phase balancing for multiphase interleaved converters.
The accompanying software allows programming the controller and experimenting with different controlparameters to tune the control loop for good system performance. This design supports the use of C2000powerSUITE tools like the compensation designer, the software frequency response analyzer, and thesolution adapter. The software project allows users to evaluate the complete system with the help of thesesupported tools. This document provides the hardware and software design details along with the testresults. This document also describes a structured step-by-step method to evaluate this solution bystarting with a simple open-loop excitation and then working towards a complete well-tuned closed-loopsystem.
TMS320F28379主要特性:
• Digitally-Controlled Two-Phase Interleaved LLCResonant DC-DC Converter
• 500-W (250 W per Phase) Full-Load Power or42.5-A Full-Load Current
• Vin: 370-V to 410-V DC
• Vout: 12-V DC
• Resonant Frequency: 250 kHz, SwitchingFrequency Range: 200 kHz to 350 kHz
• Peak Efficiency: 94.5%, Efficiency > 90% for allLoads Above 10% of Rated Load
• Excellent Current Sharing Between Phases WithoutAny Additional Hardware
• Phase Shedding With Programmable Limits
• Fault Protection: Phase and Output Overcurrent,Output Overvoltage, and Input Undervoltage andOvervoltage
• Supported by Various C2000 powerSUITE Tools
TMS320F28379应用:
• Server Power Supplies
• Telecom Rectifiers
• Automotive Charging
• Industrial Power Supplies
图2.500W转换器参考设计TIDM-1001外形图
500W转换器参考设计TIDM-1001主要性能指标:
图3.参考设计TIDM-1001系统框图
图4.两相交叉HB LLC转换器框图
图5. 参考设计TIDM-1001电路图(1)
图6. 参考设计TIDM-1001电路图(2)
图7. 参考设计TIDM-1001电路图(3)
图8. 参考设计TIDM-1001电路图(4)
图9. 参考设计TIDM-1001电路图(5)
图10. 参考设计TIDM-1001电路图(6)
参考设计TIDM-1001材料清单:
  • 转换器
  • TI公司
加入交流群
微信小助手二维码
扫码添加小助手
加入工程师交流群
    热点推荐
    新旭48V/500W有刷电机控制电路图
    新旭48V/500W有刷电机控制电路图
    发表于 11-08 13:24
    请问谁有无线充电500w设计方案和无线充电电路图
    无线充电500w,充锂电池48v。充电电压最高是DC58v,充电电流最大10A.使用2.4GHz无线发射接收模块。发射和接收部分要有指示灯。有各种充满保护、过压、过流等保护。有详细的电路图。最好有实物。
    发表于 05-17 18:04
    使用C2000 MCU的数控式两相交错LLC谐振转换器设计
    参考设计实现了 500W数控式两相交错 LLC 谐振转换器。该系统由单个 C2000™ 微控制 (MCU) TMS320F28379
    发表于 12-26 14:42
    请问有500W逆变器电路图吗?
    500W逆变器电路图
    发表于 10-25 06:27
    新旭48V/500W有刷电机控制电路图
    新旭48V/500W有刷电机控制电路图
    发表于 10-17 17:34 119次下载
    新旭48V/<b class='flag-5'>500W</b>有刷电机控制<b class='flag-5'>器</b><b class='flag-5'>电路图</b>
    500W灯泡软启动电路图
    500W灯泡软启动电路图
    发表于 01-20 22:35 1483次阅读
    <b class='flag-5'>500W</b>灯泡软启动<b class='flag-5'>电路图</b>
    500W功率放大器电源电路图
    500W功率放大器电源电路图
    发表于 04-26 14:38 5993次阅读
    <b class='flag-5'>500W</b>功率放大器电源<b class='flag-5'>电路图</b>
    500W音响功率放大器开关电源电路图,原理
    发表于 05-12 00:57 1.3w次阅读
    <b class='flag-5'>500W</b>音响功率放大器开关电源<b class='flag-5'>电路图</b>,原理<b class='flag-5'>图</b>
    500W逆变器电路图
    500W逆变器电路图
    发表于 05-13 13:33 6072次阅读
    <b class='flag-5'>500W</b>逆变器<b class='flag-5'>电路图</b>
    晶体管构成的500W输出功率放大器电路图
    发表于 07-13 17:51 2168次阅读
    晶体管构成的<b class='flag-5'>500W</b>输出功率放大器<b class='flag-5'>电路图</b>
    直流12V转220V交流逆变器电路图 (500W)
    直流12V转220V交流逆变器电路图 (500W) 直流12V转220V交流逆变器电路图可以转换为12V直流转220伏交流
    发表于 03-05 16:10 4.2w次阅读
    直流12V转220V交流逆变器<b class='flag-5'>电路图</b> (<b class='flag-5'>500W</b>)
    山特500W逆变器电路图(原厂电路
    山特500W逆变器电路图
    发表于 04-22 18:13 7111次下载
    山特<b class='flag-5'>500W</b>逆变器<b class='flag-5'>电路图</b>(原厂<b class='flag-5'>电路</b>)
    开源硬件-TIDM-1001-使用 C2000 MCU 的两相交错式 LLC 谐振转换器 PCB layout 设计
    发表于 12-07 18:04 0次下载
    开源硬件-<b class='flag-5'>TIDM-1001</b>-使用 C2000 MCU 的两相交错式 LLC 谐振<b class='flag-5'>转换器</b> PCB layout 设计
    TMS320F28379D TMS320F2837xD双核Delfino微控制
    电子发烧友网为你提供TI(TI)TMS320F28379D相关产品参数、数据手册,更有TMS320F28379D的引脚、接线图、封装手册、中文资料、英文资料,TMS320F28379
    发表于 04-18 20:03
    500W全保护IGBT电鱼机电路图
    500W全保护IGBT电鱼机电路图
    发表于 12-08 09:18 92次下载
