Wuppertal, Germany based industrial designer Stefan Reichert presented a new 3D printer concept for his Bachelor of Arts in Industrial Design at the University of Wuppertal: XEOS 3D printer.
This desktop 3D printer separates itself from conventional printers through its two windows design. It has a 5x5x5 inch (127x127x127 mm) build envelope which is 66% smaller than the smallest FDM 3D printer with the same build envelope (Stratsys Mojo)。
The uplifting door controlled by the Stop/Open button on the outside gives easy access to the printed parts and the cartridge bays. The integrated fisheye camera helps to control the printing process from everywhere. The LED status bar displays the printjob progress and is easy to see even across the room.
The innovative FDM print arm is inspired by a robotic arm on a wafter handling robot. Watch below the print arm in action.
The XEOS 3D printer supports ABS and PLA plastic filament and its new black support polymer material is easily removable with hot water. They are held by two material cartridge bays.
自动翻译仅供参考
XEOS 3D打印机
伍珀塔尔,德国工业设计师斯特凡·赖克特提出了他的文学士工业设计在乌珀塔尔大学的新的3D打印机概念:XEOS 3D打印机。
这个桌面3D打印机通过它的两个窗口设计将自己与传统打印机分开。它有一个5x5x5英寸(127x127x127mm)的构建信封,比最小的FDM 3D打印机具有相同的构建信封(Stratsys Mojo)小66%。
振奋人心的门口外面的停止/打开按钮控制,可以轻松访问打印部分和墨盒托架。集成的鱼眼镜头的相机帮助来自世界各地的控制印刷过程。 LED状态栏显示将打印作业进度,很容易,甚至在房间里看到的。
创新FDM打印臂是通过在wafter处理机器人的机器人手臂的启发。观看下面的打印臂动作。
该XEOS 3D打印机支持ABS和PLA塑料丝及新的黑色支持高分子材料很容易拆卸用热水。它们是由两个材料盒托架保持。
3D打印
26文章
3475浏览量
107653
