TPS63024是一款高效,低静态电流降压 - 升压转换器,此转换器适用于输入电压会高于或低于输出的应用。在升压模式下,输出电流可高达1.5A,而在降压模式下,输出电流可高达3A。开关内的最大平均电流被限制在3A(典型值).TPS63024根据输入电压在降压或升压模式之间自动切换,以便在整个输入电压范围内调节输出电压,从而确保两个模式间的无缝转换此降压 - 升压转换器基于一个使用同步整流的固定频率,脉宽调制(PWM)控制器以获得最高效率。在低负载电流情况下,此转换器进入省电模式,以便在整个负载电流范围内保持高效率。有一个使用户能够自动PFM /PWM模式运行和强制PWM运行之间进行选择的PFM /PWM引脚。在PWM模式期间,通常使用一个2.5MHz的固定频率。使用一个外部电阻分压器可对输出电压进行编程,或者在芯上对输出电压进行内部固定。转换器可被禁用以最大限度地减少电池消耗。在关机期间,负载从电池上断开。此器件采用20引脚,1.766mm x 2.086 mm,WCSP封装。
所有商标均为其各自所有者的财产。
Topology |
Vin (Min) (V) |
Vin (Max) (V) |
Vout (Min) (V) |
Vout (Max) (V) |
Switch Current Limit (Typ) (A) |
Duty Cycle (Max) (%) |
Switching Frequency (Min) (kHz) |
Switching Frequency (Max) (kHz) |
Iq (Typ) (mA) |
Features |
Iout (Max) (A) |
Operating Temperature Range (C) |
Rating |
Package Group |
TPS630242 | TPS63024 | TPS630241 | TPS630250 | TPS630251 | TPS630252 |
Buck/Boost | Buck/Boost | Buck/Boost | Buck/Boost | Buck/Boost | Buck/Boost |
2.3 | 2.3 | 2.3 | 2.3 | 2.3 | 2.3 |
5.5 | 5.5 | 5.5 | 5.5 | 5.5 | 5.5 |
3.3 | 2.5 | 2.9 | 2.3 | 2.9 | 3.3 |
3.3 | 3.6 | 2.9 | 3.6 | 2.9 | 3.3 |
3 | 3 | 3 | 4.5 | 4.5 | 4.5 |
100 | 100 | 100 | 100 | 100 | 100 |
2500 | 2500 | 2500 | 2500 | 2500 | 2500 |
0.035 | 0.035 | 0.035 | 0.035 | 0.035 | 0.035 |
Enable Light Load Efficiency Load Disconnect Output Discharge Synchronous Rectification UVLO Fixed | Enable Light Load Efficiency Load Disconnect Output Discharge Synchronous Rectification UVLO Fixed | Enable Light Load Efficiency Load Disconnect Output Discharge Synchronous Rectification UVLO Fixed | Enable Light Load Efficiency Load Disconnect Output Discharge Synchronous Rectification UVLO Fixed | Enable Light Load Efficiency Load Disconnect Output Discharge Synchronous Rectification UVLO Fixed | Enable Light Load Efficiency Load Disconnect Output Discharge Synchronous Rectification UVLO Fixed |
1.5 | 1.5 | 1.5 | 2 | 2 | 2 |
-40 to 85 | -40 to 85 | -40 to 85 | -40 to 85 | -40 to 85 | -40 to 85 |
Catalog | Catalog | Catalog | Catalog | Catalog | Catalog |
DSBGA | DSBGA | DSBGA | DSBGA VQFN-HR | DSBGA | DSBGA |
